Valve bank... what happened?
Started by timberlinetree, March 01, 2016, 05:48:12 AM
teakwood
How on earth can that happen? Anybody knows? clogged filters?
MattR
Filters clogged,   pressure spike for whatever reason (relief problem?),   extremely cold  weather making oil very, very thick and improper warm up time.
But now you can do some investigating with them. Continue splitting them or cut them in half. Pull out the paper and see what type of debris is in there.  Some small  metal flakes are normal . An extreme amount of small metal flakes, or big chunks, is obviously not . Also if you see brass or other colored metals , you can start to narrow down  where it came from . We have done this often.
It's hard to tell from the picture , but I don't see anything extreme.
Matt
Holmes
Is your fluid murky, whitish color? If so maybe the water in the oil froze and blew the filters apart?  That does look like what happens to frozen pipes.  Just a thought
Think like a farmer.
snowstorm
MattR
Water will, but boy you have to have such a high concentration of it that it's crazy. To have a concentration that high , you would've had problems long before it froze. Such as pumps going because of lack of lubrication , etc. We have had many systems that in some form or another have gotten contaminated with water . To the point they were near white , and we have never had them freeze so as to cause damage like this. If this was the case other things like aluminum housings and such would have broken as well . At least in my opinion .
Matt
Holmes
Are filters on the low/ no pressure side of the hydraulic system? Was there any damage to the canisters that hold the filters, expanded or deformed? If not then it probably was not freezing because with that much movement the canisters show have deformed also. So  if it is the low pressure side how can you blow out 2 filters?  Just asking
MattR
Just a question:  are these filters open on both ends or closed on one end? If they are closed on one end the possibility could be there someone install them wrong .  Or installed the wrong filters. Just a thought . I've seen crazier things done by accident.
Matt
timberlinetree
The filters are open on both ends with a bypass valve. Two pumps on the machine, same resivor. The filter are in the tank and on return lines. Sereens are on the suction side in the tank. Lot of stuff in there( metal,packing ,paint chips) and seems for some time. Hydraulics work good until it starts getting hot.I m getting real nervous about pump failure. Could a pressure release valve be getting stuck and cause this?
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
RHP Logging
What year is your machine?  The pump that runs the loader on mine is driven off the trans.  The pump on the side of the engine runs the blade/steering.  A new Prince pump can be had for 350 bucks.  Pull whichever pump it is and take it apart.  Not too big of a deal.
Buckin in the woods
MattR
Quote from: timberlinetree on April 05, 2016, 05:14:31 AM
There are two ways that relief valves fail . One is that they open too early due to a weak spring or improper adjustment. This would result in a low pressure and a weak operating system .
The other way they fail is that they don't open soon enough due to something caught in it , or improper adjustment . This would cause extra high pressures .
You also stated that the hydraulics get abnormally hot . This is usually an indication of a bypass . It can be in many places , but most likely in the pump or in an improperly adjusted relief .
I would say your first step is to contact your dealer and find out what the pressures are supposed to be set at . Get a gauge and the proper fittings and take a pressure test at the pump and on the valve bank . Make sure you get a gauge that is rated high enough for what your system supplies . I can't tell you what that is , you need to speak with your parts dealer . There are many good ones out there . I am not familiar with the specifications on your machine .
It sounds complicated but it isn't at all on an older machine like that . You must do this before you start throwing money at guesses , such as buying new pumps or other components . It's the first step .
Indeed you may have to buy a new pump , but I would certainly test first . As someone above-stated it doesn't sound as though it's a very pricey pump to change out . But getting a good gauge is something you'll be happy to have in your toolbox anyhow .
Matt
Neilo
From what MattR is saying, 2000psi. It is stamped on the relief valve.
RHP Logging
Is this machine a Franklin?  If so i have a guy who has seen and done it all.  If it wasn't for him i dont know where id be.  Id happily give you his number.
Buckin in the woods
timberlinetree
Thanks so much for the help! 87 Franklin 132. The pumps are on tranny and engine and $350 will help me sleep better( was thinking the worst $1000 or more). Its starting to seem that maybe something got stuck in the pressure relief valve? Hydraulic stuff seemed real complicated, thanks for helping to make it some what simple. I think I found a testport/valve gizmo attached to a line but not sure. I plan to work on this on Thursday or Friday. Thanks again for the help!
timberlinetree
Dose this look like a pressure valve and do I check the pressure at this plug and(sorry for all the questions)can I take this apart to clean/inspect?
bill m
MattR
Yes that's a relief valve sticking out of the side of the block . The big pipe plug above it which looks to be 1/2 or 3/4 inch , is not where you want to tap into for your pressure test . Usually it is 1/4 or 3/8 inch .  If need be you can bush down from that plug , but there should be an easier location than that .
