Pine cookies
Started by kelLOGg, February 08, 2016, 01:12:23 PM
kelLOGg
I cut a cookie off of a pine stump with the mill 14 months ago in hopes of making an end table if it didn't crack. I put it in the first floor of the barn in a corner where it didn't get much air flow for a year then on the 2nd floor for the past 2 months. It did get a little green mold on it which sanded off very nicely and sustained only very fine cracks which don't even show up in the pic. So far I am very pleased. I know it needs more drying; it is 3" thick and 20" dia. Any advice on continuing the drying?
The next effort is 6 more pine cookies. I cut them from a different stump which caught my attention because of the density of growth rings. The tree was only ~18" dia at the butt but was about 200 years old. Here's a pic of one taken of the pith to the bark. There are unfortunate holes around the pith which looks like wood was pulled put when it was felled. All six of the cookies show these holes ???.
I am planning on drying them as I did the first one. Any advice on these to prevent cracking? They range in thickness from 2.3" to 3".
Here's all seven.
Deese
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
Ljohnsaw
The bark looks like Ponderosa Pines out here.  Hate to say it, but I think you will get cracks :-\  You just can't cheat physics.  The other 6 cookies, how long have they been cut?  Is the pullout you noted on both sides of the cookies?  You could always fill with an appropriate colored epoxy.
Good luck!
John Sawicky
QuoteAny advice on these to prevent cracking?
As John said, they will crack...  eventually.
kelLOGg
Quote from: ljohnsaw on February 08, 2016, 03:26:09 PM
Good luck!
Not cracking in 14 months gave me hope but...  >:( I'll try not to expect too much from them.
The 6 cookies were cut yesterday and the pullout goes through both sides of all of them. Apparently when they cut it the falling trunk pulled the two strips through 18 inches of stump. I wasn't there when it was felled but it was a real butcher job judging from the top of the stump. It looked like someone used a chainsaw as an axe.
Deese
Polyurethane? I've done a few cedar cookies like that. Sanded them down really smooth and brushed poly on it.
A friend of mine did a huge osage orange cookie tabletop like that. I'll try to find the picture.
Cooks AE4P Edger
Deese
Here is a big Osage Orange cookie that I cut for a friend.
And here it is after he sanded it down and coated it with Polyurethane. Not sure why the color is different. I took the above picture and he texted me the pic below. But regardless, it turned out real nice  ;D
Cooks AE4P Edger
OlJarhead
One thing I've done with cracked pine cookies is to fill the cracks with epoxy resin.  Seems to work very well and once coated with Parks Super glaze they look great.
You'll have to 'dam' up the sides and underneath when filling so the resin fills the crack but once done it leaves a nice finish.
kelLOGg
Quote from: Deese on February 08, 2016, 05:30:15 PM
It surely did turn out nice! Did he fill the cracks with contrasting epoxy? It sure is dramatic, esp. the ring pattern.
Bob
kelLOGg
Does anyone have ideas for legs for cookie end tables? There used to be a sponsor to the left. I'm thinking of some sort of steel legs I could make or buy.
Go to sponsor logRite and look at their legs section.
http://www.logrite.com/store/Category/legs
tule peak timber
  Some recent cookie leg designs. Another batch coming out of the oven tomorrow (pics ) The sky is the limit on leg design . Rob
OlJarhead
First one I did -- made the mistake of using Elmers wood glue before switching to epoxy but it worked out
Love the Parks Super Glaze
My latest -- not finished yet but almost.  Those are coins from my second hitch and I always wanted to do something like this with them.
Oh and this was an old chopping block I 'repurposed' lol
kelLOGg
Wow! I asked and did I ever get some answers. Thanks. Old jar. if my pine cookies turn out like yours I'll be very pleased. What was your drying conditions?
OlJarhead
Quote from: kelLOGg on February 08, 2016, 09:12:01 PM
I had them in a garage in central WA.  No air moving, no heat or AC....can't remember how long I left them sit but I'm guessing 2 months or so.
I'll find a pic of the cookies after cutting them...pretty rough since they were old and already rotting LOL
OlJarhead
Before I used epoxy I made the mistake of using wood glue.  I don't recommend it!  Why not?  It dries a yellow color!  DOH  :o
After sanding off the wood glue as best I could I shifted to epoxy and am happy I did!
You can see just how rough this cookie was!  LOL
But it made this:
69bronco
Rob, you are the official Cookie Monster!!
kelLOGg
kelLOGg
Quote
Central WA is desert-like, right?  If so, that would make them dry fast.
Bob
OlJarhead
Yes.  Thought it was in the fall and damp out.  This was an old chopping block that I decided to try to utilize this way so it was old and dry to start with too.
Deese
Quote from: kelLOGg on February 08, 2016, 07:39:02 PM
Bob
I'm not sure what he did. I think he just slapped on a bunch of polyurethane. Makes me wish I would have kept a piece for myself.
Cooks AE4P Edger
cbla
OlJarhead, what brand of epoxy resin did u use?
OlJarhead
Quote from: cbla on February 10, 2016, 11:09:39 AM
I believe it was loctite but I'd have to check.
