Sawdust use
Started by starmac, December 16, 2015, 09:35:27 PM
starmac
I was talking to one of the older hands at the sawmill today.
I see them loading the sawdust pretty regular, and ask him where they took it.
He told me they hauled much of it to the sewage treatment plant.
What does the sewage treatment plant use sawdust for??
CaptainBob
looks like they add sawdust to feed the BIOSolid composting process :
https://www.uaf.edu/files/ces/newsletters/mastergardeners/MGU00/MGU06_00.pdf
Golden Heart Utilities' wastewater treatment plant located at the river end
of Peger Road, has Class A composted sludge available as a soil amendment.
Sludge, also called biosolids, is a by-product of municipal wastewater
treatment. It includes materials separated from the wastewater stream
and microbial matter produced from wastewater treatment. It is a good
source of plant nutrients and organic matter. Two types of biosolids are
available in the nation. Class A biosolids have been treated to be free of
disease-causing organisms. That is the type we have in Fairbanks.
starmac
Now you have my curiousity up, do they sell the composted sludge to the public??
kensfarm
They do here in MD.. but I believe no human food can be grown on the field for a timeframe after.
SLawyer Dave
When ripping logs, I gather up all of the saw dust / strings and store in 55 gallon drums.  Then throughout the year, I put it in as bedding/nesting material for my chickens.  Works really well and helps control smells too.
CaptainBob
Yes, it is sold .  $20.00 per standard pickup truck load.  $10.00 per cubic yard for large quantities.
This is Class A biosolids - they mix the wastewater with sawdust and pump it with air to get the thermic process to kill any pathogens, e.g., virus or diseases.
Use it straight to the garden.  The fertilizer effect is best during the first year, but a garden guru knows that it is the residual Trace minerals that add to your gardens output for 3-5 years.  This is something you can add anytime of the year and benefit your lawn or garden.
http://www.akwater.com/pdf/CompostHandoutRevised%2005-19-2015.pdf
http://www.akwater.com/compost.shtml
starmac
That is WAAAAAAY cheaper than what I have been paying the last few years for somewhat sorry garden mix.
I lived in a small town a few miles out of Houston Texas for several years. They averaged around 300 arrests a year breaking into the sewage plant.
I never thought about it, but have seen some super tomato plants growing around septic systems, it turned out, that many folks flushed marijuana seeds, and the stuff grew like wildfire at the sewage treatment plant. lol
Ron Wenrich
There was a logger who used to supply loads of whole tree chips to the Philly treatment plants.  It was used in a similar process, but the chips lasted a longer time with the process they were using.  Sawdust seems like it would be cheaper, but it breaks down quicker.  Pellet mills are also causing a lot of competition.
Ox
Whatever you do, don't put fresh, non composted sawdust on your garden.  It uses nitrogen to break down, sucking it out of your soil that your garden plants need to thrive.  I use my sawdust for animal bedding and to "soak" up wet spots on the lawn from an old, broken down septic system.  My bedrock is around a foot and a half down, on top of the mountain where it's flat all around.  Drainage?  What's that?  :-\
SLawyer Dave
Ox, I just have to say, I LOVE YOUR SIGN.  That is just too classic.
mesquite buckeye
Fresh sawdust is fine for gardens as long as you add extra fertilizer to compensate for the extra organic matter that will get decomposed. After that you get a pretty good slow release as it decomposes.
I put 2" of fresh sawdust on my garden this year and worked it in with a bag of ammonium sulfate. Followed up with one feeder of miracle gro every month after. Seems to not be a problem. ;D 8) 8) 8) :snowball:
Sorry they look a little frozen. Low in the 20's last night. They will perk up and look fine an hour after the sun hits them. We are eating fresh lettuce, broccoli, kale brussels sprouts and collards most every day now.  ;D Waiting for the carrots and peas.  :(
I have worried a bit about all the walnut sawdust causing problems in my garden, but so far no problem. Either the juglone is getting decomposed fast enough to not be a problem or my plants are unaffected.
rjwoelk
Great product to use in the outhouse, do your deposit, sprinkle saw dust or chips till covered, no smell, same goes for inside toilet. I have given a couple of bags to a fellow that does this, then he composts it and puts it on his garden. Once it heats up it kills everything that could be a problem.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Quotesame goes for inside toilet.
You use the sawdust on the inside toilet as well?     ???
fishfighter
Quote from: beenthere on December 17, 2015, 12:43:40 PM
Well, that has to be a bit rough on the backside. :D
woodmills1
Merrimack NH uses chips and sawdust to make world class non food compost sold all over the world, from their sewage treatment plant.
kensfarm
Buckeye that garden looks nice green and leafy..  no squash?
rjwoelk
Yup inside bify as well. For a good lol check out the lovable lue.
Ox
Quote from: SLawyer Dave on December 17, 2015, 09:45:36 AM
:D  I have a feeling if we ever met in person we'd get along fabulously!   ;D
Knute
Makes good kitty litter.
SLawyer Dave
Quote from: Ox on December 18, 2015, 10:38:20 AM
The only problem would be that with your accent, I would never be able to understand what you were saying.   :D
Ox
Ha!  I've often been asked where I'm from, from people locally I've never met before.  Apparently they think I'm from a southern state somewhere.  Beats me.  I guess I've picked up the local farmer twang over the years.  If we can't understand each other I guess we'd have to use sign language.  A cold beer in an extended hand is pretty universal, no?  ;)
fishfighter
Quote from: Ox on December 19, 2015, 09:49:29 AM
Had always worked for me. Maybe it's just a southern gentlemen's  thing, but in my family, it had always worked. A handshake has always been our word. A cold one, well that always is after the fact. ;D
Cazzhrdwd
I use mine for cattle bedding, best I've ever used. It keeps the cows and barn clean and dry. I dump it in a side window and the cows spread it out.
96 Woodmizer LT40Super  Woodmizer 5 head moulder
mesquite buckeye
Quote from: kensfarm on December 17, 2015, 08:22:12 PM
It would be dead from the freezes. :( ;D 8) 8) 8) :snowball:
thechknhwk
I was thinking brick or briquette press.
