Blue Logs ?
Started by doctorb, December 22, 2015, 05:36:18 PM
doctorb
I built a tree house for my kids years ago in a Chinese Chestnut tree.  A few of the limbs died, including ones from which a couple of swings were attached.  Took down those dead limbs and split them up for next years fuel.  Look what I saw!  Somebody please explain this copper sulfate color in these logs.  Note, the hook is still attached to the log in question.
Here's the tree house after the lime trim.
And here are the logs.
Note the still inserted hook.
Somebody must have seen this before and have an explanation.  Somebody here always does!
doctorb
Thanks, SD-
I thought it odd that I did not notice the discoloration the day the logs were cut, split and stacked.  Your reference gave me the reason.  The reaction takes moisture to occur.  If I had put those logs inside, the blue staining would not have happened.  Guess what?  It rained last night and earlier this AM.
I wonder if I cut the log whether this discoloration would appear on the inside, or does it only appear on the cut / split surface of the cut log?
My thoughts are that it is not necessarily just the moisture because there is plenty of moisture inside the tree/log.  It is a combination of tannic acid and iron oxide plus the moisture being exposed to the atmosphere (oxygen).  I have seen Oak trees felled that had fence wire inside.  There was no blue color for a couple of hours but once it started the spot grew noticeably larger and darker as time passed.
Blue color on a log end as seen above is a sure sign of metal inside.
WmFritz
Quote from: Magicman on December 22, 2015, 07:45:06 PM]
For some reason, ALL my Walnut logs seem to have this.   ;D
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
I've seen mills that paint all their log ends blue. ;)  ;D
I have sent logs to the commercial sawmill that I should have painted.  When they saw the blue they would not even unload them.
