jonsered 2166
Started by coxy, February 03, 2016, 09:05:38 AM
coxy
i have  an issue with it flooding  it will idle all day as soon as you pick it up it floods out same thing when your cutting with it it will run fine then you twist it side ways and hit the throttle it will flood and quit then you pull your guts out to start it back up i put a different carb on it it helped it some but as soon as the saw gets hot maybe after a half a tank of gas it starts the same thing but not as bad  this has done this since the saw was new and the deal tried to fix it and couldn't if i take it some place else they tell me 4-8 weeks to fix it cause i didn't buy it from them  any help would be great
lumberjack48
  Check the gas cap, sounds like a fuel pressure issue
coxy
LJ48 some one else told me that too but it would have to be the vent in the tank and was also told that you cant change the vents any more you have to buy the hole tank/handle assembly at 110 bucks  :-\ :-\
old2stroke
Have you confirmed it's flooding by pulling the plug and seeing that it is too wet to fire?  The problem sounds like vapor lock because of the fuel tank or carb getting too hot, but that would cause the saw to quit because of lack of fuel instead of flooding because of too much fuel.  Maybe someone will join in with more experience with this particular saw.  If pressure is building up in the fuel tank, changing the tank vent will have no effect as it is a one way valve that lets air into the tank, not the other way around, and besides that, the tank pressure would have to get pretty high before it would exceed the "pop off" pressure needed to unseat the carb inlet valve and cause flooding.
Not too many saws.  Not enough storage space.
coxy
the reason I say flooding is after it quits you have to hold the throttle wide open to start it it will take a few times of this and then will run and smoke like crazy till it cleans its self out
weimedog
Wonder if you are sucking bar oil in from somewhere. Maybe leaking case gasket? Maybe under the oil pump/clutch side seal or screw hole for those two screws that hole the bar oil pump?
It could be carburetor related...an easy test for a shop is to simply swap one out. Cost of a spare carb or one from a dead saw is peanuts vs. screwing around with a lot of the other things folks do with carbs!
And when was the saw built? Always wonder about clutch side issues related to bearings and seals in the earlier versions.
If you were closer I would take a look but it is very hard to debug over a phone or on the internet and I won't deal through mail or shipping either.
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
49er
My 365xt never had a consistent idle. It would idle down after a long cut (till it would almost die) and then gain rpm's after a few seconds (if it didn't die). I eliminated the tank vent and eventually adjusted most of the idle problems out of it but it was never rock solid.
Monday I eliminated the strato dividers in the intake and it has never ran better. I was hesitant to do this but I am glad I did.
Husqvarna EC390 365xt
Jonsered 2188 2165 2260 2253 70e
Redmax GZ4000
old2stroke
Just trying to understand the problem.  Are you saying the saw runs and cuts properly until it gets hot, and then will still act normal as long as you are making vertical cuts, but as soon as you tip it on its side and make horizontal cuts it floods?  In other words, is the problem related to the position of the saw and only occurs when it gets hot?  There are only a few things that will cause a saw to flood and they are mainly a problem with the carb inlet valve not seating or the control lever for it being set too high, but when you tried a different carb and still had the same problem, it should have eliminated the carb.  When it floods and quits, will it restart when it is still hot, or does it have to cool off before it will start?  Any problem with the tank vent can be resolved by just opening and closing the tank cap every few minutes and seeing if the problem goes away.
coxy
it will start when hot but you pull your guts out to start it maybe 8-10 pulls it has to be wide open and it spits and sputters till its un flooded I took a carb of a good running saw just to check it helped it some but still does it 8-10 pulls not15-20 like it was if I cant figure it out tonight its going to be a track chuck for the dozer tomarrow  ;) >:( >:( 8) 8) 8)
old2stroke
This is a strange one, but here is my theory.  The oil tank is part of the crankcase body, and it is possible that the oil is being sucked/leaked into the crankcase and it is the oil that is fouling the plug, not fuel.  Would also account for the smoke.  There is a gasket that seals the two halves of the case and it is probably leaking or there is a hairline crack in the compartment wall between the tank and the crankcase.  High temperatures and any distortion forces from the bar would make it worse.  When the saw quits, pull the plug and see if it is wet with oil.
A crankcase pressure test would confirm this fault and I would do it by laying the saw on its side with the oil cap on top and the bar clamped down to a horizontal surface.  With the oil tank filled to the top and the cap off, start the pressure test while pushing the rear saw handle up and down to put some distorting force into the case/tank assembly and watch for air bubbles to show up in the oil tank.  The saw might have to be real hot before this test will show anything but its worth a try before tearing the saw apart.
RCBS
Quote from: old2stroke on February 05, 2016, 03:09:55 AM
Your theory sounds like a good one.  The saw needs a thorough pressure & vac test.
