I am breaking bandsaw blades.
Started by Deese, February 05, 2016, 03:58:11 PM
Deese
Friends, I have a slight problem and need your help.
I am breaking bandsaw blades. I ordered a new box of blades and have broken 2 blades out of 5 thus far. Surely it's something to do with my mill and not the blades. I have only been cutting really soft wood. Bald Cypress. If I'm lucky I will get 300bf from a new blade and then I'm afraid it's going to break, so I change the blade. If I keep sawing without changing, I will begin to feel a somewhat "pulsing" vibration from the mill and can hear it too. It's really more of a sound than a feeling...Hmm, not sure how to explain it. Anyways, it's a distinct sound and feeling that only the operator would notice.
I know that I am guilty of one thing, and that is not FULLY extending the adjustable blade guide up next to the cant while sawing. If I extend the blade guide out too far, it comes into contact with the blade in a way that causes it to dive every time (I need to adjust the guide). The problem is that the bar holding the guide has a lot of "play" in it whenever you extend or retract it. You simply slide the bar in or out, then tighten it with a screw to secure it. So, I pretty much leave it in the same position unless I need to retract it for larger cants. In other words, I generally keep it in this "sweet spot" while sawing and have never had much trouble... The guide, on average, was about 8"-1 foot away from the cant when sawing. So, the lack of support on the back of the blade could be causing the premature breakage, right?
I previously had an issue with the mill throwing the blade (even when not using diesel for lube). I noticed that the blade was riding too far on the front of the belted free-spinning wheel. So, I adjusted the wheel so that more surface area of the band was in contact with the belt, but not so much that it would remove the set from the teeth.
One other thing...Could I be applying too much tension on the blade? I tighten it down pretty good, but I seriously doubt this is the cause...I need to call EZ and ask about proper blade tension on this mill. I just tighten it down and start sawing.
A. Not fully extending the adjustable blade guide?
B. Mill not aligned properly?
C. Too much blade tension?
Maybe all or some of the above?
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
sandsawmill14
look at the blades good and see if it is in the weld first thing :)
YellowHammer
Typically the pulsing you feel is when a crack has started in the band and its going around contacting the rollers or the wood; you can feel and hear it.  That's the sound of a band dying, it's just a matter of time.
Quote from: sandsawmill14 on February 05, 2016, 04:07:41 PM
It's important to do a careful inspection and see where the crack is starting, such as the weld, the gullet, or the back of the band.  Each one will mean a different failure scenario.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Deese
Quote from: YellowHammer on February 05, 2016, 04:13:41 PM
It's important to do a carful inspection and see where the crack is starting, such as the weld, the gullet, or the back of the band.  Each one will mean a different failure scenario.
Thanks fellas. I remember looking at the first one and it was in the gullet. BUT I will inspect both of them when I get home from work.
Cooks AE4P Edger
Deese
I will not be a happy camper if they are faulty blades.
Cooks AE4P Edger
I would rather it be faulty blades if it were me, because then, you know your mill is alright, and you can usually get replacements if it is clearly faulty blades. Odds are though, it's not.
Deese
I feel that it is something on my end.
Cooks AE4P Edger
Deese
QuoteIt's important to do a carful inspection and see where the crack is starting, such as the weld, the gullet, or the back of the band.  Each one will mean a different failure scenario.
YH-- I overlooked this statement earlier. Yes sir I will be sure to remove the band immediately the next time I hear/feel that familiar vibration and hopefully we can figure this thing out. I finished sawing my small whack of logs yesterday and it will probably be a week before more are delivered.
Cooks AE4P Edger
kelLOGg
When my breakage rate went up I lessened the tension to the point of onset of flutter and the break rate dropped significantly. (I learned that on the FF)
Bob
Deese
Quote from: kelLOGg on February 05, 2016, 05:09:18 PM
Bob
Thank you sir for the comment. I am thinking (hoping) that my issue is simply something I am doing incorrectly. I do feel that I am putting too much tension on the band. I mean, I REALLY tighten that sucker down. Plus, the full body of the band wasn't riding on the belt...just the back of the band. That much tension on such a small portion of the body of the band, plus the lack of support from the adjustable blade guide are probably all contributing factors...I may be totally wrong but at least it sounds good  :D ;D  But I really don't know smiley_confused smiley_whacko
Cooks AE4P Edger
Wayniac
dont rule out bad blades i got one order of blades that was so brittle i guess thats what you call it that the teeth broke off when trying to put a set in them didnt have much luck sawing with them but didnt figure i could ever prove it were do you get your blades from
wayniac
sandsawmill14
i had 2 blades break in the weld this week its not all that uncommon but they will make good on them with no questions ask. i will get 15-20 a year that break in the weld but that is not bad for as many blades as i buy :)
Dave Shepard
That sounds strange to me. I've never had one break in the weld.
