Shed.... Shiplap, is it posssible? If not Board & Batten vs Claps?
Started by wfcjr, November 29, 2015, 07:35:01 PM
wfcjr
Will have some logging done this winter.  Going to keep some of the timber to have it milled up for an equipment shed.
Two questions....
Our existing barn and attachment shed were made with lumber from the lumber yard.  Siding is pine shiplap that was subsequently painted barn red & white for trim.  Even though we plan to use rough sawn from our logging operations, would like to keep with the shiplap siding.  To date I have not been able to find any planer or piece of processing equipment that will turn rough sawn into shiplap.  Does anyone know of any good methods to convert rough sawn to shiplap?
If it is not possible or practical to mill shiplap from rough sawn, then we will look at either board & batten or clapboards.   Will likely sticker the wood for a few months.  So it will not be entirely green, nor will it be dry either.  Understand the theory behind the board & batten approach in that any shrinking as the wood dries will be perpendicular to the long axis, rather than along the long axis and the battens will cover any additional shrinkage.  If we decide to go with clapboards, I am assuming that it would be OK to put up the claps, only nailing on one side, (along the top) and that if we are conservative with the reveal, that any shrinkage in the claps will be far less than the overlap portion.
So... is is possible to mill shiplap from roughsawn?
If not, is there any advantage to board & batten vs clapboards?
Thanks for any insights...
Ljohnsaw
Quote from: wfcjr on November 29, 2015, 07:35:01 PM
<<snip>>
Yes, I would use a shaper table or a router and remove half the thickness to whatever overlap you want.  Could also use a dado blade on a table saw.
I'd say the advantage of board & batten is that you don't have to machine it!  Clapboards you really need to have a taper on the boards.  You can do that by alternately lifting one side of your cant a little, slice a board, lay flat, slice a board, lift same side again, etc.
John Sawicky
Dave Shepard
A jointer with a grooved outfeed table will do it pretty quick.
brendonv
I did a garage, and my dormer on the house with rough sawn and ship lap. I used a router at first, then a dato blade on a table saw. Because we used random width, setting up a system that helps push the piece along the table saw fence wasnt an option. I did it all with body weight, my back and sides hurt for days. Constant same motions just killed my body. I also killed a router at first too. Hahahhaha. Ill never do shiplap like that again, and without spending money on equipment it was my only option.
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
wfcjr
Quote from: ljohnsaw on November 29, 2015, 08:06:32 PM
Two other questions...
First on the shiplap, if we assume an 8" board or 10" board, how much of a rabbet is required on each end and how much shrinkage should one expect if the boards are put up green or after a month or two of stickering/seasoning outside but under cover?
Interesting question on sawing & processing time....
Second, on the processing time for the options...
Yes, the board & batten only get processed once for the main vertical boards.  But you still have to saw all the battens.
Understand that clapboards require a taper.  I would assume that one needs a Wood-Mizer type shingle/siding table or some other fixturing to permit an angled cut. While the claps need special processing to get the taper, you don't have to saw all the battens.   On the other hand, with clapboards, given the reveal, one likely needs more board feet per outside surface area than with board & batten.
So shiplap.... yes it does need secondary processing, but once again, no need to saw or mill battens.
Also, probably have a higher efficiency ratio of board feet to surface area, than you get with clapboards.
So I am wondering if it is a wash on the work involved or time to saw/mill between all options of board & batten, clapboards or shiplap.
Thoughts?
wfcjr
Should I have posted this thread to the "Sawmills and Milling" forum vs the "Drying and Processing" forum?
Dave Shepard
I've done 1" x8" clapboards, no taper. Works great, no machining.
I guess this is the only pic I have loaded of it.
DMcCoy
Thanks for that picture.  I have always wondered why the taper?  Never made sense to me as required.  I always figured it started out as a way to economize on materials, labor, and shipping.  First guy who did it could undercut the price of the competition.
edit: same goes for shingles.
Ljohnsaw
I wouldn't say that battens require "extra" milling.  They can be the off-cuts/trim when sizing your main boards.  All comes down to planning.  The reason for the taper on clap boards is probably two-fold.  Conserve materials and to keep the wall a little more "flat".  As far as overlap on shiplap - commercially, they are about 1/2" rabbits.
