The proof is in the pudding.
Started by customsawyer, January 20, 2016, 03:51:18 AM
customsawyer
As most know I have been running one of my LT70 mills full time custom sawing for a very large hardwood mill in central Ga. I bought the mill new in April of 2006 so it is just shy of 10 years old. Well yesterday it turned 11,000 hours. I have done the crop and rotate but it doesn't seem to be working on my computer.
One thing I never realized was how abrasive saw dust could be. Here is a pic of my sawdust chute right where it is hinged. If you look close you will see it has cut a groove in the metal.
Here is a pic of where the ceramic inserts go right beside the blade guide rollers. I don't use the inserts on this mill so the bolt hasn't been turned in about 8 years but you can see how the sawdust has worn a large part of the bolt away.
All I can say is that after all of the abuse this mill has been through and it still cuts good lumber speaks volumes for these WoodMizer mills.
www.thecustomsawyer.com
Nomad
Quote from: customsawyer on January 20, 2016, 03:51:18 AM
     Congrats! 8)  Kinda like a birthday, isn't it? ;D  Definitely a noteworthy milestone!
WoodMizer LT50HDD51-WR
Lucas DSM23-19
MartyParsons
Hello,
   You can also give your self an " Atta a boy" pat on the back. Maintenance is key to keeping all equipment running. Keep up the good work.
Guides are for keeping dull blades cutting straight. I don't think I have ever seen the adjustment bolts wore like that.
Marty
Does seem odd. Just like water will wear a rock too.
4x4American
Boy, back in my day..
47sawdust
Trees have a lot of grits in them,that's why somes don't eat them.We eat mush,I think it's a close relative.You do know how to get it done,congratulations.
Mick
red
I thought you knew them there cantilever design mills can't cut like a 4 poster .
Peter Drouin
The sand coming out with the blade will add to that too.
Good job keeping the 70 going.
A&P saw Mill LLC.
License NH softwood grader.
Chuck White
That's a huge milestone.
Congratulations!
sandsawmill14
have you cut a million bd ft yet ???   just kidding ;D congrats on such a mile stone and getting the mill broke in :D :D :D
Jake is working on a billion board feet  :)
Sixacresand
sandsawmill14
yep he saws alot if i ever get a chance i would like to come down and see his setup and yours to wdh if yall dont mind :)
LeeB
I'm working on a billion bf too. I think I might get there sometime in my third lifetime.
drobertson
That's a lot of whacking!  Lord know what all you must have seen in all those logs,,
Ga Mtn Man
Pieces of "double-hard" saw blade teeth can be mighty abrasive. ;D
Congrats on the milestone Jake.  I forget, do you walk with that mill?
Congrats on another milestone Jake.  After over 10,000 hours I have seen similar wear around my sawmill but it all seems to be on ME.   :o   :D
LeeB
Lynn, I hope I'm in half as good a shape as you are when I get that many miles on me.
POSTON WIDEHEAD
Andries
We can mark that down as a very 'high proof' pudding' Jake.
Hats off to you - sombrero, baseball, toque or cowboy. Well done.
Lets see, 25 to 45 foot walk for each cut . ..  double that for the gig back . . times how many million board feet?
Here's a question . . . hows about a photo of your boots?
Now that might be a good wear indicator too!
LT40G25
Ford 545D loader
Stihl chainsaws
4x4American
Shoot with that much walking I'd be inclined to make a jolley trolley like @ElectricAl  did, but he doesnt have the axle under the mill either..hmmm
YellowHammer
That's a lot of wood, Pilgrim!  Congratulations!
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
scully
Does my ol heart good to see that , them 70's are quite an animal .
I bleed orange  .
Brian C.
What a milestone. Walking, off loading, that is a lot of beer, errr... work.
terrifictimbersllc
When you walk with the mill, on the return, do you turn around partly to see where you're going or not?
