Faux Cordwood Wall
Started by Jeff, April 23, 2016, 08:19:21 PM
This spring we tore a stone wall out that used to be at our front entrance. (link) It was nice looking, but very obtrusive. Once the flowering crab tree died, (link) it was an easy decision to go ahead and redo the front entry, and that is what we are working on now.
So, I got the wood-mizer fired up and made some cookies out of some of the cedar I had here. I cut a hunk of treated plywood to fit the area I wanted to address on the entry way. I then painted that to hopefully emulate the color of mortar.  I then arranged all the cedar cookies on the board and screwed them on from the back. We could then afic the entire sheet of plywood to the wall, and it can be removed if we want to do something else.  The picture below shows it dry fitted.  It has to come out so I can pour the concrete where the dirt behind the wall was. I have some other ideas for finishing off the new treated berm wall with cedar logs. Again, can;t do that until the concrete is poured, and they will do that when they pour my polebarn floor.
To cut the cookies I cut some logs in short lengths, then strapped them together in a bundle. Stood the bundle up and secured it to the mill, then sliced away.  When I got down to my strap, I took the bundle apart then screwed the remaining log ends to a board, and finished slicing them up.  The blade I used has been on that mill getting rusty for about two years, but it worked fine for this.  I'll change it before cutting any lumber though.  The mill ran well, but my feed is really jumpy for some reason, so I just pushed the head through the cookie cuts.
All in all, I think our Faux Cordwood wall looks really good!
Pictures begin with the stone wall that was there that needed to go.
Wow.  That really changes the entrance.  Looks great.  You are going to enjoy that extra space.
LAZERDAN
Well that looks pretty dan g   good.  All in a days work.
        Lazerdan
I need to figure out what I am going to seal the cedar with. I don't want a stain, just something clear that I can spray on if someone has some suggestions?
Gearbox
Jeff I showed that wall to my wife now she wants one but this summer project list is full .
Ox
Gosh, I've always loved the look of cordwood walls.  Looks really nice.  A suggestion for a clear spray on is spar urethane.  I love the stuff.  It shines up a bit, not glassy but a warm gloss.  It works on metal, wood, stone.  I love the stuff and it lasts for at least several years out of direct sunlight.  Periodic re-application would be required eventually, of course!  It seems like nothing lasts forever.  :)
Looking good.  Helmsmen has the UV inhibitors that you may need.
POSTON WIDEHEAD
What ever you decide to seal it with, I am assuming you will lay the wall down flat and give it a good soaking.   :)
While your over there shooting water balloons, I'll sneak over there and write my name on one of them.  :D
Corley5
What about soaking them with/in linseed oil?
I was thinking an oil, too.  Like 100% pure tung oil.  Spar urethane will peel as it weathers.
wndwlkr65
Maybe boiled linseed oil ?
Corley5
Some AW32 would probably do just as well  ;) ;D
barbender
     That looks really nice, Jeff!  I love the look of cordwood walls, too.
Gary_C
The question is will you be happy when the log ends turn the normal aged color, probably black or grey or do you want to prevent that discoloration? I doubt just oils will stop the color change.
Maybe the same stain that is on the rest of the siding?
Very nice fix by the way.  8)
gfadvm
Quote from: Ox on April 23, 2016, 08:53:25 PM
The "out of direct sunlight" is critical. Helmsman Spar Urethane will peel/crack in a very short time if exposed to Oklahoma sun. You milage may vary.
Don_Papenburg
I like Zinzer Sanding sealer, it is a dewaxed shellac  that can be coated over without sanding as needed . just clean and coat . The varnish will melt into the old .I like it for outside doors  without a paint job.
21incher
That looks great. You may want to come up with some kind of termite/ant shield to keep bugs from making tunnels between the wall and plywood with it being less then 8" of ground clearance. :)
timberlinetree
Neat and original. Nice job!
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Quote from: 21incher on April 24, 2016, 06:11:48 AM
There will be concrete underneath it, plus, it is northern white cedar and pressure treated plywood over plastic lined treated plywood. I don't think there will be a problem. We also already have a wood foundation that hasn't had an issue in 32 years.  :)
red
There is a very smart business man on here that sells lots of Cedar products . I can't remember his name ?  His son may sell.mulch in another state . . . I think he is the go to man for this question
What is the question?  :) cedarman is an erc guy.
From the research I'm doing this morning, the cordwood guru's say don't seal. The beauty of the fake wall, is if it turns into something we don't like, it is easily changed out.
Bruno of NH
My 2 cents linseed oil
Bruno
Ox
I've done a few projects with boiled linseed oil and Helmsman spar urethane.  It leaves the most beautiful finish to my eyes.
Jeff, do they say not to seal for vapor/moisture purposes?  As in you need to let the wall "breathe" a bit reducing the trapped moisture inside the wood blocks with a sealed end?
Yes. Moisture is the enemy of cord wood, and end grain according to Rob Roy's books, you should not seal cord wood construction walls on the exterior. Interior is different.  Sealing can lead to trapped moisture and additional maintenance and upkeep.  We are going to try to let it weather naturally this first time. If we don't like the results of that, this is very easy to try again by simply removing the entire plywood sheet. Its a fun project anyhow  :)
