Questions about the different degrees of bandsaw blades
Started by tomb, October 15, 2015, 09:09:23 PM
tomb
I need help to understand what the different degrees of bandsaw blades are for.  There is a 4, 7, 9 and 10 degree available for my saw.  I received 10- 7 degree blades with the purchase of my mill.  They have been working great on the ambrosia maple I have been cutting.
I have a hickory I will be cutting soon and I would like to know if a 7 degree blade is the correct choice.
Thanks for your help.
Den-Den
I am sure more experienced sawyers will be chiming in.  My take is that the higher numbers are best with soft wood and adequate horse-power.  Harder woods and wide cuts are where the lower hook angles tend to be better.  Lots of different opinions about which is generally "best".
Chuck White
Quote from: Den-Den on October 15, 2015, 09:24:09 PM
I agree with Den Den!   ;)
WV Sawmiller
Tomb,
    A few weeks back I cut a large (30") hickory that had been cut for over a year. I started with a 7 degree blade but pretty soon I had to change to a 4 degree blade. I have some new turbo 7 blades I am going to try in a little while on some seasoned W/O and see how they perform there.
    I'd have both available and try with your mill and see what works best for your application and that particular log. Good luck.
coppolajc10
Quote from: WV Sawmiller on October 15, 2015, 09:51:32 PM
Sooooooo, did the 4° work well on that hickory or what? ???
Kingmt
I'm surprised no one has asked you what saw you have yet. That seems to make the biggest difference. I was informed that a 4 degree is the blade for every wood on my mill. More horse power is needed to run more degree.
Sawmill=Harbor Freight Item#62366
Chainsaws=MS180CBE(14"), MS290(18"), MS038(20"), MS660(20" & 36")
Staff=1Wife & 5 Kids :)
Please excuse my typing. I don't do well at catching auto correct.
JB Griffin
It would help greatly to know what hp mill you're runnin. I use Cook Super Sharps exclusively, they're 8°, cut mostly hardwood and can't gripe about at em at all. I think they're far superior to the 10° blades for my application. I run a 33hp diesel mill.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
terrifictimbersllc
I have 42HP diesel, and use 1-1/4" 0.045 WM double hard blades.
I started with 10 and 9 degrees, but in last several years mostly use 7 and 4 now.
7s will handle about anything unless I am seeing wider cut widths in certain woods, or am resawing timbers.
So a 4 goes on automatically when larger (say 15" or bigger) hickory or ash logs go onto the mill. Or dry oak or pine timbers especially sappy ones.
Or when a wider cut in a hardwood is not perfectly flat, like when slabbing live edge logs with cuts up to 26" wide.
And if cut is not perfectly flat first things inspected are drive and feed belt tensions.
p.s. Also 4 degree for white oak. Last Spring I sawed 150 white oak logs for a timber frame house all with 4s, pretty much not a wave anywhere.
I might be full-o-grits but its my understanding the first band saws were manually pushed with lower HP and the 10 degree aided the feeding, you didn't have to push as hard. Today with high HP power feed mills its not as important. Truth be known all the hook angles will cut everything if sharp and set correctly. The trend, and I agree, is  less hook I use 5 or 6 but haven't tried 4 yet. Frank C.
petefrom bearswamp
saw 98 percent Hemlock and have recently gone to 7x34 and 7x39  turbo blades.
The last 7x34 is still on the saw after about 1100 bd ft. and working well if i dont crowd it too much.
BUT I did find out that they dont work worth a hoot on the side supports (another story).
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Side supports leave WM with waaaay too much paint on them anyway.   ;D
WV Sawmiller
Coppo,
Quote from: coppolajc10 on October 15, 2015, 11:23:22 PM
Yes. They did fine.
Kbeitz
Love machine shop work
and Wood work shop work
And now a saw mill work
dgdrls
tomb
First off, Thanks for all the replys!  Its exactly what I needed! 8)
I have a manual Turner mill with a 24 HP Honda engine and Im going to be cutting up an oak on Saturday and will see how the 7 degrees do with it.  Im thinking I might also get some 4 degrees as well.
Thanks again!
tomb
Quote from: dgdrls on October 16, 2015, 07:59:19 PM
http://www.suffolkmachinery.com/order-a-catalog.html
Grab the on-line catalog its loaded with great info on bands.
Dan
I use the Timberwolf blades on my shop bandsaw and they are great, thanks for the link!
