Costs for low impact selective cutting
Started by Leo Lancer 5738, February 13, 2016, 09:25:46 PM
Leo Lancer 5738
Need some guidance on bidding on the above topic. Removal of white ash trees, aver dbh 13". Felling, limbing, piling brush, bucking into about 8' bolts. Total trees 6161. Mainly level, dry ground. Summer months operation. 3 years to complete. 6 man crew. Use small equipment. Use small 4wd tractor. 2 crews felling. Workman's comp quote 125k, umbrella liability 10k. Use mid size saws. Either rough estimate per man hour or per tree. Mid-age stands. Not many ash over 50 feet. Some tight canopies. Thanks in advance
BargeMonkey
 Your bidding on the job buying the wood or bidding the job to  cut / remove the wood ? Skidding behind a tractor or cutting to 8' and loading on a trailer ? 6200 smaller trees with 6 guys, shouldn't take long. Hard to give a per tree or per hr, how many acres are you covering ? How long of skid ? Quality of employees who are cutting ? My last faller could do 100+ in the right stuff in a day if he just kept cutting flat out.
Leo Lancer 5738
This job is for mitigation in preparation for arrival of some insect that is supposed to kill all the ash trees in the area. It is up to each landowner as to what he/she wants to do with the wood. Everything is to be felled and left. Brush scattered. Additional money to be paid if landowner wants logs bucked up to firewood length. Plan to add 20% to manpower costs for these requests.
Leo Lancer 5738
About 250 acres total. 10 different landowners. All lots connected. No access problems either
blackbruin
Emerald ash borer,  got em all about killed here in central pa.  I would get an Amish crew and get their bid, add 10% fee for yourself.
BargeMonkey
 Got to love the EAB.  :D.  I'm having trouble quite understanding what your getting at. Just going in and dropping 6200 Ash for a TSI job, on 250 semi flat acres, I just don't get the idea behind 6 guys / 2 crews cutting. ??? Around here TSI work pays next to nothing, it's almost viewed as a burden on some jobs, a big reason why I see woodlots with 75% of the beech and hemlock girdled and becoming a hazard tree a few yrs later. 2 good guys cutting together should walk thru that. I would bid something like that, without any skidding or extras at 15-20.00 a tree if hand cutting, that's just throwing #'s without knowing all the particulars. The day I stack and pile brush by hand on a log job will be the last day.  :D
Lumberjohn
I would just try to buy it standing (pay accordingly) and sell the logs/firewood if they are not too far gone. At 13" dbh your not going to get many good logs.
I dont understand the 6 man crew behind 1 tractor though?  You will need the 6 guys if you are stacking/piling brush LOL.
If just laying it down I think I could make good money at BMs prices, provided there isnt a lot of messing around with tops.
Lumberjohn
I missed the part about "to be felled and left". Im still around 15-20, a guy could do 100 trees a day. What is the tractor for?
What I do with the brush on my land is cut it into small pieces,3 feet would be the longest and I aim for around 2 feet or shorter. Yes,it takes time,but you said brush scattered. That will take some time too,cutting it in short pieces will make it disappear as soon as you are done. I kinda think they might be looking for a "park look" when you are done.  12-14 foot limbs from one tree will spoil that look. Now if you cut 3-4 trees that are close together,that look is really gone. I log my land with a tractor. This also allows me to drive through my brush without getting a long piece of brush through the raditor.
sweetjetskier
In CT we have to at a minimum, chip all debris from EAB operations.
Why would they let all the wood stay on site, the EAB still has plenty of wood to feed on and reproduce for a season or more ?
Leaving the debris behind does not seem to make sense, from what I have seen or read.
Arborist, Horticulturist, Nursery and Turfgrass Professional with 27 years experience.
BargeMonkey
Quote from: sweetjetskier on February 14, 2016, 08:11:40 AM
I had wondered that also. Figured it all would be skidded out whole tree and chipped.
This last clearing job I did was quite the paperwork shuffle, anything over 1" was considered "restricted material" and required a transport plan, after some debate what to do with the mountain of chips they used them on site for erosion control.