I see two plugs on the left-hand side , I would assume one of those but I can't be sure . It can't be that difficult to get a hold of a Franklin parts or service dealer to find out the proper tap location .
And yes you can pull that relief valve out and inspect it , clean it with some starting fluid etc. . You can put it in a vice , and push on the bottom part of it with a punch or a screwdriver or something just to ensure that it moves . Under the outer cap there will be an Allen screw with a jam nut. That is for adjusting the pressures . Don't monkey with that until you get a gauge hooked to the system , and know what pressures you are looking for .
There should also be a port on your valve bank somewhere . Usually off of the end . You can tap into there , but depending on where you tap into you will have to hold a function to get a pressure . You'll have to hold a function until a cylinder is bottomed out and then hold the lever down . That is  when a relief valve is designed to kick in . So it doesn't blow a hose or something else in the system . That is when you tell what a relief is set at.
Some systems have multiple relief valves , because they are designed to send different pressures to different functions . For instance a main boom cylinder pressure may be higher than a bucket cylinder pressure . I can't say this is the case with your machine , but it is with many . The one coming right off the pump will be the main relief which dictates the pressure heading to the valve bank . There may be individual reliefs on the valve bank so as to distribute different pressures to different functions . Again I don't know, but something to look for .
Matt
schmalts
Quote from: OntarioAl on March 25, 2016, 09:35:03 AM
Timberlinetree
You are going to have to play Sherlock Holmes and find out where that metal came from that jammed the spool.
Al
yes, and look at the filter of the system to see what may have made it past the valves. If it's a cartridge or screw-on filter cut it open and see what's all in it. Hope there's not much in there.
timberlinetree
Thank you for the help. I think the pressure valve for the boom is on the valve bank. The one in the pic is for stearing/blade. Is a tee on the line going to a swing cylinder a good place to ck psi? Only see one big plug on the valve bank? The filters blew so a lot of the stuff ended in the tank( looks like years of stuff) and think the bypass on the filters where cloged and that's why they blew? I didn't get as much done since this truck had to get back on the road.
  2 axle swap
oldseabee
Probably swing cylinder would have a cushion valve some where in the circuit that would drop off pressure at or near the end of stroke to prevent slamming into the swing stops on the frame. Just a thought
timberlinetree
I think the spring cushion valve is in the valve body but not sure. Think I'm going to tee into the line to swing cylinder and ck what's going on with psi gauge. Hope things stop breaking, I need a break!
AlexHart
After an absence I just caught up on this thread.    I hope you get it figured out and I wish I could help with some magic answer/instructions but your probably (way) ahead of me at this point as far as knowledge of the system.
Good luck with it.
Logger RK
Not to change the subject but,I have a C5 with a grapple. Since we put it on the orbit motor was not very good shape. We put a good orbit motor on it last summer and after a skid or two the face plate cracked on it. It does have reliefs on that spool of the valve. There #1750. Does anyone know if when the spool is centered do those reliefs work? I believe the good motor is a carlyn 103 maybe? Do I need less psi reliefs? Or do I need inline reliefs? Because when pulling skids the motor still has to turn.  I could put it on a valve with a float position I guess? We put the wore out motor back on to it keep working.
oldseabee
Those port reliefs on the spool are mainly to protect the machine from shock loads when the valve is in neutral, like a tree falling on the grapple arch or a rear wheel dropping into a hole which would put a big shock load into the arch or boom if you have one, sometimes you want a lower pressure in one circuit but not the main relief then the port reliefs are set to the lower pressure for that circuit, so they act as main reliefs for that circuit as well as protection from shock loads.
Polish Hammer
if the oil getting is getting warm durring opertion? how warm do you have a gauge or a thermo gun to see how warm? i believe your issue is that u have a bad pump, its worn out and your getting excessive pressure on the return side due to the oil bypassing inside the pump ( case drain ) i would take the pump off and take it apart or at least pull the case drain line and put a funtion over relief and see how much oil your getting on the case drain side.
Cat 322c fmhw with waratah 622, Komatsu PC200-7 FM with waratah 622b, Timberjack 450b grapple, timberjack 660c grapple, Tigercat 630c grapple, John Deere 853j Buncher, echo saws
timberlinetree
Back up and running so far, but haven't run to much.
