How dry is it?
Started by GeneWengert-WoodDoc, April 20, 2016, 06:59:40 AM
GeneWengert-WoodDoc
For the past three weeks, the relative humidity here in GA has been running under 30% RH every afternoon almost every day.  I have seen a few days under 20% RH. And it has been windy some days.  Temperatures in the afternoon have been in the 70 F range.  Very, very unusual to be so dry in the SE USA.
This is terrible oak drying weather for green or nearly green oak, hickory, beech, and some other species thicker than 6/4.  Of course, this is ideal for pine, soft maple, ash, etc.  In such dry weather with freshly sawn oak, etc., using Shade-Dri or other techniques to slow drying is essential.
Denny
Yep same deal here in Pennsylvania but not as warm.  Bright sunny breezy dry days.  Right now Im showin' 58 degrees and 19% RH.
GeneWengert-WoodDoc
At 2 PM, April 20, 2016 we have in north GA, 69 F and 18% RH.  Unbelievable
WV Sawmiller
   Okay - may be a dumb question but where do you get your RH readings?
Our spring time is usually quite dry up here. Every time in the last two weeks they call for rain, it's bone dry. No one is allowed to burn anything on the ground. Today was suppose to be rain showers and the sun is out this afternoon, not a drop.
Den Socling
Quote from: WV Sawmiller on April 23, 2016, 12:27:52 PM
:) Years ago Gene and I did not agree on the reliability of RH meters. He was recommending some cheap low cost meters from Radio Shack while I was paying hundreds for scientific instruments. It will be interesting to see what he currently uses.
You can simply go to the Weather Channel website.  You can get the current temp and humidity at your location, plus hourly forecasts.
Probably same deal as up here, there are unmanned weather instruments at different locations, plus the DNR offices to as they monitor these things and fine fuel dryness for the fire weather index. One reason that they post fire danger on a sign out by the office. Plus the website. Afternoon humidity was below 50% yesterday after a weak low moved through and it was in the teens the day before.
xlogger
Quote from: WDH on April 23, 2016, 09:40:22 PM
that's cheap enough
GeneWengert-WoodDoc
For outside RH, I use the Weather Channel app and the weather app that came with the I-phone.  They are quite close or the same.
With these apps,  scroll down for RH on some or just tap the temperature number and then RH shows up for others.
GeneWengert-WoodDoc
The neat thing about RH measurements is that we do not need to be very precise for drying wood.  It is about 5% RH change to make only 1% MC or EMC  change, and 1% MC change is 1/5% to 1/4% shrinkage in wood...that is, it takes a 20% RH change to get 1% size change, except at very high MCs.
I did not know that you could just tap on the temp on the I-phone weather app and get the humidity.  Cool.  I know more about trees and wood than I do smart phones.  It is bad when your phone is smarter than you  :)
petefrom bearswamp
Very dry here but RH as i type this is 75.
I use the NOAA app on my android
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
I don't own any of them, never took.  ;D :D
PC-Urban-Sawyer
Quote from: WDH on April 24, 2016, 07:48:23 AM
...  It is bad when your phone is smarter than you  :).
Yeah, I first noticed that problem when we got our first dial telephone and quit using the operator to connect all calls < BIG GRIN >
Herb
Den Socling
It seems that phones can do so much that nobody can sit you down and show it all to you. Sometimes I just poke or drag an area I never tried before and all kinds of new stuff comes up. I was just thinking. I've never used it as a phone.  :D
logboy
Quote from: GeneWengert-WoodDoc on April 20, 2016, 06:59:40 AM
The obvious solution is to start storing lumber in the kiln to keep it from drying out.  ;D
I like Lucas Mills and big wood.  www.logboy.com
GeneWengert-WoodDoc
With an i-phone, did you know that if you go to the compass, and then drag the image to the left, you will have a level.  The level tells you when things are level and also how many degrees off you are too.  And another is that you do not have to give your password to use the camera...just tap the camera icon when the phone first comes on...5 or later, but maybe even earlier.
petefrom bearswamp
I only have to rotate my wrist  a couple of times to open the camera.
Had a nice rain Monday here laid the dust and greened up the grass.
Kubota 900 RTV
