Chain for McCoullough 4-30
Started by Butchie74, February 24, 2016, 09:25:23 PM
Butchie74
I have an old 4-30 saw that the chain has worn out. It is a 1/2" pitch and am having difficulty finding another one for it. Any suggestions? It has 76 drive links on it. Appears to be roughly a 30 inch bar. Thanks!
dougand3
Welcome. You have 1/2" pitch and 76 DLs. Measure gauge of  the drivers. You can also compare to the gauge of the bar slot with automotive feeler gauges and see if both #s are close. Then, you have all 3 data points to find a chain.
Butchie74
Yes I have done that. I believe it is .058 inch gauge. Thanks for the info.
weimedog
I have some 1/2 semi chisel. Think some loops in either 76 or 78 drive links.
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
