To pick up logs or not ?
Started by Arkyrick, December 11, 2015, 05:01:44 AM
Arkyrick
OK here we go again first off, if there is a thread that covers this topic already I couldn't find it, so apologies if I'm posting this in the wrong place. Does anyone have pictures or information on ways that you pick up logs from people who call you and want to give or sell them to you? My phone is ringing off the hook with calls about logs since I started advertising on the internet. Many are asking way too much but some are free and a few are fairly priced. I am currently looking into building a trailer with a winch and ramps for this problem. Has anyone on this forum done the same and have any info or pics they would like to share? Once I get the logs on my property moving them is not a problem I have a tractor that can load and unload.
Thanks in advance
Arkyrick
LT 35 hydraulic portable "73"Ford 335 tractor - lots of chains
Kipper
LT40HD, Cat Diesel
New Holland L783
Kubota BX23
Metavic 1400XL
2016 Dodge 3500
2007 Dodge 3500 (Dump)
Belsaw 802 Edger
Too many trailers to count and all Stihl Saws!!
fishfighter
I have a 20' trailer and I will load my tractor on it. I use a heavy set of hay bale forks to lift the logs over the side and roll them off onto the trailer. Before doing that, I always lay some 4x4's across the bunk of the trailer. Makes it so much easy to unload the at the house. Only problem using the tractor is that I have to make double trips. I have to leave my tractor till I unload the trailer. I do have a backhoe that I unload with.
I saw some people here that use a winch to load logs on a trailer. I'm still looking for a flat bed trailer that the bed goes over the wheels. My plans are to make some side ramps. Mount the wench at the front, install a pulley center of the trailer. The cable will pass under and around a log, back to the center of the trailer. Wench in, up the ramps. ;D
Kbeitz
Yes there is a few threads that covers this topic already.
But I dont know what they called the lifting arms thread that mounts on trailes.
Ahhh.... Found one...
https://forestryforum.com/board/index.php?topic=35016.0
Love machine shop work
and Wood work shop work
And now a saw mill work
red
There are only so many hours in the day . Try networking and bartering services. Logs are heavy and need heavy equipment. It has been said many times that cheap winches have cheap cables . Use good heavy duty equipment and Be Safe !
I load mine like this.
I now have two small tractor tires that go into the trailer bed before loading logs.   Live and learn :P
kelLOGg
I do it pretty much like Magicman.
Bob
warren46
I get 90% of my logs by picking up logs removed from someone's yard.  I use a trailer with a loading arch and a winch.  The winch is mounted about 2 feet above the trailer deck so the cable is higher than much of the load when pulling logs for the second and third layer on the trailer.
The reason I use a loading arch instead of par-buckling logs on up ramps at the side of the trailer is because I often cannot get the trailer along side of the logs where they lay.  Homeowner yards usually have lots of obstacles.  I can winch the logs right to the back of the trailer and the arch lifts them onto the trailer deck.
Warren E. Johnson
Timber Harvester 36HTE25, John Deere 300b backhoe/loader.
Kbeitz
About half way down the page is a good video about this log lifting arch.
https://forestryforum.com/board/index.php/topic,60413.20.html
Sixacresand
I load like MagicMan does.  If I cannot put the trailer next to the logs, then I move them with a log arch to where I can load them.  Some times you have to leave them if they are too big or in a bad place.
Den-Den
I load like Magicman and KelLOGg do.  I use a heavy duty manual winch, can load a log heavier than my trailer should carry (I will try to NOT do that again).
I have loaded them like this.
I have loaded them like this.  Backed the log arch onto the trailer as shown here loading some Walnut for Andy White.
YellowHammer
I used a standard, truck mounted service crane and attached it to a dump trailer.  The crane could  deadlift 3,500 lbs of logs right over the side into the bed, or I could extend the 3 section hydraulic boom 15 feet in the air, unwind some cable out to the logs, and "fish" them back through the woods using the crane winch.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Kbeitz
Quote from: Sixacresand on December 11, 2015, 08:42:16 AM
When I made my arch I put a large gas powered winch on top of it.
Any logs in a bad place is winched to the arch. I've winched logs up over a cliff already.
Nothing gets left behind.
fishfighter
Quote from: Kbeitz on December 11, 2015, 04:50:29 PM
Kbeitz, this years award for the best improvement of all things has to go to you. You got my vote. ;D
Kbeitz
Arkyrick
Wow great info and great ideas I'm leaning towards Majic Man's design it goes well with what I have available.
Thanks Everyone!
Alligator
Quote from: fishfighter on December 12, 2015, 06:51:12 AM
I second that. Kbeitz is the most creative tinkerer I've ever seen.
Esterer Sash Gang is a  Money Machine
mesquite buckeye
I am also impressed. ;D 8) 8) 8) 8) 8) :snowball:
dboyt
Parbuckling up a ramp is easiest, if you can get the log & trailer lined up.  My chain saw powered Lewis winch has never let me down.
Norwood MX34 Pro portable sawmill, 8N Ford, Lewis Winch
dustyhat
Somethings bad wrong with my computer it keeps putting the word (GOAT) were logs supposed to be. or is this a joke?
dustyhat
PC-Urban-Sawyer
Quote from: dustyhat on December 18, 2015, 08:09:50 PM
Im i going crazy or what.
Sounds like a variation of Yooper text change going on...
Don't panic, things will git worse.
Just kidding... <--- See what I did?
Herb
POSTON WIDEHEAD
logs....logs.....logs.....testing, 1, 2......logs, logs, logs.
Nope....its your computer.  :D :D :D :D
dustyhat
Sure hope you guys are playing tricks on me , my wife made me get off of here said it was one of them viruses.
POSTON WIDEHEAD
Quote from: dustyhat on December 18, 2015, 08:34:14 PM
;D
kensfarm
Those goat virus's are hard to get rid of too!   ;D
Yer lucky it's just the goat virus. That clears up pretty quick. Now if you would have had the yooper variation, you would have been DOOMED.
dustyhat
I think im putting it together, ort not to do that to a guy that dont know much about computers noway. :D
Yup, the yooper virus usually takes someone out with it.  ;D
dustyhat
Could not figure out why them guys were all loading goats, specially the guy with the knuckel boom.
POSTON WIDEHEAD
This is too funny. When I first came to the forum, I had Windows XP...I think.
Yooper night came without any warning and its was bad.
It was like being in another world and I was the only one that knew it....nobody else was talking about it.
I thought EVERYONE of my files were SHOT!  :D :D :D :D :D :D
Kbeitz
Caprine Arthritis Encephalitis...
It comes from drinking to much goat milk...
your haveing  hulalations...
