homemade mill and autofeed
Started by revid, February 13, 2016, 09:31:49 AM
Kbeitz
I would say yes you can do it with that switch...
Love machine shop work
and Wood work shop work
And now a saw mill work
revid
thanks KB.Ok, I Still need that 2 dpt switch in that drawing? I can't find a dpt switch,did you mean spst,spdt,dpst,dpdt,etc? I have those relays like in your drawing,awaiting bases
revid
does anyone know what kind of switch is in the drawing in reply#278? The one 2 PDT going to limit switches.I cant find a switch called that
Ga Mtn Man
DPDT (double-pole double-throw)
Kbeitz
It's a toggle switch with 6 pins on the back.
The toggle will have 3 positions. Up, down
and middle.
Kwill
Kbeitz i read all 16 pages of this thread and got a couple questions. I watched this video on you tube https://www.youtube.com/watch?v=qCjdSc-nLEg I see that the guy who done this video didnt have all the relays and timers and stuff like you have. Looks like he just has the controller and the travel limit switches. My question is if i used a 12 volt tarp motor as you have suggested in other threads would i need all the relays and timers? I just want a simple adjustable speed forward and reverse setup. I had considered going with a hydraulic setup but am interested in the 12v setup. Im like the original poster and not a electrical savy as yourself.
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
Kbeitz
Nope you dont need all that stuff if you find a toggle or drum switch
that can handle the amps of your motors. They will be BIG. My contacts
are rated way more than a normal toggle switch.
sawwood
Kbeitz in your last post you show a simple set up to drive a motor. I have a few question about adding a drive motor to our mill.
Fist can I use a 12 volts motor to drive the saw head, and what size speed control would you buy to control the speed ? Also
I see you need a drum switch to match the amps of the motor. Would it be best to use a second battery for the motor or can
I use the mill battery ?  I would like to make this a simple as possible and use a chain to drive the saw head. Will need to find
the correct sprocket to get the speed and power. are there gear motor on ebay better then just a motor ?
Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Kwill
Quote from: Kbeitz on April 06, 2017, 04:12:48 PM
Ok that looks simple enough. thanks
Kbeitz
Quote from: sawwood on April 06, 2017, 08:25:20 PM
Sawwood
12 volt stuff works fine. It's harder to find than the 24 volt stuff and you will
need heaver wires and switches for the 12 volts stuff. You wont know what
speed control you will need until you buy your motor. You will need a gearbox
motor or a whole lot of chain and sprockets to get the speed down. You'r mill
battery will work if your engines charging system can keep up. The drum switch
needs to match the amps of the motor if you'r not using contactors or relays.
You also wont know what sprockets you will need until you buy you'r gearbox.
They all come with different ratios. I like using 24v wheelchair motors because
they have low amp draw and they are geared to a very good ratio to match
what we are doing. It's hard to find them in 12 volts. 24v Wheelchair motors are
also continuous duty. Most 12 motors are not. E-bay has 12 volt tarp motors
but then again they are not continuous duty. I don't know how important this
might be but you don't want your motor to get hot from running all the time.
Kwill
Kbeitz what do you think about this motor for raising and lowering the saw head?
   it's a 5th wheel jack motor. Got it with a box of stuff ato a auction a few years ago. Been setting in my shop every since.
Kbeitz
I bet that would work good for raising and lowering because you don't use it
all the time. But any of the brush starter type motors like that has a short
life span.
Kwill
Yeah it was just a thought. Have it laying here doing nothing so I thought I would put it to good use. :laugh:
Kbeitz
Quote from: Kwill on April 07, 2017, 11:54:31 AM
If you ever do have a motor problem with it you can use garden tractor
starters parts to repair it. Tons of them at most junkyards.
Kwill
Quote from: Kbeitz on April 07, 2017, 12:06:31 PM
starters parts to repair it. Tons of then at most junkyards.
I got a few of those starters laying around to.
Kwill
Any ideas on what I might use to connect to this
Ga Mtn Man
Hey Kwill, how about putting a space between your pics and text.  Sure makes it a lot easier to read. :)
Ljohnsaw
Kwill,
You will need a shaft that will fit inside (or outside) that fitting.  Then put a spring pin across it to engage the slot.
John Sawicky
revid
Well finally got a chance to get bk at my mill. Kbeitz, in post #278 you posted a wiring diagram for me and I thank you for it. Got to ask another favour , can you post how to wire witthout those 2 PDT switches in that diagram? I just have a drum switch, controller with pot to adjust speed and  2 relays . Thanks
Ga Mtn Man
revid-  What is the current rating of your drum switch and how much current (max) will your motor draw?  You may not need the relays at all.
revid
30 amp drum switch and have a wheelchair motor. Relays to protect controller board I thought . Already burnt one up when I slow down travel
Kbeitz
There is a chance that when you slowed down that the motor generated
power back to the control board.
I can't draw a diagram without the schematics of your drum switch.
revid
Reply # 299 back on this topic and thanks
Kbeitz
revid
Thanks KB but I needed diagram with those two relays in there also.
