Author Topic: Extra Large Log Arch  (Read 5831 times)
Offline Raym
« on: January 11, 2016, 05:04:11 pm »
Old Propane tank trailer. Perfect to be used as a log arch. Pump worked when tested with battery but some rust visible. No title, As is no warranty. 600.00
I have read, understand, and agree to the terms of posting an ad on the Forestry Forum.
'14-LT40 super, nyle l200m kiln, vintage case 480E loader.
It's not the fool that askith, it's the fool that agreeith.
Offline VictorH
Re: Extra Large Log Arch
« Reply #1 on: January 12, 2016, 02:32:13 am »
Oh I wish you were closer.
1995 LT40H24
Offline Raym
« Reply #2 on: January 12, 2016, 12:56:10 pm »
A couple of questions have come up so I thought I would answer them...
Center of the wheel to front of frame is 8'
Tires are in very good shape (not sure of the age though)
It has some kind of torsion suspension that i'm not familiar with and not sure of the payload
Missing fender not included  smiley_grin
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: January 12, 2016, 08:22:45 pm »
Raym,
   Tempting and if had a tractor instead of just an ATV I'd probably jump on it. What is the ball hitch size? 1-7/8", 2"?? Not a big issue to change ball or hitch if needed (I've standardized on 2" over last few years).
   Have you used it and if so what is biggest log you lifted/hauled.
    Looks perfect for someone in an urban area who gets lots of logs from tree trimmers/arborists. Good luck.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #4 on: January 12, 2016, 10:39:58 pm »
Raym,
I am interested in the weight it can carry. My problem is I am out west till March.
LT40HD, 742b Bobcat, Sthil v170,038, 461. 1952 TEA Fergusan Tractor
Offline Raym
« Reply #5 on: January 13, 2016, 07:53:59 pm »
I have moved it with a 2" ball but it may even be a 2-5/16. I have not used this to move a log but would imagine it would move anything you wanted. I brought this with the intention of moving logs but I wound up with a "vintage" case loader with forks.
Offline Raym
« Reply #6 on: January 14, 2016, 11:23:25 am »
More questions answered....
distance between centers is 47" distance from center of wheel to front of opening is 8'
here are better pictures of the wheels
Offline stihltoomany
  • I'm new, but not real new!
« Reply #7 on: January 14, 2016, 05:15:41 pm »
It is made to move LP tanks. My guess is it would handle 5000 pounds of log. Looks like just the thing if you can use it.
Way too many saws, mostly STIHL
 Bobcat S650, Bobcat 331 excavator
and other dirt toys
Looking for hyd bandsaw mill, Timberking used maybe? NOT anymore!
 WoodMizer LT40 super
Offline samandothers
« Reply #8 on: January 14, 2016, 06:15:10 pm »
We're you going to modify it to carry your logs?
Offline Raym
« Reply #9 on: January 15, 2016, 06:15:41 am »
That was my intention. I was planning on using it to move logs around the yard but I came across a loader with forks that better served my needs. Therefore I have not done anything with this other than take pictures to "resell"
Offline LeeB
« Reply #10 on: January 15, 2016, 06:43:03 am »
As far as I'm concerned the hydraulics alone are worth what you are asking for the whole thing. I'd be happy to take it off your hands if I was closer
'98 LT40HDD/Lombardini, Case 580L, Cat D4C, Ford 851 tractor, JD 3032 tractor, Husky 346, 372 and 562XP's. Stihl MS180 and MS361, 1998 and 2006 3/4 Ton and 2005 1 ton Dodge 5.9 Cummins 4x4's, 1989 Dodge D100 w/ 318, and a 1966 Chevy C60 w/ dump bed.
Offline sandhills
« Reply #11 on: January 15, 2016, 10:10:03 am »
Yes, and it wouldn't take much modification either.  I too wish it were closer.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #12 on: January 29, 2016, 01:17:44 pm »
They're made to carry bullet type propane tanks but, those tanks are always moved empty.
If the tanks were full, they'd be too heavy.
I keep my eyes open for one of those in this area.
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider
Cooks Cat Claw Sharpener, 4-foot Logrite cant hook.
I LOVE MY SAWMILL
Offline Firewoodjoe
« Reply #13 on: February 03, 2016, 08:47:46 pm »
A 500 gallon tank is about 1,000 lbs empty. So dead weight bouncing down the road I bet it would pull some wood with bigger flotation tires. It's tempting:)
Offline Solomon
  • I finally figured out how to upload pictures!!!!
« Reply #14 on: February 18, 2016, 03:15:26 pm »
How far is Montpielier from Norfolk ?   I'm right here in Chesapeake, Va
Time and Money,  If you have the one, you rarely have the other.
The Path to Salvation is narrow, and the path to damnnation is wide.
Offline Raym
« Reply #15 on: February 20, 2016, 06:01:48 am »
About a 2 hour drive....
Offline ScottCC
  • New ideas welcome
« Reply #16 on: April 11, 2016, 09:47:35 pm »
I have an electric one and it is the best, with butt end forward got 20'.  Also strapped in three 16' about 14" dia.  It is rough to use in the woods and hope to use rubber track excavator to pick logs in rough spots and bring to roads.  You need straps that will stagger multiple hanging logs.
Necessity is the mother of invention.  Poverty is its big brother.  Woodmizer mp100, Woodmizer electric  lt15 wide with extra track, 71 Oliver allterrain forklift, 26' flat bed trailer, road legal log arch, homemade kiln, AutoCAD lt15
Offline Raym
« Reply #17 on: March 09, 2017, 06:58:48 am »
I'm still moving this thing out of my way.....surely someone has a need for this.
Offline gasman1075
« Reply #18 on: March 09, 2017, 11:16:12 am »
That tank hauler or brindle was used to move 500-1000 gallon empty propane tanks which weigh 1750-1900 LBS and could have less than 5% liquid in them so another 211 pounds ( 2200 lbs ) . 2 5/16" ball.  no matter where you are geographically that is worth the money. There used to be steel rails that went across under the tank once is was picked up and then we would lower the tank and secure the tank to the frame. Jack
JD 790/Stihl MS310/Stihl MS261 / Timberwolf TW-P5/ Norwood Skid-Winch
« Reply #19 on: March 09, 2017, 09:19:48 pm »
Raym,
   If you get too tired of moving it out of the way you are welcome to move it to my place and I'll worry about moving it out of my way. :D :D
    Good luck on selling it. Sounds like when it finds a new home there will be 2 happy people.
