Has anyone modified their CatClaw?
Started by kelLOGg, October 29, 2015, 07:32:51 AM
I find the inside teeth seem to loose set more than the outside, probably why most often bands want to dive. How large is your grinding wheel/rock I think they tend to favor one side when worn down small. That's about all I know on that problem. Try running the band around once more and see if it removes the dull corners, if so insufficient grinding. Frank C.
Chuck White
Make sure that the "grind rock" is squared up with the blade.  :P
Other than that, send the blade around the second time!  ;)
4x4American
I usually do a minimum of 2 rotations...I've set the thing up and went outside and did stuff and come back in to see what effect the grinder has had on the blade..don't do that much anymore.  I will do other things in the shop and listen to the sounds it's making.  I do also notice that every so often it will just destroy a tooth or three and then go bak to being perfect.  I thought it might have something to do with a band being stretched (I run 3k lbs tension on it) and another thing I've thought it might could be is the clamp too loose, but I keep that thing so tight nowadays that I have to loosen the clamp before I can take the clamp down.
Boy, back in my day..
Banjo picker
4 x 4    I have a question.  Are you adjusting the sharpener in mid cycle or do you set it and then let it make a complete loop?  Banjo
4x4American
Chuck White
Quote from: 4x4American on November 03, 2015, 09:10:41 PM
I tweak it as it's going.
I believe that's the thing that Banjo was eluding to!
It's hard sometimes not to do that, but if you want the blade to be "even" all the way around, you have to start it, then leave it alone for the whole cycle.
I used to do that, and wondered why the grind would become uneven, then it would be OK again, then I STOPPED adjusting as it was grinding!
customsawyer
If you are tweaking in the middle of the pass it will only get worse each time you sharpen that blade.
www.thecustomsawyer.com
4x4American
Doesn't the grind wear rock as it goes around though?  I feel like the finger adjustment moves also...but aye aye capn I'll try it and see how it goes.  sail_smiley
Chuck White
Quote from: 4x4American on November 04, 2015, 06:46:49 AM
If you think the adjustments are actually moving, mark your adjusters so you'll be able to see.
4x4American
Banjo picker
It took me a while to learn to let it alone as well.  Just give it a try.  Banjo
4x4American
Thanks will do, will free me up to do other things!
4x4American
So once you get it started you're saying you don't touch it at all even if you let it go another round?
YellowHammer
Quote from: 4x4American on November 04, 2015, 10:00:04 PM
Yes, set it and forget it, and let it go fully around without adjusting anything.  It helps to mark the start tooth, just for reference, but you can hear it pretty easy, too. I can normally get all adjustments complete in about two teeth, running on 4, never letting it stop, then let it come around again.  Seems it take me normally 2 sharpening passes, then one light polish pass to get a nice sharpen.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
sandsawmill14
yellowhammer when i try to let mine go the 2nd round if i dont adjust the rod that pushes blade it will grind the tip of the tooth off  or am i not understanding what you are saying ???
Banjo picker
After it has made one complete pass, you will need to slightly readjust before letting it make another pass is needed.  4x4 after you get it set and grinding, if you are working on a band that you have adjusted in mid stream before it may be that there will be an area of the band somewhere that won't get hit at all or at least very little.  That is when you may have to uses several complete passes to get the band back uniform.  but as sandsawmill14 said , after the first pass it will start to ruin the teeth if you don't slightly readjust it.  Hope this helps.  Banjo
YellowHammer
Quote from: sandsawmill14 on November 04, 2015, 10:51:13 PM
It must be adjusted every trip around.  I'll make two sharpening adjustments and passes, and then one polishing or very light adjustment pass.
Just avoid the urge to adjust it in the middle of a pass.
YellowHammerisms:
sandsawmill14
ok thanks guys  i thought i may have had some thing set wrong as i am new to sharpening im getting better though now at least 1/2 of them will saw straight :D :D :-\ :-[
4x4American
I have been pleased with the way they are cutting, but just the inside set teeth give me trouble on the corner of that tip.  But yea after a revolution I need to tweak it a bit.
YellowHammer
Quote from: 4x4American on November 04, 2015, 11:16:55 PM
Does it appear that the rock may not be square, so is not cutting deep enough on the inside set teeth?  Or are the inside teeth just worn down more than the outside teeth?
If the finger adjustment moves, you may need to tighten up the setscrew on the barrel nut.
The grind rock shape should stay fairly stable, occasionally it will need to be profiled, but not for many bands.  I prefer the red rocks to the blue, they will hold their shape for a long while.
Don't forget to grease the shaft bearings, or you'll get to to replace them.  Been there done that.
I put a timer on my sharpener, that way I don't have to hover over it when it comes around, it will shut itself off rather than just keep grinding.  That lets me work on other things while I'm sharpening and not have to drop what I'm doing and come running over to adjust.
YellowHammerisms:
customsawyer
The grind rock will wear a bit this is why I do a very light dressing of the stone between each blade. This also keeps my stone clean and gives me a little cooler grind.
kelLOGg
I can now post pics. Below is one showing the deep grinds in an old band to make the angle measurements easier.
Below you can see one of the spacers I put under the band to raise it. The tooth is a 4° angle. You can see the descent angle of the motor/grind rock assembly is not parallel to the flat face of the grind rock. (4 x4, is this what you referred to as not being square??) I  have not yet adjusted the shim thickness under the pillow blocks.
Below you can see the new holes for 6° and 4° angles. I had to redrill the "L" shaped clamp so the motor could be pivoted.
Cutting Edge
Quote from: kelLOGg on November 05, 2015, 08:46:59 AM
https://forestryforum.com/gallery/albums/userpics/13036/P1020074.JPG
You do not want to remove shims to adjust the angle of the stone.  The shims are in there so the stone does not get abnormal wear.  Without the shims, the ENTIRE left hand portion of the stone will make contact with the whole entire face of the tooth as it comes down.  Very quickly, the "side" portion of the stone will begin to wear in an ever so slight taper and will subtly reduce the hook angle further.
Also, by having such a large contact area as the side of the stone stone comes down the face, heat transfer to the blade body itself significantly increases... ie: blued teeth.
The base that the pillow blocks mount to is what controls the chosen angle... that is also the plane of travel for the arbor.  You could have the arbor/stone shimmed to where you measure a 45 deg angle , but the plane of travel is still at 86 degrees (for a 4 deg face).
Hope this makes sense
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
- Sharpening Services
- Portable/Custom Milling and Slabbing
- On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blades
Ph- (304) 878-3343
kelLOGg
I hadn't thought of the side of the stone grinding the tooth face. You point out the effect of that very well. I haven't adjusted it yet so I will leave it as is. Thanks,
Bob
deadfall
Great information, CE.  Thanks for that explanation.
I like the mod, kelLOGg.  Thank you too. When I eventually buy a sharpener, I would like having such options.
W-M LT40HD -- Siding Attachment -- Lathe-Mizer -- Ancient PTO Buzz Saw
Happy for no reason.
