Help with Log marking by buyer
Started by dgdrls, January 21, 2016, 06:05:12 PM
dgdrls
Can I get some help with the markings on these logs,
They were cut in the Mohawk Valley region of N.Y.
The buyer was a local shop out of Oswego County.
Dan
mad murdock
The number preceeding the"V" (for veneer) looks like 8 foot veneer, and 10 foot veneer. Not sure what the digits above might signify.
dgdrls
I suspected the veneer coding,  these photos are about 8 years old.  My initiation into marking a tract
for a select cut.   I learned a bunch and have even more to learn!!  :)
I was thinking the additional
numbers 1219, 1220 were some type of control numbers?
Thanks Mad M.
Dan
Maine logger88
The 1219 is 12 foot long 19 inches diameter
Vtbowhunter3
Every mill or scaler has different ways of doing it so hard to tell what's going on with every log. Maine logger is right about length and diameter with 1222. The one to the left that says 1022 above 822 is a 10 foot log that he bought for a 8 foot. Most likely the 8v and 10v, etc are his grades which vary from place to place and region.
jmouton
nice looking logs,,,,
        jim
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
dgdrls
Thanks Gentlemen,  I was discussing this with another friend and he was of the same opinion
about the 1219 1220 numbers being length/diameter codes and the V being Veneer coding,
much appreciated,
Dan
coxy
I think I know the co that bought those logs  :)
dgdrls
Quote from: coxy on January 22, 2016, 05:17:38 PM
Coxy,  The Gang at Allwood purchased our timber back then.
Dan
tj240
the first number is lenght second diam. then usually grade, if the top number has a line with a different number, the log was cut on paper.
work with my father[jwilly] and my son. we have a 240 tj 160 barko[old] works great three generations working together
dgdrls
Quote from: tj240 on January 25, 2016, 05:20:57 PM
Thank you tj240
Dan
