Blackgum Behavior
Started by chickenchaser, February 13, 2016, 07:23:39 PM
chickenchaser
I started this as a reply to Hackberry Jake's thread in another section of the Forum, but opted for a new topic here...
I have a few blackgum logs - nice looking...straight and uniform. I was getting anxious to put toothed steel into them. Now, after reading some posts concerning said species, I'm not as optimistic for great lumber.
One of the logs has no bark left - none whatsoever. It came out of a bamboo thicket and has been down probably 5-6 years. I actually was hoping for cherry or white oak at the start, but decided it was red oak until I cut the butt end off. Also, I was surprised at the weight and soundness of the log.
The other logs were from a storm damaged blackgum I finally was able to take down back in November. It was less than 50' from the "barkless" log so I have eliminated most other possibilities and am 90% sure the mystery log is blackgum. All are under 16" diameter.
Can anyone tell me what to expect from the logs (lumber) when sawed?
Should old log behave any better than newer ones?
Nothing critical here. It can always be firewood. I just had - maybe unrealistic expectations.  :D
CC
WoodMizer LT35HD
JD 3720 w/loader. 1983 Chevrolet C30 dump. 1973 Ford F600 w/stickloader. 35,000 chickens.
Den-Den
Black gum is great wood for carving.  As lumber it will usually tend to be bland in color and grain pattern and prone to warping as it dries.  It is extremely difficult to split for firewood.  You already have the logs, not much to lose by sawing them.  I would suggest cutting somewhat thick so that some warp can be planed out.  Watch out for decay in the older logs.
YoungStump
 You don't really have anything to lose by sawing it but I would consider it to be one of the ugliest woods I've cut, like den den said very bland and at least in the ones I cut you normally get very little clear lumber before your boards are covered in black knots, many of them partially rotten.
Echo Enterprises 45HD2 production series band mill, Cook's Edger, sawing mostly pallet cants, rr ties, and grade lumber.
drobertson
  trailer decking of heavy thicknesses,  keeping from twisting seems to be an issue during drying,, just checked google after remembering some folks do use it for flooring and some of it is veneered and used with laminate,, so, if you have them you can do some research and or experimentation, best knowledge is what comes from first hand experience.
Images looked good to me,, and I know for fact its a durable wood surface from the trailer deck I've sawn, albeit sweet gum rather than black,, not real sure of the difference with these, but figure gum is gum,, so, go for it after you figure how to,,
It has spiral grain.  Flatsawn, it will almost certainly twist and warp, especially the first few boards off each of the four faces of the log.
POSTON WIDEHEAD
I saw a lot of Gum. Money wise, I get the most bucks out of a log by milling a log into a bench.
9 inches thick x 13 inches wide x 10 foot long with the top 2 edges beveled.
The legs are 2 Gum blocks 9 inches tall giving me an 18 inch high bench.
I get $200 for these benches.
No twisting or bad behavior at all.
Not a bad return on Gum.
YellowHammer
I've sawn a decent amount, it's very strong, and I use it for things that get banged up, such as my wood racks, farm lumber, and even my log deck.  I have customers ask for it as boards, and when I get enough requests I'll saw up a bunch of it, dry it, sell the half of the load that turns into potato chips for low cost project wood or make it into pallets, and take the half load that turned out OK and sell it at poplar prices.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
dustyhat
Trailer decking , gives me a good idea sense i got gum and a trailer needing floored. how would it act bolting it in green?
YellowHammer
Quote from: dustyhat on February 13, 2016, 11:17:53 PM
As long as the trailer frame is stronger than the boards you are bolting in, it should work great. ;D  The black gum cross ties I've been using for my log deck have been laying on the ground for about three years, and they are still tough as nails.  No bugs, or significant rot yet.  The logs drop on them and bounce, and I've only run over them with my tractor about a hundred times.  They remind me of hard, heavy, tough rubber.
YellowHammerisms:
terrifictimbersllc
Quote from: POSTONLT40HD on February 13, 2016, 10:28:10 PM
Pics?  I've been sawing out similar for another sawmill.  Love to see.
POSTON WIDEHEAD
Quote from: terrifictimbersllc on February 14, 2016, 10:14:37 AM
chickenchaser
Quote from: Den-Den on February 13, 2016, 07:40:31 PM
Sorry to be a bit "under informed" here. When you say carving, does that also mean it would be good or acceptable for turning? Especially for a prospective beginner?
WoodMizer LT35HD
terrifictimbersllc
Quote from: POSTONLT40HD on February 14, 2016, 02:40:13 PM
Very nice, thank you.
chickenchaser
WoodMizer LT35HD
Black/Tupelo Gum was/is the choice species for making dough bowls.
chickenchaser
Thanks, Magicman.
