thinking of building a drying box
Started by yukon cornelius, December 13, 2015, 09:20:12 AM
yukon cornelius
I am wanting to build a box for drying some wood but mainly for killing any sort of bug that could possibly be in the wood. my thoughts are 4'x4'x9'.  I think I would like it to reach 150-170 degrees. I have a heating element, fan, timer, and safety's from a electric dryer. the timer goes to 90 minutes I believe. the temp control is set for 150 degrees. from what I have read, we need the wood to "bake" at 150 for 6o to 90 minutes. so in theory, these controls should fit the bill perfectly. I also have some thoughts for a duct port for a wood or gas furnace to blow in. i have a background in hvac, and electrical and believe i have the fire hazard portion addressed in the design.
I would like to be able to bake our cedar logs for our log furniture. we use 1-6" logs generally. the larger the log, the more cook time?
any advice for the temp and time or any other suggestions?
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
GeneWengert-WoodDoc
The rule for sanitizing lumber or any wood product is the entire piece, inside and out, must reach 133 F.  This can take much longer than 90 minutes at 150 F.  For a log pie.ce, it could take 24 hours or so.
yukon cornelius
Thanks! maybe a test or several. Bake for a set time and immediately cut it open and temp test. The average size I plan on is 2-4 inch range.
Ljohnsaw
Quote from: yukon cornelius on December 13, 2015, 09:20:12 AM
Other than big black carpenter ants in the rotted heart, I've never seen anything IN cedar.  Just bark grubs eating the cambium layer.  Do you leave the bark on?  I wouldn't think you need to heat treat it.
John Sawicky
yukon cornelius
We always peel the bark. We have only foundd grubs but would like to add an extra step of heat treating to make sure. Besides that, sometimes we end up with greener logs than we would like and a place to dry them a bit faster would be nice.
GeneWengert-WoodDoc
I assume you are talking about western red cedar...true?  Note that there many many cedars, but almost all are a different genus..white cedar is the only close relative in North America (genus is Thuja).  So, drying of WRC is quite a bit different than most other cedars including Alaska yellow, eastern red or aromatic cedar.
Be very alert for large logs, as the MC of the lumber can be extremely high...so high that the logs will not float in water.  Such lumber must be dried very slowly.
Looking at yukon's gallery and posts, I suspect it is ERC.
yukon cornelius
Sorry, yes eastern red cedar. I should have posted that but forgot.
21incher
I plan on building one soon also. I only use short pieces and have very little room left in my shop so I am looking for one of those old steel office cabinets that is 36" x 18" x 6 ft high with removable shelfs on craigs list to use for the box. I plan on lining it with insulation and just using one of the low cost STC-1000 temp controllers with a relay to control the heater, and a fan in the box to keep the temp even. The only thing that I am wondering about is should I keep it sealed to keep the moisture in and hopefully not add stress to the lumber, or should it be vented which could remove moisure from the surfaces and cause stress. :)
yukon cornelius
To vent or not runs through my mind also. I believe I will add a sliding vent to adjust for humidity and some for slow cooling so not to shock the wood. I think I may build mine horizontal and a workbench top on it. Multipurpose.
GeneWengert-WoodDoc
Vented is critical, as when the moisture leaves the lumber, you need to get it out of the dryer.  With oak, for example, each 1% MC loss is about 4 gallons of water from 1000 BF of lumber.  Of course, if you vent too much, then all the heat goes out.  So, the vents should be controlled to open when the humidity is too high and close when the RH is too low.  The key is to achieve the correct humidity, which is given in a kiln schedule (widely published).
The moisture is very acidic, so it will rust the steel components in no time at all.
Heaters can be hard to find as you want to go to 150 F or hotter, and do it safely...the contents are combustable.
Note that stress only develops at very high MCs, so if you air dry first, you will not be able to make any more stress.
yukon cornelius
Thank you! That is just the kind of info I was looking for. i think I will procede with this project soon. I hope to get some pics as I go.
21incher
Thanks for the info. Sounds like using a steel cabinet may not be a good idea. I thought using steel and lining it with fire rated  insulated drop ceiling panels would offer some fire protection and be real easy to make. I am wondering how much drying will actually happen in a single heating cycle to eliminate borer problems. :)
GeneWengert-WoodDoc
When drying ERC, we find that we have the best aroma after drying if the drying process did not go over 80 F.  When you go hotter, the dry kiln and local environment smells awesome, but the aroma is being evaporated from the lumber.  Many people dry ERC using a warm room, rather than a kiln such as used for hardwood drying.
yukon cornelius
Quote from: GeneWengert-WoodDoc on December 17, 2015, 08:21:38 AM
Thank you for that info. I appreciate your help!
