Furniture built with inexpensive landscape ties
Started by Busy Beaver Lumber, December 21, 2015, 09:51:53 AM
Busy Beaver Lumber
Boy do I like being home on vacation. Letting me catch up on a lot of woodworking projects and ideas i had to build.
Here we have some outdoor furniture i made for around the outdoor fireplace. These are made from relatively low grade landscape ties i got at Home Depot when the were on sale for 99 Cents. I ran them through surface planner several times to get more of a flat face on each tie to simplify construction and increase user comfort. I then used a combination of sanders to smooth the sides of each tie. Construction is done with 3", 4" and 5" wood screws. Build time was about 3 hours.  In this case, I used thompsons water seal as the finish. Very sturdy furniture for hefty people like me :)
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
21incher
I always wondered what would be a good use for them, and you found one. :)
yukon cornelius
I love it. I was talking to the wife the other day about a project I wanted to try with them.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Busy Beaver Lumber
People seam to like them. My daughter took an order for a set of 4 chairs today. Should take me about 2 hours to make the 4 chairs.
6 x 10 dump trailer
Jet Bandsaw
