For all the block heater users
Started by yukon cornelius, December 26, 2015, 10:30:24 AM
yukon cornelius
I found something I really like. I needed a thermostat for the well house and remembered seeing one that plugs in inline for heat lamps and such. I started thinking about how well that would work for the block heater on my truck. I like to plug it in but I don't drive it often. This would  keep it from having power on it all the time. It comes on at 34 I think and I forget the off temp and it rated for 15 amps.  I got it from the hardware store. It is working well so far.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Chuck White
Sounds like it might be a worthy test.
Sounds feasable.
Wouldn't hurt to try it.
sawguy21
I used to put the block heater on a timer, I could set it to come on in 6,9, or 12 hours. I turned it on at 10, it kicked in at 4 am so the engine was warmed when I left for work at 7. It sure cut the power bill, those things draw a lot of power.
Brucer
I combined both ideas when I had a diesel pickup. Way back when, I found an extension cord that had a built-in thermostat, specifically designed to be used with block heaters. I also put an industrial timer in my garage and set it to come on 3 hours before I would normally leave for work. It worked great.
Bruce    LT40HDG28 bandsaw
timberlinetree
Nice! On of the nicest things is a plugged in piece of equipment on freezing days.
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
Ox
I salvaged a "Grey Box" electric water heater timer and rigged it up in the shop to come on a few hours before I had to leave for work.  Used it on my old 86 Ford crew cab dually diesel.  Same principle, different means.  Worked well, saved money.
yukon cornelius
Reddog
A google search for Thermostatic outlets gives you all sorts of options.
I just use the timer myself.
