Sawdust
Started by 4x4American, April 23, 2016, 09:50:03 AM
4x4American
My neighbor milks a little over 60 head of jerseys and holsteins, he uses sawdust for bedding.  Right now he buys it from a guy a few hours north.  He's interested in mine.  I did mention that it's prolly too fine and can get in their teats and being wet can cause mastitis, but then he came back and said it might be something where he could mix it into his current sawdust to make it go a little further plus he gives his cows the 9 in 1 shot which should help protect against mastitis.
He mainly uses pine sawdust now, and I don't think it's KD.  My question is: can he use hardwood sawdust as an additive?  I'm planning to mainly be sawing hardwood, even though I have a load of pine sawdust for him now (with a little locust mixed in).  Is there any sawdusts to keep out of the mix ie cherry?  Will that locust hurt anything?
I am thinking to trade him sawdust for bushog work..
Boy, back in my day..
Chuck White
I really don't see why he couldn't us most any type of sawdust, he just needs to keep in mind what you had said about the "fine" sawdust and infection.
My suggestion for him would be to use circlesaw sawdust for bedding and use the fine stuff to spread on the platform in the dairy barn!
paul case
Walnut is a NO NO.
PC
pc
wesdor
When I was growing up we milked cows and went to a nearby lumber yard to get their sawdust.  As I recall it was much coarser than what comes off my mill so I think you may have good concerns.
I agree with Paul Case - Walnut is a problem.  A friend of mine has dairy goats and there is something in Cherry bark that is poisonous to them (not sure if it does the same to cows).
Peter Drouin
Hardwood will burn the feet, softwood is ok. ;D
A&P saw Mill LLC.
License NH softwood grader.
cuznguido
Cherry and walnut are definite no-no.  Red oak is not good but will not harm them is diluted pretty well with the lighter woods.
Dave Shepard
No hardwoods for lactating cows. Not sure about the particle size. I've heard it's an inhalation issue, but if it's fresh and damp it might not be a problem.
1ruralmailman
  walnut,and oak will both cause skin issues after a while of being exposed to it.cherry i think would be fine,but i know that the dried leaves of cherry are poisonous,and will kill a adult cow.we used to use bandsawn sawdust,but only from a softwood mill for our cows,only thing is it is a little harder to spread due to the fine grit it is.the coarser was alot easier to flip under them off a silage fork.
Dave Shepard
Strangely, cows can eat green cherry leaves, but not dry. I think it's cyanide that forms when the leaf dries.
4x4American
Interesting...
Thanks for all the responses
Cazzhrdwd
Works great for my cows. Its the best bedding I've ever used. Walnut is not a problem and Oak is what I use most.
96 Woodmizer LT40Super  Woodmizer 5 head moulder
ncsawyer
Quote from: Dave Shepard on April 23, 2016, 08:43:08 PM
They can eat dried or green leaves with no problems.  Prussic acid (hydrogen cyanide) poisoning occurs when ingesting leaves in a wilted state. Because cyanide is a gas, it gradually dissipates as the plant tissue dries.  This is why dried leaves are OK...but I still don't want my livestock eating cherry leaves.  The same is true for sorghum forages.  DO NOT let cows graze sorghum shortly after it has been frosted on for the same reason.
4X4, has your friend got a free stall barn or a compost pack barn?
Our neighbor has a compost pack barn and was using kiln dried shavings with very good results.  His pack in the barn was reaching 90+ degrees.  He started blending some brooder litter in with the shavings (said you couldn't tell the difference just looking at it).  So it must have been very clean. After that he had some pretty bad sub-clinical mastitis issues.  Only way he new was the SCC count in the tank was sky rocketing.
Checked his pack temp in the barn, much cooler than before.  Wasn't getting hot enough to kill the bacteria in the barn.  I think your concerns with your sawdust are very legitimate.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
I had a customer that piled Pine sawdust, bark, whatever else was left after I sawed for him.  A week or so later he called me in a panic.  The pile had ignited (spontaneous combustion) and had also burned his nearby stickered lumber.
paul case
Ouch!
That would be an expensive mistake.
PC
pc
Walnut is a definite no-no for horses. The juglone in it leaches out when they pee on it, and affects their hooves, causing Laminitus, which is a detachment of their hooves. A horse without hooves is a goner.  Cows don't seem to be affected in the same way.
QuoteWhen I was growing up we milked cows and went to a nearby lumber yard to get their sawdust.  As I recall it was much coarser than what comes off my mill so I think you may have good concerns.
Probably a Circle mill. They make much bigger "sawdust", more like chips from a nice sharp chainsaw. It does make better animal bedding than the finer band saw dust.
4x4American
NC he has a tie stall barn with a pipeline.
Sixacresand
Quote from: Magicman on April 23, 2016, 10:26:45 PM
The older than me generation did not use the word "composting".  Everything was put in a pile and allowed to "go through a heat" before putting in the garden.  I have never seen one ignite itself, but I know it possible.
petefrom bearswamp
My sawdust pile sits idle for a month or so and has bark mixed in, no combustion problems as yet,.
I spoil it in the edge of my mill area in a brushy place and it has been ther for 10 yrs and more now no probs.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
I kinda thought it had to be a big pile of sawdust to do that. Not just one even 4 feet high.
YoungStump
 A neighboring farmer uses some of the sawdust from my mill for his cows and he actually prefers it over the coarser sawdust from the circular mills, he says the cows like it because it's softer.
We sell hardwood sawdust to horse and dairy farmers everyday and I've never heard of anyone having issues with it except that we really need to watch if we cut walnut that it doesn't go to anyone with horses.
Echo Enterprises 45HD2 production series band mill, Cook's Edger, sawing mostly pallet cants, rr ties, and grade lumber.
I doubt that the pile that I referred to was even 2 feet high.  I think that the major contributing factor in this instance was that it was not all sawdust.  It was the mixture.  I have not heard of such before or since.
Carson-saws
I also sell my sawdust.  Primarily to farmers but have a regular that uses it for Hamster bedding and in bird cages.  I GIVE sawdust to a Mother that has a child that can not play in sand for whatever reason.  So she uses it as a sandbox material for her children.
Let the Forest be salvation long before it needs to be
Chuck White
Seems I read somewhere that there is a state or two in the North East where it's illegal to have a sawdust pile higher than 3 feet!
Around here, I see sawdust piles at Amish mills that are 25-30 feet high!
WV Sawmiller
Peter Drouin,
   You said hardwood sawdust will burn the animal's feet. Any idea why? Is it a chemical reaction in the wood or just the normal "heat" from oxidation as the sawdust rots?
Hackermatack
I think you guys are making much to do about nothing. Yes walnut is bad especially for horses. Green sawdust especially hardwood will have coliform bacteria but storing it for a wile in a large pile will generate heat enough to kill most of it and it most likely won't burst into flames. After a cow is milked a plug forms in the teat end that helps keep objects and bacteria out and good dairymen dip the teat end in a disinfectant solution before and after milking. Many dairymen bed freestalls with sand which is at least as fine as sawdust. Oh and by the way I have milked quite a few cows in my day, ain't ever milking another one though  :laugh:
Jonsered 2230, 590, 70E. Kioti DK 35 /w fransguard winch. Hudson Oscar 236
