best way to mill flooring on band sawmill
Started by Aeneas61, January 23, 2016, 10:29:08 PM
Aeneas61
Building a cabbing this year and wanted to start by milling the flooring and letting it air dry while we do the timber framing.
I would like to ask those with more experience the best way to mill flooring that will be later T&G for sub and finish floors in the cabin.
We have access to hickory, white oak, tulip poplar, hemlock, pine (red?), maple, beech, and tupelo.
Which woods would be best for flooring, sub and finish, and what would be the best way to mill them, (flat sawn, quarter sawn, whatever)
I have heard its better to use more narrow boards but had trouble cutting say a 12" board in half to make two 6" boards, they would warp apart badly, is there a better way to mill say 1x6 boards from a 12x12 can't or should i try making wide plank flooring?
What thickness is best for sub or finish flooring? What species?
We plan to start cutting soon, and hope to be able to air dry over the summer and instal in the fall. Would this be advisable or maybe too green still? Ive heard of folks putting down some flooring green as a gourd.
Any and all advise would be greatly appreciated.
Josh
Dan_Shade
I have made flooring, my best results were with boards sawn and dried a bit more than three times wider than finished product.
Step 1 was to plane to finished thickness
Step 2 was using a shaper and a feeder  with LONG  fences and a jointer cutter head to make a straight edge
Step three was to rip on a table saw  to width using a feeder
Step 4 was cutting the groove with the shaper and feeder
Step 5 was to cut the tongue
Keeping a good coat of wax on the tables helps
lots of dull bands and chains
paul case
I cut a lot of lumber and sell to an outfit that dries it and makes flooring. They want it plain sawn with no pith in it.  They will buy various width boards so I have no idea about the right width for you to cut, but it may be more depending on your desired result. I believe what the flooring outfit does is dries it and then cuts out what size they can around the defects that will make their product. They buy red and white oak and walnut to make flooring from.
Even though it is pretty I would shy away from hickory as the hickory I have dealt with is real real really hard when green and it don't get better as it dries.
PC
pc
starmac
I'm new at this, so my thinking may be flawed, but if I was wanting 1x6's out of a 12x12 cant, I would split the cant and then cut 1x6's instead of 1x12's then splitting them on a bandsaw.
Chuck White
fishfighter
What I been doing for my camp is cutting 1x12's for the sub flooring out of SYP. Putting them down green with ring shank nails. I have some 1" OSB that was laid down to start with. In between each, I had installed 30lb roofing felt. So far all is good. I do have some small gaps, but I will be over laying with 1/8" luan plywood. My finished flooring will be some 100+ year old pine flooring.
Oh, I been passing all sub flooring thru a planner to make sure all of them are the same thickness and I also had cut the edges at a 45 degree angle to help lock them in.
warren46
When I saw 6" lumber from a 12"X12" cant I first saw 2 or 3 1"X12" boards from one side.  Then turn the cant 180 degrees and saw 1"X12" boards from the other side until I have a 6" by 12" cant.  The side boards are sawn so that the pith is as nearly centered in the cant as possible.  These 12" boards are set aside to be sawn into 1"X6" boards after the 12"X6" cant is sawn into 1"X6" boards.
Note that the 12"X12" cant should be sawn oversize to allow for kerf or the 6" boards will be undersize.
Warren E. Johnson
Timber Harvester 36HTE25, John Deere 300b backhoe/loader.
customsawyer
If I was making flooring from a 12" cant I would probably make 1x4 out of the cant. You will have less movement this way. Warren's will work also.
www.thecustomsawyer.com
Quote from: starmac on January 24, 2016, 04:29:23 AM
Sorry, but flawed.  Never split the pith area.  Instead, always keep the pith area centered in the board regardless of the width.
For 6" flooring lumber take the cant down by removing side boards from each side of the cant.  If you have to split these side boards oversize them because they will tend to crook.  For maximum yield, I would prefer to use large logs for wide lumber and smaller logs for more narrow lumber and never split anything.
warren46 and customsawyer are spot on.
scsmith42
Ditto Jake and Warrens advice. Warrens method will more high grade wide boards; jakes will yield faster production of high quality narrow boards.
Tom's 3638D Baker band mill
Verticaltrx
In my opinion the nicest flooring from what you mentioned would be the white oak, quarter sawn. The narrower the boards the narrower the gaps will be. My house was built in the '20s and the flooring is 2" wide x 5/4 tongue and groove, laid directly on the floor joists (no subfloor). Every room has a different species, white oak, red oak, pine, maple, etc. The white oak is my favorite. I personally would never go over 6" wide for T&G flooring, probably 4-5" max would be better.
Wood-Mizer LT15G19
Aeneas61
magicman,
yes the only time I tried sawing 1x6s from a 12x12 can't i split the can't, rotated 90% and sawed 4/4 through the can't, every board cast so badly I just sawed and laid 1x12s for the remainder of my roof. I thought there must be something I was doing wrong, I guess that was splitting the pith.
verticaltrx,
what size white oak would be needed to get 1x2s quartered? Is there a better way to quarter saw than flipping each quarter for each cut?
Anyone have experience with laying green flooring? Or laying green sub flooring?
Aeneas61
magicman,
so how did the green sub flooring work out? any tips on its installation?
any advice on best/easiest way to QS on a manual band sawmill?
Josh
I turn the smile (pith side) up which will cause the edges to tend to turn downward as it dries.
I used 60 grit and did a "scrub" sanding
and added "house wrap" before I laid the flooring.
starmac
Thanks MM, I see the error in my thinking.
I, myself can get trees much easier to make 6X's than 12X' so would rarely need or want to use 12x12 cants for 1X6's or 4's
Rougespear
Is it advisable to cut flooring 5/4 or 4/4 green?  In other words, what thickness should flooring typically be when installed?
Custom built Cook's-style hydraulic bandmill.
It depends upon your sawing accuracy and how true your lumber is.
The first flooring that I sawed, the Kiln/Planer/T&G guy requested 1 1/8".  After having milled many tens of thousands of bf of my lumber, he is now OK with a full 1".