I was shopping for a short cant hook at our local flea market couple weeks ago and looked at a dough bowl (oblong) dated by previous owners - supposedly.
1907...1930something and 1967. One of the topics was wood composition and I was trying to remember if he said blackgum. It was noticeably thinner (lighter) than the one my wife uses. He was asking $125. I didn't figure she needed two.  ;)
CC
WoodMizer LT35HD
Dan_Shade
Magicman, was that a flatsawn board left to its own devices?
lots of dull bands and chains
landscraper
How soon in the air drying of black gum would one know whether there was going to be trouble with the lumber warping?
Firewood is energy independence on a personal scale.
POSTON WIDEHEAD
Quote from: landscraper on February 15, 2016, 04:10:58 PM
Get you a moisture meter. I like to get mine air dried down to 9%....Thats about as low as I can get it outside.
Then you can take the wood into your temperature controlled shop or even in the house and the MC will drop even more. I have worked with wood around 9% but like better around 4 or 5 if I can get it.
Alligator
Quote from: Magicman on February 15, 2016, 08:41:59 AM
MM do you see Black and Tupelo Gum as the same spices? They are real hard to tell apart.
Esterer Sash Gang is a  Money Machine
landscraper
Poston - Thanks, I'll check with my meter.  It's been stickered 2+ months and no warping yet, but with the winter weather it's probably not drying much at all yet.  It has been very windy this winter though, so maybe a little bit.
Checked it with my cheapy pin meter - 16-20%.  We shall see.
POSTON WIDEHEAD
Lynn, was this a family hand me down?
Quote from: Dan_Shade on February 15, 2016, 03:54:29 PMMagicman, was that a flatsawn board left to its own devices?
It was carved out, but I like your response/description better.   :)
Quote from: Alligator on February 15, 2016, 05:22:16 PMMM do you see Black and Tupelo Gum as the same spices?
I am not a "tree-ologest", but to me they are cousins and their wood use is interchangeable.
Water Tupelo (tupelogum, sourwood) scientific = Nyssa aquatica.
Black Gum (black tupelo, sour gum, pepperidge) scientific = Nyssa sylvatica Marsh.
Swamp Tupelo (swamp blackgum, blackgum) scientific = Nyssa sylvatica bilflora
Quote from: POSTONLT40HD on February 15, 2016, 05:45:14 PMLynn, was this a family hand me down?
Yes, from my Mom.  Before that, I have no idea.   ???
elk42
Lynn do you know if they are carved green or dry. My mother had one that was about two' long and it came from her mother and I don't know the age of it. My dad said it was black gum. Also as  young boys we would make toy log  wagons and make the
wheels of black gum.
Machinist Retired, Lt15 WM 25 HP, Stihl 044, Stihl 311, Kubota M2900w/FEL, KUBOTA L4800 w/FEL,
Lincoln Ranger 10,000, stihl 034,
Alligator
Quote from: Magicman on February 15, 2016, 05:49:33 PM
The reason I ask, I spent about 6 years scaling / trying to separate Black Gum from Tupelo Gum. We had a log swap deal with a plywood / door manufacturer. They wanted only Tupelo Gum in 12-14-16 ft. lengths. We swapped even for Cypress which they had no use for. They used the Tupelo for the face of the doors. Almost every load they would send 1 to 5 logs back, said it was Black Gum. Close to the end I figured it out pretty good, but still sent a "Black Gum" every now and then. We were happy to get rid of the Gum of any kind. As discussed it was hard to keep on the sticks, with lot of loss. I never got to see any leaves, on the yard, just ends and bark. Tupelo most of the time has a greenish 1" to 2" pith on the butt cut, but sometimes not. We thought Cypress for Gum was a good deal any way you slice it. :)
Den-Den
Quote from: chickenchaser on February 15, 2016, 07:03:17 AM
It turns very nicely, excellent for a beginning turner.  It is also nice wood for enhancements like carving, pyro  or dye.
chickenchaser
Thanks, Den.
Sounds like I have quite a few options after all.
Thanks, everyone.
WoodMizer LT35HD
Quote from: elk42 on February 15, 2016, 06:53:45 PMLynn do you know if they are carved green or dry.
I have no idea.   ???
PC-Urban-Sawyer
Quote from: Magicman on February 15, 2016, 08:38:26 PM
I have no idea.   ???
You might want to ask user @woodbowl
Herb
Herb, the @ notifier had to be disabled.   :-\
PC-Urban-Sawyer
Thanks MM, I missed that.
Maybe woodbowl will happen to read this and give us his expert opinion.
Herb
The dough bowl that woodbowl made for me is pecan  smiley_devil.
Carvers prefer the wood from the butt swell of the water tupelo.
