Interesting winter wheel chains
Started by ~smokey~, February 08, 2016, 03:55:10 AM
~smokey~
Never seen anything like these, I would imagine under certain circumstances they would come in pretty handy.
https://youtu.be/IPd3O5_SJEs
snowstorm
there are a few fire trucks and oil trucks with them. the trouble with them is they only work if the truck is moving
Ocklawahaboy
Looks like if they were not lined up just right they would beat your side walls to death.  It is interesting to see what y'all put yourselves through up there though.
Skip
All the school buses here have them,.
coxy
if your going to slow they don't work they just hit the in side of the tire  I think they are the worst thing they ever invented it makes SOME people think they can go any place
yukon cornelius
We had them on all fire trucks and ambulances. Ours got stuck either up or or down often.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
bill m
The "Onspot" brand seam to be the most popular in this area. Just about every Oil, Propane, Ambulance and firetruck have them.
JJ
I've seen them in action on school bus and oil trucks; they do work.  All emergency trucks and ambulances have them in in this area as well.
since spun by tire rotation, I do not see how they could damage sidewalls, but do no good if not moving.
       JJ
kensfarm
Ljohnsaw
Quote from: JJ on February 08, 2016, 10:41:43 PM
       JJ
Take a look again at the video around 1:20 - the tires were spinning and then deployed the roto-grip and off they go.  That is a really neat invention!
John Sawicky
starmac
They work, sort of. Quite a few truckers installed them, some because they had the fancy fenders and couldn't chain up, others because you can legally run without chaining up when the chain law is up, but if ou need chains, they do not cut it. lol
hamish
Quote from: snowstorm on February 08, 2016, 06:43:34 AM
Well that's kind of the whole point of any tire chain system...............to get moving.................
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
~smokey~
Even if the vehicle isn't moving I'm guessing if you get the wheels spinning it would engage the chains, I wonder if they make a cable version of these, they would do less damage to the roads and you wouldn't have the same flailing action of the chains.
Ljohnsaw
So I was coming back down the hill from my property (no snow on the roads) and there was a CDF (California Department of Fire) truck (a brush fire truck) and low and behold, there was a handful of short chains hanging down by each back tire.  Guess they use them out here, too.  I'll have to stop in and talk with some of the guys to see how they work in our snow.
John Sawicky
Peter Drouin
I wonder how long they last in the salt. :D :D
A&P saw Mill LLC.
License NH softwood grader.
