chainsaw info
Started by Scooby Doo, January 01, 2016, 09:28:40 PM
Scooby Doo
My boyfriend has a 450 husky rancher and has been cutting fire wood for my grandma. He is looking for a high quality saw that he can use a chainsaw mill with. Can anyone give me some specs and product info that isn't going to cost a fortune? Any help is greatly appreciated.
Stacy n Jd
Owner/Operator of a 1986 Wood-Mizer LT30 Manual
sawguy21
What are the characteristics of the wood he will be cutting? Few if any of us are familiar with your part of the world. Stihl, Husqvarna, Jonsered and Dolmar are the only manufacturers making anything powerful enough to meet your needs but be prepared to spend. I used to get orders for saws to go as carry on luggage for Africa and south east Asia, they were too expensive to import through normal channels and delivery could be iffy.
Lnewman
I use a Stihl 441 with an Alaskan occasionally
and it works pretty well
Stihl 170, 210MS, 290MS, 441MS and Hudson bandsaw
Check out her profile.  ;) Look to see where she is located. Hint,the pig roast.  ;D
I don't keep up on the models and sizes,but get a dealer you like. That means alot to me. They are really all just about the same. Meaning,Echo,Sthil,Husky,Johnsred.
celliott
A high quality saw you can use on a chainsaw mill, will cost alot of money. You get what you pay for. Milling takes lots of power, which means big displacement.
For new offerings, Husqvarna 390xp, would be about the smallest I would want to use for alot of CSM work. Other new options are the 395xp, Stihl MS661, or the real big boys, the MS880 and the Husky 3120. Any of these saws will likely set you back $1000 USD on the low end, and up from there.
Of course you can try to get by with a smaller saw and save money, but chainsaw milling is hard on a saw, and you're likely to smoke the engine on even the bigger models if you aren't careful.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Jiles
Since I have worked on chainsaws for many years, it is my opinion that you are better off purchasing a saw that is a few years old. Too many potential problems with "modern" saws that EPA has caused.
With that being said, when buying new, modify the saw after warranty expires.
Also realize that all warranties are worded to protect the manufacturer not the consumer--too many ways they can decline repair.
I personally like Dolmar/Makita, Echo, Husqvarna and Stihl, in that order.
Stihl is my least favorite because of starting issues and difficulty of repair to some models.
Even a 10 years old girl can start a Dolmar/Makita--Google it.
This is strictly MY OPINION and some are sure to disagree.
Satisfy needs before desires
John Mc
Can you tell us a little about what kinds of wood he will be cutting, and how big it is?
Also, How frequently is he likely to be doing chains saw milling?
As you've figured out, the Husky 450 he has now is too small for milling. You want a good sized saw for that application. Celliot mentioned some great choices, but they are expensive. If he's just going to mill a log or two now and then, or if the largest log he is likely to mill is 10 inches (25 cm) diameter or less, he might get by with something smaller than those saws - but whatever he ends up with is still going to be a significant step up from what he has now.
CR888
A used Dolmar 7900/7910 may be the ticket. Good for medium to large wood with enough power to mill. That would be the route I would go if the saw was not primarily used for milling. If the saw will only be used on the CSM.....well get the biggest saw you can afford.
starmac
What is available saw and parts/dealer wise in your neck of the woods. I would be looking for something that is at least somewhat available locally, even if it is not the very best for the job.
A saw big enough to be a decent milling saw is going to be a pro rated saw and not usually found on the cheap side, no matter the brand, it is also sometimes cheaper to go with the best and bigger than it is to go smaller to save a few bucks.
Whatever saw you choose, make sure they have enough oiling capabilities to handle milling (some don't), or plan to go with a remote oil system right off the bat.
Stacy change your location or I'm goona tan yer hide! :D
Some people's kids anyhow!
starmac
Are you saying we have done been hoodwinked. lol
Check out the pin map location on Stacy's profile.   :D
But she is serious about looking for a chainsaw.   ;D
starmac
I didn't even know we had a pin map, and rarely look at anyones profile.
I don't know much about computers, but just naturally figured what was on your profile was what would show up under your avatar. learned something today. lol
Scooby Doo
Thanks to all that gave me information! It is greatly appreciated!
Thanks again,
Stacy n Jd
sawguy21
Quote from: Jeff on January 02, 2016, 08:41:22 PM
ROTFLMAO. Botswana. SHEESH
cbla
Quote from: celliott on January 02, 2016, 08:33:36 AM
I second that. I have a 390xp that I use for CSM and I would not want anything smaller than that. Running the saw wide open is hard on them.
CTYank
Quote from: Jiles on January 02, 2016, 01:11:08 PM
What Jiles said. Some stihl models (e.g. 441) are unbelievably difficult to repair, because of crazy complexity.  "Comparable" Husqy (576 XP-AT) is WAY more reasonably designed, more powerful, and a much better value. It's good to have "open" access to parts too, something stihl embargoes.
Dealer dependancy only goes so far, until the training wheels are off.
Especially for CSM, it's a good thing to be able to spin your own chains, and an absolulte necessity to file them properly and often. Talking ripping chains, of course, vice crosscut.
'72 blue Homelite 150
Echo 315, SRM-200DA
Poulan 2400, PP5020, PP4218
RedMax GZ4000, "Mac" 35 cc, Dolmar PS-6100
Husqy 576XP-AT
Tanaka 260 PF Polesaw, TBC-270PFD, ECS-3351B
Mix of mauls
Morso 7110
