newbie chainsaw milling. help!!
Started by Andyp16, October 12, 2015, 10:10:13 PM
Andyp16
Hello all,
I need a little help with the type of saws I should be considering for milling my own lumber.  I have the granberg 777 chainsaw mill setup.  I purchased a used Stihl 044 magnum from a pawn shop and in the middle of my 1st cut the saw stopped working and some black smoke started to come out.  I had a 24 inch bar running with a regular chain and the log was a 22 inch diameter piece of Indian Rosewood.  I was able to take the saw back and get my money.
With all of that said...I'm only going to use it for maybe a few logs a week and the types of wood I'll milling will be indian rosewood, mesquite, chinese elm, willow acacia, alligator juniper, some oak, and some ash.  Generally no larger than 20 inches in diameter.
I don't have a ton of money for a saw but I know I need it to do the job so any suggestions for different saws...used or new...and any info on where to get a good deal would be greatly appreciated!!!
Gasawyer
Welcome to the forum. For a saw to mill with needs to be atleast in the 70CC range to do what you described. And go ahead and sharpen chain to 10deg it will help. All so at end of a long cut take air hose or blower and blow air around starter assembly for a minute or two (with saw running)to help cool saw down. This will make saw last longer. I do not have much experience with chainsaw milling small logs, used mine on logs to large for woodmizer and for slabbing. My first and only power head has been a 3120husky so far have 350 hours on her slabbing and no issues. At the end of each use blow saw off, check all screws,and clean air filter and prefilter. Good luck!
Woodmizer LT-40hdd super hyd.,Lucas 618,Lucas 823dsm,Alaskian chainsaw mill 6',many chainsaws large and small,NH L555 skidsteer, Int. TD-9,JD500 backhoe, and International grapple truck.
jimdad07
Even doing a few logs a week you want a good sized saw.  90cc+ is about the starting point, especially for any hard woods.  I ran a Dolmar 9010 for a few years with a 28" bar.  It worked well enough but it was still hard on the saw.  You can usually find an older Stihl 066 pretty reasonable.
Hudson HFE 30 Homesteader bandmill w/28' of track
Couple tractors, a bunch of chainsaws and not enough time to use them.
Andyp16
Thanks Jimdad and Gasawyer!  I'd love to get my hands on a husky 3120...want to sell yours?  Haha!  I've been thinking of a Stihl 066 and haven't been able to find a used one in my neck of the woods...I'm in Arizona.  What's a good price range for a good used 066, 395xp, or  other saws in the same range?  I found a McCulloch 250 on craigslist...80cc....listed for $125.  I was thinking I could probably get it for  $80.  I know parts are hsrd to come by but I figured if I could st least get started with this one then it might afford me a better one real soon...any thoughts?
jimdad07
Those older saws are even better.  They're slower but more torque.  Of she's a runner that's not a bad deal.  I've milled with a few different saws, even an old 045 Stihl.  What they lack in cc's they make up for in grunt.
grampt1
Welcome to the forum. I have used my Stihl 046 for milling on and off for years now, sawed about 25 oak trees in the 18 to 24" range over the years and I would say this saw would be about min saw for occasional use.
Good luck
mad murdock
You can get by with a 70cc saw well, if you set it up to mill with Picco chain.  If you are going to mill larger pieces, (dia), and plan on using 3/8" chain, you will want a 80-90cc class saw as a minimum.  The 250 has good torque, and surprisingly, due to it's popularity with the karting crowd, there are lots of parts available for it.
Brad_bb
Get rip chain for sure.  I do believe it is ground to 10 degrees, but don't quote me.
Welcome to the Forestry Forum, Andyp16,
Sixacresand
Andyp16, Welcome to the Forum.  Did your chainsaw lock up?  If it didn't it might be repairable.  Check with the chainsaw area of the Forum.
jimdad07
Quote from: Brad_bb on October 14, 2015, 02:05:00 AM
You are right.  Top plate is 10*, you can buy a loop of ripping chain for about what you pay for regular chisel chain.  Last time I bought a loop for a 28" bar I think it was 19 cents a drive link.
BUGGUTZ
I run a 77cc saw with a 28 bar. I file to 10 deg. I mostly mill pine and aspen. I built my own mill set up. Works great for me, I get a 22" width. VERY IMPORTANT: care for your saw, let it idle down and cool before you shut it down after each cut. Blow it out often, caked dust in the cooling fins will kill a saw quick. It retains heat.
Everyone has to be somewhere.
