I have a sickness
Started by hackberry jake, November 13, 2015, 06:39:23 PM
hackberry jake
New to me spindle sander. It has a 3"x9" "pump drum".  You can vary the amount of air in the bladder to get a harder or softer sanding surface. Saw it on cl for $100 and couldn't pass it up. I have an old American iron sickness. I am going to build a glue-lam sycamore top for it.
ScottAR
If it's any comfort... I woulda bought it for $100 too.
Scott
[Magicman]
POSTON WIDEHEAD
jueston
its purdy, i can't wait to see it with a new top on it being put to work in your shop.
21incher
Looks like you have Allmymachinesmustweighaton syndrome. No cure exsists. ;D
Delawhere Jack
Collecting Beanie Babies is a sickness. What you have is a shrewd eye for a good deal!  ;)
coalsmok
Want to form a support group?  I have the same sickness, and have been told its incurable.  Ole well, may as well enjoy it. 8).
drobertson
It may be a sickness, but at least your are treating it the best you know how!
happyj
I tell my wife it's not a sickness it's medicine that keeps me from being sick.
yukon cornelius
I will help you cope by hauling a trailer load of that machinery to my shop  ;D
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
park ranger
the acme thread rod and wheel look like an future apple press to me, if the sander doesn't pan out
hackberry jake
Got it moved inside and powered up yesterday. Now I'm gluing up cherry on edge to make a top for it. It has quite a bit of range of motion on the spindle, so building a top for it should be interesting.
Ljohnsaw
What is the vertical ACME screw for?  Will it be used for the table?  That is sure a crazy bunch of ways to set it up!
John Sawicky
hackberry jake
It is for a belt sander that is long missing. I will either try to fabricate something that will work or I will just remove it for more leg space.
51cub
I have the old iron thing. If it is a sickness, I hope there's no cure
I believe in the hereafter, because every time I take two steps into the tool crib to get something I wonder " what did I come in here after"
If nothing else I'm always a good last resort or the guy to hold up as a bad example
Delawhere Jack
So, you've got cherry just laying around for things like this? Can I be your best friend?  :D
hackberry jake
Quote from: Delawhere Jack on January 02, 2016, 06:43:38 PM
I used mainly low grade sapwood-ish, knotty, cupped cherry for this project, but I do have quite a bit of cherry laying around if you are needing some. Come on down to Arkansas and I'll load your truck up for you.
hackberry jake
Quote from: yukon cornelius on November 21, 2015, 11:52:58 PM
I saw a video of someone using one of these "pump drum" Sanders for making spoons. It flexes around what you are sanding to round the corners better. It made me think of your boy. I actually ordered $40 worth of the wrong size sandpaper. If you or your boy want to get one in the near future, get one that accepts the 3X9 sleeves that are 9.5" in circumference and I'll send you some paper. Mine takes 10-5/8" circumference paper but they are both called 3X9... Go figure. I believe you can mount the pump drums in a lathe as well if you don't have a sander they fit on.
Here is the video
https://youtu.be/-or3dx-s5a8
yukon cornelius
That is going to be a nice set up! We will keep that in mind about the sleeves. That is going to be quite a top for it. I can't wait to see it running.
yukon cornelius
Thanks for sharing that video. I showed Ashton that video and he this is we need one. I think we could find a use for one too. We shall put it on the wish list.  8)
hackberry jake
Lud
How ya gonna suck the dust?  No ocillation ?
hackberry jake
No oscillation. I haven't decided on how to suck the dust yet. Probably just let it fly and wear a mask. I have a dust collection drop nearby I'll experiment with. I think the sander is officially complete now.
Beautiful top.. they just don't make 'em like that anymore..  ;D
Kbeitz
The ones at Grizzly tools had a fan attached to the shaft below the sandpaper.
The dust would get sucked down inside.
Love machine shop work
and Wood work shop work
And now a saw mill work