John Sawicky
wfcjr
Quote from: ljohnsaw on November 30, 2015, 11:04:53 AM
Understand the rabbet size on commercially available and kiln dried shiplap.
Wondering about rabbet size on lumber that is either green or has a modest amount of dry time, outside & stickered.  How much rabbet to ensure that there is still some overlap after shrinkage?  Is 1/2" adequate or will it need more?
To be a bit more safe, you likely will need more than 1/2".
But how much more is hard to say. If all the siding boards would dry straight, then even 1/2" might be enough.
But they will not all dry straight. Some will have crook and that overlap will disappear... then the underlayment will show or some "see through cracks" will show.
Then just a matter of how annoying might that be.
BradMarks
I've done both B&B and shiplap. Although the shiplap(tapered) was over 20 years ago, I seem to recall the overlap beiing more than 1/2", if for no other reason than enough wood to hold/hide the siding nail.  I can check at lunch, If I remember ;D
Ljohnsaw
Quote from: BradMarks on November 30, 2015, 11:58:51 AM
I just want to be clear in my own mind.  Out here, shiplap is uniform thickness boards with a rabbit on each edge, opposite sides.  Clapboard has a tapper in its thickness across the width of the board.
John Sawicky
We usually refer to this "clapboard" siding as bevel siding. Maybe one in the same?
Not sure what BradMarks shiplap (tapered) is. ??
On bevel siding, the holding nail isn't hidden, and isn't driven through the thin edge of the siding board just below it so it is allowed room to float with shrinkage and swelling.
BradMarks
Me and my terms!  Beveled siding I guess is clapboard, I've always referred to it just as beveled siding. So shiplap in my visual would be totally flat up against the outside wall. And no offense to anyone but I would be totally unhappy if someone put up beveled siding and showed nails - if I were paying for it! Just isn't done that way - at least in my experience. My only disclaimer would be that most beveled siding is primed, and then painted. Rough out (no paint) could allow for shrinkage and swelling and maybe then nail placement is different.
Dave Shepard
It's always nailed up with a nail visible that I've seen. We used one nail on the 1x8 non-beveled clapboards, about 2" up so it didn't hit the board underneath.
GeneWengert-WoodDoc
The reason that it was beveled is that originally it was cut 100% quartersawn, so when looking at the end grain, each piece is like a thin slice of a pie.  When sawing, this was easy to do by just spinning the quartered log slightly and then sawing another piece.  Hard to say in words, but very obvious if a log is first quartered and then quarter sawn...I will look for a picture, or maybe someone else has one.  So, by doing it this way, there was not as much waste.
jwilly3879
I have seen ship lap put up to resemble clapboard siding. The rabbet overlaps the full thickness on the lower board ( the full thickness of the upper board rests on the rabbet of the lower board) and it looks just like beveled and has a drip edge.
wfcjr
Quote from: GeneWengert-WoodDoc on December 01, 2015, 12:41:31 AM
Makes a lot of sense... least wasteful way to quartersaw.
But how would one go about doing this on a modern, portable bandsaw?
Seems like it would be tough to hold the quarter log properly and then turn it precisely for each cut.  All the pics & videos that I have seen showing quartersawn or quartersawing on a band mill, are a sort of modified quartersaw vs. a true radial cut.
Am guessing that is has to do with the limitations on holding a log relative to a horizontal band saw.
Dave Shepard
What Gene is talking about is a dedicated machine that holds the log between centers and has a circular saw. There is at least one on YouTube.
An article in Old House Journal with pictures. Someone has posted a pic on the FF before. Don't remember who.
bevel siding production link
See FF thread post #21 by Peter Drouin for a demo at a field event.
https://forestryforum.com/board/index.php/topic,79020.20.html
wfcjr
Quote from: beenthere on December 01, 2015, 12:45:40 PM
Anyone have any idea who the chap is that owns & runs that clapboard mill in the Peter Druin thread referenced above?
Bruno of NH
I put up truck loads of 8 inch shiplap every summer for a on going contract with a condo assc .
The kiln dryed stuff shrinks a lot .
With that said I milled some 1 inch pine last summer sold it to a friend and shiplap it for him he was very happy . Air dried 6 months .
You can saw your logs into board then bring it to some one to shiplap it for you .
Pm me when your ready I can give you some names .
Jim/Bruno
I use screws to hang the shiplap it works well for me.
