Most unique foreign object.
Started by Clevelander, February 05, 2016, 04:41:45 PM
Clevelander
Just curious: What is the most unique, unusual, or unexpected item you have ever found inside a tree you were milling?
Live your truth and your truth will find you
sawmilljoe
12 inch length of chain must have been put on a branch and in time it grew over . What a bang that was took every tooth off the band.
kelLOGg
terrifictimbersllc
1/2" twist drill bit in a pine log, hit with chain slabber.  :o
http://www.sheltonherald.com/16885/16885/
Also a mouse.  ::)
A while back there was a thread on things found in logs when sawing.. maybe someone recalls and can find the right words for a search of the archives.
POSTON WIDEHEAD
All objects are a pain if you hit them with a blade.
The object I guess I hate the worse are Eye Hooks.  >:(
Deese
When I was 5 or 6 (don't really know when), I stuck a truck remote control in the fork of a magnolia tree and couldn't get it out. The tree has grown around it and now you can still see the tip of the antenna sticking out. That was a good 25 years ago. Pretty cool.
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
By doing a forum search, using tramp metal or the like, you will find a many numerous topics about the same thing.
terrifictimbersllc
Nomad
     Lots of things are really bad to hit.  But the strangest thing I ever cut was a garden hose wrapped around the tree and grown in.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Quote from: nomad on February 05, 2016, 06:28:18 PM
Self Watering Tree
Nomad
Quote from: Jeff on February 05, 2016, 06:35:55 PM
Self Watering Tree
     Okay.  You got me beat! :D
Lucas DSM23-19
fishfighter
Quote from: POSTONLT40HD on February 05, 2016, 05:46:27 PM
like this?
Add a couple nails don't help. >:(
fishfighter
Quote from: Deese on February 05, 2016, 05:50:52 PM
Lost a bottle of home brew in the fork of a cypress tree one night coon hunting. That was over 30 years ago. If only I could find it. Was with two cousins that night and both passed away. Been back many times and could never find it. :'(
I suspect a cousin probably already had. :)
Joe Hillmann
A frozen raccoon.  But that was found with a chainsaw not the mill.
Does snakes, frogs, and flying squirrels count?   ???
tule peak timber
  Don't know if this counts, but a snake in the mill ?  Rob
ncsawyer
The hardest thing I ever tried to cut was a porcelain fence insulator in the middle of a white oak tree.  Saw blade smoked like crazy when it hit the insulator and didn't even scratch the insulator.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
Ron Wenrich
Ball peen hammer head and railroad spike used by hunters to climb trees are the ones I've had near misses with.  I've also seen horseshoes, and a bicycle wheel in trees (used for a wash line).  The most unusual I've heard about was an unexploded shell in a log from a military base.  It did explode when hit.  No one hurt.
Ox
I've only found lead so far.  But a local guy told me years ago he found a cannon ball in a tree once.  It stopped the saw and broke the blade, of course.  It was an LT70 Super and he saws like crazy when he's in it.
Chuck White
Telephone company "J" hooks.
During the '98 Ice Storm the phone company apparently installed numerous J-Hooks on trees as a temporaty measure until the ice cleared.
Most that I've found would have been 15-16' above the ground as installed.
terrifictimbersllc
Quote from: ncsawyer on February 05, 2016, 09:56:51 PM
Yep, second time in 13 years, last week. This time I sawed in a half inch.   4 degree blade lives up to its reputation & maybe I got better at sharpening.
A T fence post driven into the log sideways and broken off below the bark.  It was ~43' up the tree from the butt.
The customer gave it to me as a souvenir.
