Looking for Recommendation on Bar and Chain on Stihl 084 Alaskan Mill
Started by tomjones2a, November 20, 2015, 06:42:32 AM
tomjones2a
Hey Everyone brand new to forestry forum.  I just picked up a Stihl 084 to mill a 48" x 10 foot wormy maple that has sentimental value.  I already have MS 441 and run that with a a variety of 3/8 bars from 18 - 36".  I use the stock rim sprocket and use both woodland ripping chains and standard chains.
The 084 is coming with 3 rim sprockets 1 x 0.404, and 2 x3/8 (7 tooth and 8 tooth).  So I have some options.  Looking to see if anyone has any recommendations on bars and chains to harvest this log.  I really appreciate your help.
drobertson
Howdy,  I know nothing of CSM but I'm pretty sure Left Coast supplies could answer some questions for you,,
terrifictimbersllc
Seems to me your only option will be a 5' bar, on maybe a 54" Alaskan mill.  In Stihl or Cannon I think those will be only 404/063.  I agree check with LCS, there may also be GB bars.   I buy from them a 72" 404/063 GB sprocket nose bar (to modify) for my Peterson slabber.   I'm guessing  you'll spend $400 for a bar, $80 for a chain that you need to modify, and $250 for an Alaskan mill, work to make a rail system for initial cut, then you'll still have to do the work, and learn to do it well if you can.  Looking back I'd recommend considering finding someone to slab it for you if you can.
tomjones2a
Great Advice all.  I ended up going with a GBF 60" bar from Left Coast and 404 pitch ripping chain.  I'll use engineered 2x4 for my rail system for the first cut and will keep the chain sharp to cut down on my sanding after the wood dries out.
Thanks for the advice.
