LT15 Diesel Mod
Started by UN Hooker, January 21, 2016, 04:37:50 PM
UN Hooker
No not the motor! But maybe in the near future. Anyhow, I been sawing all the sappy EWP all fall to finish the B&B siding using water/pinesol/cascade and a few other "additives. None of it worked well, most of it splashed off and landed on the cant 6" ahead of the blade, which did little to remove the pitch on the blade and belts. About 3/4 way thru, I got a couple days break ( weather ) so to the shop & started working on what I been "thinkin on". Built it, installed it and finished sawing the rest of the boards. WOW, the blade was spotless and the belts were almost,and sawing about 15-16' logs it used way less than 1/2 qt. of diesel.
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
Bruno of NH
ncsawyer
Diesel works on sticky pine sap very well!  I keep an oil can full of diesel by the mill the spray on my blade if I get into a sticky spot.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
UN Hooker
  Yes, I did the spray bottle of diesel too, but that got old fast. This is the second best mod. I've done to this saw since I bought it.
               UN
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Ga Mtn Man
Very nice job.  What did you make the wick holder out of?  Got any dis-assembled pics?
Good idea. I have a drip system,a slow drip,and that seem to use as much diesel too. With mine I have 2 valves,one to adjust the flow and one to turn off when I am loading a log or not sawing.
UN Hooker
    Thanks for all the compliments.
  Ga Mtn Man
  Its all made of SS. The felt holder started as 1"dia. 1/16 wall tubing. Pre-flattend in a milling vice, forced a piece of 3/8 x 1" in it then spanked that in the hyd. press to get the sides flat. That's the felt holder. If all goes well, I plan to bring the head & one section in the shop next month, then I can take it apart & take some pics.
  c-farm
  I have 2 valves on this also, top one is electric and opens at full throttle, second is needle valve and only opened a crack to adjust the drip.
              UN
YellowHammer
That looks professional 8)
Very well done.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Jemclimber
Looks very nice!!! Can you elaborate on the electric valve that opens at full throttle?
Where you got it and how it's hooked up?
lt15
slider
Do you have any plans for wiping the bottom of the band.I have seen just as much pitch build up there as on top.
al glenn
Sixacresand
I like the idea of wicking instead of dripping and also with wicking I see the possibility of lubing the under side of the blade as Slider mentioned above.
UN Hooker
Quote from: Jemclimber on January 22, 2016, 07:29:50 AM
      Jemclimber
     I have a micro switch mounted so when you engage the blade/throttle lever, it energizes the 12V solenoid by completing the ground circuit.
       This is at idle
       This is at full throttle
  The valve I bought on e-bay, but I don't know how much of that info I can post on here  w/out "gettin shot at"
         UN
Jemclimber
lt15
UN Hooker
Quote from: slider on January 22, 2016, 08:22:29 AM
  slider
   I've not had a problem with the bottom of the blade, on mine the sawdust/pitch gets squashed between the blade and the belts and just keeps building up.
  Just keeping the felt damp, the blade runs clean as new.
     I looked at the guide assy. today, looks like a bottom felt assy. could be fitted. The only issue may be making a mount that is adjustable. Next month when I have the head in the shop, I'll check and see what it involves.
           UN
