Steady hand, good eyes and he did it.
Started by POSTON WIDEHEAD, October 22, 2015, 09:46:25 PM
POSTON WIDEHEAD
Kirk and I were sawing today and the small pin broke that holds the gear that moves the guide arm in and out.\
I held the light and Kirk was able to replace the new pin without taking anything apart.
Took about 3 minutes.
Sure beats removing the whole motor, bracket and having the psi handle flop around. :)
You can see the pin if ya look close.
Bandmill Bandit
There is a woodmizer upgrade to that little problem that has fixed that issue permanently for me so far. Been about 2 years and about 800 hours of sawing since I installed it.
Even a good man needs someone to hold da light.   smiley_lit_bulb
Dave Shepard
I've replaced that little guy a couple of times. I keep a bunch of them on hand.
Bandmill Bandit, what is the update part?
terrifictimbersllc
It may happen tomorrow, but I have never broken that roll pin.
POSTON WIDEHEAD
Quote from: Magicman on October 23, 2015, 08:55:25 PM
It happens.  >:(
Nomad
     I've replaced that pin a couple times.  It's nice to know it can be done without taking things apart next time.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Peter Drouin
I replace the pin without taking it apart all the time. ;D
A&P saw Mill LLC.
License NH softwood grader.
terrifictimbersllc
Hats off to your friend I couldn't do it with a goat watching.
POSTON WIDEHEAD
Quote from: Peter Drouin on October 24, 2015, 06:30:44 AM
If you're replacing your pin "all the time".....somethings wrong with your alignment.  :D
He is sawing too many Pine Logs.   :D
Bandmill Bandit
The upgrade kit includes a new shaft with a flat spot machined onto it and then a set screw in the new sprocket as mentioned above. Would have to check with woodmizer but I am pretty sure it is a higher grade of steel too. I also used high strength lock tight on mine when I installed it.
I am gona look for the invoice so I can give the kit part number here.
customsawyer
The new one on the LT70s has the same shaft as before but there is a threaded set screw on both sides of the sprocket.  I used to have to replace mine about every 150 hours or so. This new one has been going for almost 800 hours.  ;D
www.thecustomsawyer.com
Chuck White
Hope I don't jynx myself, but something must need alignment for that pin breaking to be so common.
My mill now has over 2,500 hours on it, and I've never had any trouble with the pin.
POSTON WIDEHEAD
Quote from: Chuck White on October 24, 2015, 07:37:10 PM
Are you sawing or just letting your mill set and run?  :D
Bandmill Bandit
Pretty sure it isnt an alignment issue at all. just a slight loose fit with out the set screws lock tight would probably solve the issue just as well
terrifictimbersllc
Debris jamming  rhe tiny space between guide block and roller can  cause the blade to pull the arm when engaging the clutch. If the blade  guide arm rollers are a little bit loose that can yank the arm hard for some distance. I think this can break the pin. Maybe there are other reasons too.
Nomad
     Jamming the arm into the log puts a lot of stress on it (an "oops.")  Jamming the arm all the way open does the same thing.  (Much more common.)
Lucas DSM23-19
POSTON WIDEHEAD
Quote from: nomad on October 24, 2015, 08:58:44 PM
x10
Y'all probably saw into your side supports too.   :D   8)
POSTON WIDEHEAD
Bandmill Bandit
drobertson
Steady hand and a good eye for sure, done it before, an extra hand would've been nice ;D  it took a little better than 3 min for me :D
After multiple trimmings, some side supports are only a few inches tall.   :D