sandsawmill14
i use the woodmizer silvertip 1 1/4 .042 blades and i am on autoship with mill supply so i get 10 every week i started that last march i think it was  ???  so that 15-20 blades that broke in the weld is out of somewhere between 350-400 blades so its still a small percentage :)  i can go back and check records to get an exact number if anyone thinks its needed :)
dgdrls
Quote from: Deese on February 05, 2016, 05:38:28 PM
Bob
There is no reason to "..REALLY tighten that sucker down"
http://www.cookssaw.com/index.php/sawmill-blade-insight/troubleshooting-blade-breakage
really good info here,
Dan
Quote from: Deese on February 05, 2016, 03:58:11 PMIf I extend the blade guide out too far, it comes into contact with the blade in a way that causes it to dive every time (I need to adjust the guide). The problem is that the bar holding the guide has a lot of "play" in it whenever you extend or retract it. You simply slide the bar in or out, then tighten it with a screw to secure it. So, I pretty much leave it in the same position unless I need to retract it for larger cants. In other words, I generally keep it in this "sweet spot" while sawing and have never had much trouble... The guide, on average, was about 8"-1 foot away from the cant when sawing. So, the lack of support on the back of the blade could be causing the premature breakage, right?
I am not following this completely, but you have some blade guide issues that need correcting.
pine
I have had several welds break lately as well.  Not sure what is going on for that to happen.
losttheplot
Check the gap between the back of the blade and the guide roller flange is to spec.
DON'T BELIEVE EVERYTHING YOU THINK !
ladylake
  Yes the gap between the back of the blade and flange is real important, if my mill get out of adjustment and it gets close blades start breaking fast, I run mine 1/4" back as Cooks recommends with real good results. From your post it sound like you might have it to close, check it with the movable guide all the way and all the way in and make sure it about 1/4"  back. The next big blade breaker is worn v belts, if the blade touches the metal on the wheel they will break fast also. In all of these years I've had at the most 5 blades freak in the weld.  If everything checks out you could just have a bad batch of blades.  Steve
terrifictimbersllc
The roller needs to be tilted slightly, horizontally, so that if the back of the blade contacts the flange, it does so on the side of the roller that is spinning up, not the side of the roller that is spinning down.   Correctly tilted, the blade is pushed against the roller if it contacts the flange, incorrectly tilted, it is pushed away from the roller as it contacts the flange.
Your blade guide arm needs to be adjusted in its mounts so that 1) it does not move except in or out as it is supposed to and 2) so that as it moves in or out, the same spacing (which on my LT40 super 2001 is 1/8") is maintained.
I don't know what's in your manual, but in my manual all the instructions are there to align the mill properly.
Deese
Thanks fellas for all of the tips. Based on what you guys have said, I believe I have discovered the problem without even going to look. I will try to take some photos sometime over the weekend to help illustrate my delimma. Basically it's a blade guide issue with the stationary roller guide. The problem is this guide is already adjusted as far back as it can go, but needs to go back a little farther. To be continued. ..Again, the advice is greatly appreciated
Cooks AE4P Edger
Kbeitz
One more thing to check. Your band saw wheels or tires could be out of round causing the pulsing.
That would put a lot of tension on your blade.
Love machine shop work
and Wood work shop work
And now a saw mill work
Chuck White
Quote from: ladylake on February 06, 2016, 09:02:11 AM
I absolutely agree with Steve.
If your blade belts are worn to the point where the blade touches the wheel, the blades won't last very long.
If this is the case, you should be able to see shiny contact marks on the blades!
Nomad
Quote from: Deese on February 06, 2016, 10:15:39 AM
     From what you're saying , are you sure your blades are tracking properly on the wheels?  If tracking too far back, it could cause this.  Another option is that something is bent.  Just guessing here.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
customsawyer
I agree with Nomad. I think when you adjusted your tracking on the one wheel it moved the blade back against the flange of the blade guide.
www.thecustomsawyer.com
