Best age of logs to mill
Started by Ih collector, November 25, 2015, 05:26:04 PM
Ih collector
I'm sure different types of trees will differ but generally white oak,red how long is it best to wait till you mill boards,new here I've seen stuff applied to ends to slow drying n cracking.So you cut a live white oak down n just plan to build a hay wagon or frame a pole barn say how long?
Farmer,lineman,sawyer wood-mizer lt40
tmarch
IF I have a cut list of boards needed I cut as soon as possible, if not I let it be in log form with anchorseal applied to the ends.  I generally slab some so I can quickly edge a board if needed.  I keep most of them off the ground and if the bark loosens get it off to prevent bugs and mold or mildew if it's warm enough for them.
Retired to the ranch, saw, and sell solar pumps.
Banjo picker
Welcome to the forum.   Cut them as soon as you can.  Sawyers don't like the words ..."slab it heavy"  ...meaning I have let it set so long before I brought it to you that the outside is starting to decay......So to answer your question...about 5 or 10 minutes works good for me... ;)  Especially white oak.  Banjo
Ih collector
So it's ok to fell n mill then sticker n dry as needed,I have a job to fell 3 white oaks that were topped 3 yrs ago still standing with bark but dead white oak,so I could mill boards now?
Ih collector
Hey thanks for imput so I'm good to do it ASAP
You should mill the logs asap. There is a school of thought by a very few, usually those that have never done this for a living, that you should let logs season before you saw to help reduce stress. Bull puckey.  Mill the logs as soon as you can. The deader, and dryer it is, the harder it will saw.
Ih collector
Very good thanks I know what I'll be doing! There's nothing worse then waiting till the 3rd date!!
POSTON WIDEHEAD
Ih collector
So as you said I had a white oak we felled 2 yrs ago n now I just bought my mill and Boy oh Boy did I have stress in that log,cut in 5' n could stick my whole hand in the cut!
Quebecnewf
Tie your mill to the vertical tree and if you can start milling it as it starts to fall. If you can,t do that mill it as soon as it bounces of the ground after it falls. If you can,t do that spray it with water until you can mill it.
Of course this is what works for me in my region.
I have had problems trying to mill them as they fall,  still trying to work out the details on that.
Quebecnewf
snowshoveler
Hi Quebecnewf
The Newfoundland side of you was into the "Screech" wasn't it.
Chris
International T5 dozer
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
Quebecnewf
Never drink Screech here in Quebec. Not sure what your referring to. There was some type of black rum that I heard about that had a name something like that . Might have been sold in the prov. of NFLD at one time but I am sure that practise has long been discontinued.
QuebecnewF
Nomad
Quote from: Ih collector on November 25, 2015, 05:56:33 PM
That log didn't gain stress after it was cut down; it was just a bad log to begin with.  Not every tree makes a good saw log.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Dave Shepard
Welcome to the Forum! I'm an IH collector, too. 8)
I've felled, milled, joined, and raised timbers within a few days. The fresher the better.
WH_Conley
All the log will do toward drying is get hard on the ends. Inside is just about as wet as standing. If someone says they are going to cut some logs and let them dry out before sawing I point out that the price goes for old logs. They have to be slabbed heavier that means harder work for me with less yield per log. That usually gets them on the lot pretty quick.
Bill
Kbeitz
The best is logs 100's of years old that sit deep in the swamps of Ga.
Because they bring the most money....
Love machine shop work
and Wood work shop work
And now a saw mill work
When sawing, I hate to have to slab deep and loose a couple of inches of yield from all 4 sides of the cant.  You are already 3 years late on sawing those trees.
Most of my lumber is felled,brought to my mill and sawed into lumber. Sometimes it's only a few minutes. But the good trees are just about gone close to the mill. So it's further back into the woods I go. Now it might be 20 minutes to sawing time.  8)
Chuck White
I think that one of the nicest logs I've ever sawn was a 24" X 10' Beech that was cut, and on the mill within 15 minutes.
It really sawed out nice and layed absolutely flat on the wagon.
I told the customer to let it air-dry for a few weeks "with lots of weight and stickered properly", then put it in the kiln with weight and stickers until the desired mc is reached.
The guy made some nice stuff out of it!
Actually most of my sawing is SYP and it is commonly several months since felling.  That plus the tree could have been beetle or lightening killed before it was felled.
Here is my next sawing job that according to the measurements that the customer provided scales 3779bf Doyle.  Some of the 14 logs have been down for a year and they surely will have pencil sized sawyer worm holes in the outside 3-4" and the underside will have sapwood rot.  This is a road trip job.
sandsawmill14
i hate those worms to. we call them pine grubs but i bet its the same critter >:(
PC-Urban-Sawyer
Quote from: Quebecnewf on November 25, 2015, 06:09:00 PM
QuebecnewF
Nope, they still sell Screech in Newfoundland.
Mostly bought to use in "Screech-In" ceremonies where "come-from-aways" are granted the privilege of being declared an "Honorary Newfie" after have (1) drank down a straight shot of Screech and (2) kissing the cod (that a fish, not what you nasty guys were thinking, after all this is a family friendly forum...).
The rest of the Screech sales are to "come-from-aways" like me as souvineers (I still have most of a small flask in my cabinets which I bought three years ago...)
In the meantimes, QuebecnewF, as they say on the Rock, "stay where yer too til I comes where yer at"
Hope you have a good and safe winter. Wish I could visit you but it's quite a bit out of the way from almost anywhere...
Herb
sandsawmill14
Quote from: Banjo picker on November 25, 2015, 05:43:11 PM
banjo is just kidding about 5-10 mins  ;) you have a full hour before you need mill it unless its hot weather ;D
all jokes aside the oaks will stain in a few days in hot weather and will last a bit longer in cold weather. down here grade can be lost in as little as a couple of weeks in hot weather
fishfighter
New to sawing, I found sawing fresh fell oak saws so much better. SYP, let them sit for a few weeks, the saw due to the sap.
Ih collector
Thanks all for the input so I'm good to go,have a great thanksgiving,and the ones way up north have a great day,going out to mess around some slabs need to true n make into boards that was left over from my first project of replacing my goose neck trailer deck with that white oak I sawed.
