Insulating D logs
Started by loggerman1959, April 03, 2016, 11:14:01 AM
loggerman1959
Do you fellas feel it necessary to put a layer of insulation between D logs in a cabin ? I wanted a nice tight look on the inside and am afraid insulation will create gaps . Anyone have any experience with this ??? Or ideas ? This is my first cabin build , and I really wanted the flats nice and tight looking .
starmac
The insulation I see used mashes flat, you can't even tell it is there. I think it basically just creates a seal.
Ladysmith
I have built 2 d log cabins and put 1/4 inch ethafoam between the rows. It has worked very well. I also caulked the logs. Once a row of logs are in place, you simply roll out the ethafoam, cut it to width, staple in place and set the next row. Thanks. Rich
Rich
loggerman1959
Thanks  , not sure what Ethafoam is though .....
starmac
I do not know what it is called, but they make insulation especially for this, it comes in rolls about 4 inches wide and is just stapled down, you can't tell it is even there, once the log compresses it.
starmac
Found a price list from the local sawmill that sells cabin supplies. What is popular here is called sill seal fiberglass log insulation, 4 in wide by 100 ft rolls sells for $20.31 cents here. There will be much cheaper places to get it, probably even here than the place I have a list from.
Raider Bill
We used a foam membrane and log cabin caulk/glue then screwed together with log screws. Been 8 years strong like bull.
Remle
Quote from: loggerman1959 on April 03, 2016, 11:14:01 AM
My neighbor built his Home/ log cabin out of red pine logs and used Sill seal Tape, then caulked the edges. He also cut a 3/4" groove down the center of each log and used a spline between the logs, with the tape/ caulk on each side. Turned out so tight he had to install an air exchange system to get rid of the moisture in the house that forms on his windows.