Echo CS-3400, 550xp, Jonsered 2166, L3130 Kubota, '78 JD 300 backhoe, Kubota RTV900, JD2305, lots of sharp stuff and several firearms
Spike60
Lordy me, some of these guesses.  ???  I know everybody's trying to help, but let's be careful to try and maintain FF's reputation as the forum where people really know what they are talking about.  :)
Tank vents have always been available as a separate part. There has never been a requirement to buy the entire tank. The tank vent IS a 2 way vent, and has been for about 10 years now, well before the change to the X-torq cylinder. If you have a hose connected to the vent, you have the 2 way deal. Either way, a tank vent problem would lead to fuel starvation, not flooding. But these new vents can act a little different than the old ones when they are not working correctly. Also, the tank casting will still accept the old 1 way vent set up. And you are not supposed to use a compressor to blow out tanks for cleaning that have the 2 way valve as you can damage the valve and actually introduce a vent issue that wasn't there.
The XT's are a bit fussy with the idle setting. The early ones were really bad. In fact there was a coil and carb change halfway through 2011 to address this. The coil change involved going to a digital advance vs the previous analog advance. At the same time, the carb was recalibrated to improve the idling characteristics. Not sure why, or how big a deal it is, but the new coil is only supposed to be used with the new carb. I've never actually paid much attention to this myself.  ;)
Quote from: coxy on February 04, 2016, 07:00:32 AM
Coxy, you are correct to ID this as a flooding issue. I have seen this a couple times myself. That carb is loading up at idle causing the flooding. I'd bet that if you picked it up and pointed the bar towards the ground it would stall without even hitting the trigger. Do you have the adjustment tool needed for these things? Try to set the lo speed just barely rich enough to provide good acceleration. If that doesn't do it, it might need a new carb. Some carbs are just bad and problems cannot always be adjusted or cleaned away. Idle speed should not exceed 3000; 2800 should be a target. The ignition advance is supposed to kick in at around 3400 and if you start bumping up against that, the saw hunts and surges and drives you nuts.
49er is correct that gutting the XT dividers out gets rid of most of this fussy idle problem. I did it myself following EHP's advice and I noticed it right away. But still, most saws aren't going to have this done, and it certainly should not be necessary in order to get a good steady idle.
Hope ya solve this before you feed it to the dozer!  :laugh:
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
49er
Quote from: Spike60 on February 05, 2016, 10:22:29 AM
Yea, I have a couple of saws that have been on the wrong end of a skidder. He could use them for a chalk. :laugh:
Redmax GZ4000
coxy
Spike60 the carb that I put on there was off my other saw that ran great  last night I put the (bad carb) on the other saw that ran great and no trouble so there has to be some thing in the body of the other saw that's not right so tonight ill rip it to pieces and see if I find anything that's not right ill just use it for parts that should solve my trouble   ill never buy another new 2166 thinking of going to dolmar heard a lot of good things about them I have a dolmar cutoff saw that's been good to me          thanks for all the help guys    coxy
49er
I drilled a hole in my tank vent and then put a screw in the rubber hose  to allow air in.
Stihl use to do this years ago. I thought this was my problem and it did seem to help idle some.
Redmax GZ4000
Spike60
Quote from: coxy on February 05, 2016, 01:45:11 PM
Problem is still fuel pooling up somewhere in the intake to cause that flooding. Could be boot related; distorted/not installed correctly. How far away are you?
Really, "never buy another one" isn't gonna get this saw fixed.
Husqvarna-Jonsered
845-657-6395
346xp
I mix mine 1qrt sae30hd to a gallon of the cheapest gas in can get
Spike60
Quote from: 346xp on February 07, 2016, 03:13:37 PM
Wow, that's great advice.  :o
I have a friend that thinks like that; "Smoking isn't bad for you 'cause I'm not dead yet."
Husqvarna-Jonsered
845-657-6395
XP_Slinger
To the OP...How goes the battle?  Did you get your saw running properly? Getting some closure on threads such as these is of great benefit to everyone here. :P
346XP/NE
357XP...ported by MeDremel
372XP/XT...ported by A. Burr
Homelite (Solo) 340
I'd rather be in the woods than on this computer.
coxy
never found out the real trouble i took it all a part the only thing i thought was wrong was the gasket that holds the 2 cases together was bad it looked like it had very very small pin hole leak and very little crud like it was baked on the in side of the crank case   not to shur about that being the trouble   but it is a parts saw now  i was also told today that one of the air ports on the jug may be bad  the o ring or it may have never been punched out all the way   remember this saw has done this from day 1 and no one could seem to fix it  ill take them off today
XP_Slinger
That's a shame that it's destined for the parts pile but thanks for following up.  Better luck next time. 8)
346XP/NE
Homelite (Solo) 340
weimedog
So why not build it ... New steel caged Nachi or NSK bearings and oem  seals. Seal up those transfer caps with 1184....would be a fun project. Cut the fins out of those transfer caps too. Do a no base gasket build....Can build it as an X-torq or as an older version.
coxy
why is the piston different as in longer in the 2166 than the 2171 and where the wrist pin is the 71 is closed and the 66 is open why did they do that     I also was looking at the crank seals on the saw that was flooding and there was a small nick in the crank seal would that have made it flood up
weimedog
2171 has the old style top end. All different from filter holder through the cylinder & piston than the 2166 x-torq. BUT you can put the old style top end & intake on the X-torq cases. You have a 2171 around for parts? And yes the 2166's piston and cylinder are both taller than the 2171's...again original version vs. x-torq