Maybe they are just being realistic, as the cutting of the ash isn't going to stop or slow the EAB. It will only get the ash on the ground where it will not be standing dead at a later time.
That would be my thought... not that the effort is still a bit confusing and suspect the reasons and results are a bit cloudy.
Rick Alger
I assume the tractor is to pull down hangers and pull logs out of slash.
Back in the day 75 trees a day was a decent average for a two man crew to cut, skid, and buck  logs and four-foot pulp in my area. In your project I believe it would keep a third man busy all day lopping and strewing slash.
Because it will be low impact with no doubt all kinds of directional felling challenges, I would say 50 trees per three man crew might be more realistic. Walk the lot with a logger if you can, and get his input.
For wage rates I would look up the Department of Labor prevailing wage in your area for professional loggers and figure from there. For rates on the tractor, some tractor dealers have figures that might help.
Good luck
grassfed
I would say about 4 days per acre per man.
Mike
Leo Lancer 5738
 ;D Thanks for all the response. Never done commercial work, just firewood for personal use (about 100 cords/year). Thought tractor to pull down hangers, quicker than come-along? And scatter brush? As to the brush, up to landowner. Have to also give price for chipping brush. Up to each land owner as to wood use. We will take it as firewood if we can, split it with landowner, or buy it. Only have 3 months/year for project. Some of my calculations come to about 370k for entire project, including insurances. **DanG lawyers   :D
grassfed
I don't see any advantage in using a small tractor on that job. If it is 250 acres you will have the lowest possible impact with a small skidder and a very carefully designed trail system.
I would find a good forester to mark access trails and trees.
Even a small 40 horse tractor is much more awkward in the woods than a Deere 440 or something similar.
If you are going to remove wood you are going to need a trail system and you will cause some damage but by carefully planning the layout and brushing the trail surface you can minimise the damage. A skidder will ride on the brush and tops much better than a tractor.
I have 4 tractors and 1 skidder and I can tell you that an articulating skidder will make less of a mess and be several times safer safer and more efficient .
If you really want low impact job plan and space the trails carefully then use your manpower to brush in the trails then start cutting in earnest. If you try to start cutting and think you can just bring the tractor in when you have a hangup you will have a mess and waste allot of time.
Skidders get a bad rap because of poor planning,trail layout, and incompetent operators.
Mike
chevytaHOE5674
If all your doing is cutting and leaving the wood then a good feller buncher operator can be very low impact and get the job done way faster and cheaper than anybody with a chainsaw.
finding the trail
 Please keep us updated on how your deal is progressing.
gump
I find that the cost of roads become a factor as well if it is a large area. Your unit cost of road construction per unit of wood will increase. Just a thought..hard to say without knowing more details, but something to keep in mind.
Cutter/Climber
Can you use sub-contractors? I ask because that is what I do. I have a guy that I work for a few days a week cutting for him. I carry my own ins. just like when I had equipment and cut and skid. Now I just cut for a guy. I have made anywhere from $18 to $22.50 per hour. I supply my own saws and gas.
BargeMonkey
Quote from: Leo Lancer 5738 on February 14, 2016, 02:07:55 PM
Let's split the 370K, I do the actual job with my own insurance in 2wks time with a buncher and you have quite the pile of firewood to pick up.  :D.
BargeMonkey
Quote from: Cutter/Climber on February 15, 2016, 02:40:52 PM
If you where closer I know someone right now desperate for an experienced cutter a couple days a week.
Cutter/Climber
[/quote]
I don't know if that would be a good thing or not. I don't know how I compare to other peoples rates. The only reason that I don't work more for that guys is that I try to do my contract climbing the other days of the week. Make much more money doing that.
Corley5
  Something you need to keep in mind is that hand falling bug killed ash is very dangerous.  The tops are extremely brittle and create an extreme hazard when they're on their way down.  These trees if they're dead now are losing value every day and the harvest should be completed as quickly as possible.  Three years out.....
BargeMonkey
Quote from: Corley5 on February 15, 2016, 06:22:49 PM
I bet you've heard the sound of limbs bouncing off your cab too.  :D
