Skid Steer firewood processor
Started by Lambee10, November 04, 2015, 11:51:29 AM
Lambee10
Has anyone used or is anyone familiar with the skid steer mounted firewood processor?  I saw the Halverson Wood Products model in action at a logging show in NC.  You can take a log, pick it up, buck it to size and split it while sitting in the cab of your skid steer.  One man operation.
Obviously you need a skid steer to start with but very cool idea for those with less than strong backs. ;D
All animals like me...at feeding time.
M-14 Belsaw and the toys to go with it.
Lambee10
exactly like that one.   :)
Yes the Hahn is very similar but about $36K.  The Halverson was $15K
Anyone use one or can give some input?
OH logger
I SA WTHEM BOTH IN PERSON. HAHN IS BUILT MUCH HEAVIER AND STRONGER. the biggest problem I have with this type is that its too hard to pull a big split back and resplit it
john
shamusturbo
1.You need a relatively new machine that can run a 9(?)-way plug. You are running 3 circuits with one or two auxiliary lines from your machine.
2. You are running are relatively expensive motor and hydraulic system to run something you can purchase as a stand alone unit for very comparable money.
3. Your supply must be particularly straight pieces of wood to run through this machine. I saw this machine demonstrated at the NE Forest Products Expo in Bangor Maine in May and was hardly impressed. The operator took quite some time just to get a very straight, uniform 12' pole onto the machine to split.
4. If you are looking at working in somewhat tight quarters, factor in tearing up the soil/gravel or seriously eating some rubber off your tires or tracks on a hard surface.
Just my 2 cents. I can't see it making serious production. I guess for the positive side, you are seated, hopefully in heat and A/C, and maybe have a radio playing.....
Stihls 660,461,460,390,200T
Duramaxs 04 CCLB,15 CCFB DW
Gators- TS Loaded
Timberwolf TW-5
CRD Loco 20
CAT 287B
stumpjumper83
looks best on paper, best off with a stand alone unit.
