JET - Snatch Block - par buckle weight?
Started by OffGrid973, March 26, 2016, 09:29:40 PM
OffGrid973
Met an old timer today who had a trailer out front that I was thinking of making into a log arch.
First job on a steep hill at brother in laws house so also mentioned I need snatch block to pull trees about 150 feet to level ground.  You guys have any idea what type of weight i should try pulling with this gem?  Picked it up for $100 bucks, not sure if it was a good deal or not.
Let me know your thoughts good or bad.
Thanks,
-Chris
Your Fellow Woodworker,
- Off Grid
OffGrid973
Cleaned up nice and I found some HHH branding, not sure if that helps identify how much pulling power this gem has.
- Off Grid
elk42
   Cwimer973
  It looks to be a 6" sheave for 5/8 or 3/4 cable if so it should be about 8 ton block.
Machinist Retired, Lt15 WM 25 HP, Stihl 044, Stihl 311, Kubota M2900w/FEL, KUBOTA L4800 w/FEL,
Lincoln Ranger 10,000, stihl 034,
OffGrid973
Thank you, that is what I was hoping for.
Appreciate the feedback
- Off Grid
sealark37
If the sheave bearings are in usable condition, it will hold bore than the cable it is designed to fit.  Regards, Clark
Onthesauk
I found a small one like that from a garage sale.  Cleaned it up, oiled it up and used it for a dozen years with nylon rope on my ATV and tractor to pull logs out of the woods.  Handy to attach at any point.
John Deere 3038E
Sukuki LT-F500
Don't attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
