BT-6870 built by two old guys
Started by svart ole, April 22, 2016, 10:19:31 AM
svart ole
This is what happens when two old guys have no adult supervision.
My wife said I collect junk, I told her I am a amateur industrial archaeologist just trying to save valuable artifacts.
r.man
Looks good. Does the saw travel down instead of pivoting? Have you run it much?
Life is too short or my list is too long, not sure which. Dec 2014
svart ole
Up and down on V rollers. Did a few short tests, waiting for the paint to get hard.
Gearbox
svart ole
Point of fact, he is the OLDER old guy.
sprucebunny
Looks good !!
I like the brooms... my kind of engineering  :D
Ox
Good ol' backwoods engineering.  Lots of heavy steel in it.  I love it.  Any chance of getting a video up showing it in operation for us?
Gearbox
Soon as the paint hardens a bit . Just aired up the tires . Sunday ??
Looking forward to more pictures.
r.man
Ok I will be the one to bite, why BT-6870, is it first initials and ages?
Gearbox
r . man you win the prize . 2 blocks of split red oak but you have to come to MN to get them . Bob 70 Ted 68 .
Hilltop366
lopet
Interesting design.    Like that lime green  too. :)
Make sure you know how to fall properly when you fall and as to not hurt anyone around you.
Also remember, it's not the fall what hurts, its the sudden stop. !!
Deeprut
What kinda bristles are in the brooms?
svart ole
Deeprut,
Palmyra bristles, they resemble split bamboo and are quite stiff. The broom heads where available locally. Time will tell how the bristles hold up in the wet weather. The paint should help keep them from getting soggy.
Gearbox
Ace has them called driveway broom . Morning Ted
GAB
Quote from: r.man on April 22, 2016, 09:14:19 PM
Is the BT-7072 on the drawing board yet?
The funniest drawing I remember seeing was of a toilet seat.  In the revision block for Rev A it read "added hole in middle".
Gerald
svart ole
GAB.
We regularly discuss future projects at or frequent planning and evaluations meetings. The meetings are normally held mid morning and or mid afternoon and most often involve coffee cups and cake pieces. Although bars, cookies and rolls are more often on the table. We seldom use the drawing board as a scrap piece of wood or the end of a block of wood is normally used. Design involves the frequent use of our two on board data bases and access to the whatworkshistory folder. As of late the individual files in the folder do not always open of the first try. I understand that this may be a RAM issue and is not uncommon in older models.
bigblue12v
Lol! You guys are a hoot! Wish you were my neighbors we'd get into a lot of trouble! I'm younger but we could make a BTE-697130 model! Lol
Anxiously looking forward to videos of it in action. How about details on the heart and soul in this thing while we wait on paint (engine, hydraulic system specs and layouts, saw details etc)
Eric
Lots of junk not enough time.. full time mechanic part time logger, firewood junkie, outside boiler owner, meat smoker enthusiast, fabricator, dad, husband
Ox
You guys are a hoot!  The wit and candor is always amusing.  Your wit, sir, is legendary.
Gearbox
You guys aren't going to get too many details yet and the vid coming up may be from a bit far away .  will release details as you guys pick up on them . It is different than most builds .
bigblue12v
Aww now don't be this way.... Propane powered? Aircraft engine? Rotary engine? Jet turbine? 3 phase electricity? Hydrogen powered? Diesel/electric hybrid? 2 cylinder John Deere engine? Steam engine (wood powered??!!! The irony!)
Kinetic splitter? You're killing me here....
Ox
It could be powered by a flux capacitor with a re-bi-cycling system for the headlight fluid, which in turn jettisons past the radiator at a speed just under the speed of light, allowing the manifold to spark sufficiently enough to capture the excess energy in a double wrapped electron storing device (a battery) which is used to energize a highly efficient light emitting diode (LED light), illuminating the lug nuts, thereby allowing the user to more easily check the hydraulic pressure in aforementioned lug nuts.  ;D
Gearbox
Gas powered with 91 @ 50 to 1 Amsoil . In a 272 Huskey . STAY TUNED
svart ole
I thought about this engine but the only place it would fit was on the gooseneck and that was not a option. Picture the guy in the blue hard hat sitting on the deck with a coffee cut in his hand. This is a long video so be warned.
https://www.youtube.com/watch?v=xa9-pUGJQa8
There is one motor other than the saw that at this point is a 272 Husky with the option of other saws like a 394XP. Only one hydraulic device driven by the second gas engine and the rest is driven by DC gear reduction motors.
We have wet weather for the next few days with any luck I can post a video by the end of the coming week. As they say a picture is worth a thousand words. We promise not to keep you in the dark for too much longer. Maybe just a little bit. I want to show the critter in operation, I figure that will clear things up to some extent.  The setup is somewhat unconventional so there is no fun in just telling the whole story all at once, there is no entertainment value in that.
As a side note the tank engine in the video link above was used to run a sawmill at one point. NOT by me. Having a MOS of 67N20 the guy who bought it wanted me to get it started for him so he knew it would run. Had fun doing it.
Some history on the engine here.  http://www.enginehistory.org/Diesels/Ch3.pdf
