Shipping Containers
Started by edkemper, October 11, 2015, 08:27:58 PM
edkemper
I need some storage so I can move as much of the "stuff," Tools, supplies, equipment and such so I cn get my house for sale and move out onto my property.
I'm thinking of a couple of 20'er so I can put them next to each other. Build a "roof between and a Patio roof off both ends to park my equipment under roof. Store my stuff inside and have my stuff mostly safe from the weather.
Any advise on buying them? I note plenty of places advertising on Craigslist but they all want heavy money ($2500-3000 each) and then shipping on top of that. Any advise or suggestion on where and how to save a few bucks.
Eventually I'll convert one to a lumber dryer and possibly the other will be buried and used for a root cellar.
I have the equipment to haul them myself.
Thanks in advance.
Old Man
Larry
Around here the sellers were pretty competitive and the price didn't vary much.
The aluminum containers were a lot cheaper because they are so easy to break in to.
A lot of containers I looked at had doors that didn't seal right and it would have been a chore to fix them.  I bought local so I could look it over good before spending $$$'s.  Cuts and holes are an easy fix.
I bought a 48' X 102" high cube aluminum.  The corners sit on 12" concrete filled sona tubes.  One corner is up 3' or so...jacked it up with a hydraulic jack and used cribbing.  Put three skylights in for lighting.  I've had it about 7 years and one of my better ideas.
sawguy21
Those that don't pass inspection for marine shipment go pretty cheap here but they tend to be in poor shape from rust. Loading, shipping, and unloading are the major costs.
Ljohnsaw
Was coming back from the Bay Area (S.F.) to Sacramento and saw two different trucks (pickups) hauling a 40' on a goose-neck flatbed.  Looked a little sketchy.  They just had a chain through the end holes (where they would fit on a normal semi frame) and down the side of the flatbed.  What do the steel ones weigh?  Out here, the 40's are about $2,800 and the 20's are $2,400.  I wanted a 20' but that was too much.  So I just picked up an old 14'x8'x8' cargo box for $400.
John Sawicky
edkemper
The 20s are just over 5,000#. The 40s are just over 8,000# if I remember correctly.
Old Man
WV Sawmiller
Ed,
    Good luck finding them. They are great and we used the design you mention in camps we built in Iraq and Afghanistan only we normally used 40' containers. Just level and attach trusses across the top and a roof (sometimes we just used camo nets for shade but not weather proof) and they made a great work area.
StimW
I bought a 48'er on CL for $1500. from a company that no longer needed it. It cost me $450. to have it moved 50 miles to my new property.
I used it to store my tractor and other stuff in it until I got my 40' X 60' "I"Beam building put up in May. It will still be useful for storage.
The good thing about 20'ers is that a Roll-back Wrecker can move them which will be cheaper than a Landall/flatbed.
Around here they all seem to be using the same price list!
There is a glut in the market (it cost more to send back empty than it's worth) but I think they just take their cost and multiply it by 3 or 4.
New HF Band Mill
Branson 35 hp 4 WD Diesel Tractor W/Attachments- Backhoe, FEL W/ Bucket or Forks, 4' Tiller
4000# Clark Forklift W/24" Tires
Promark 6" Brush chipper W/18 hp Kohler
Raider Bill
In 07 I bought a 40' with doors on both ends. I believe it was $1250.00 delivered about 30 miles.
I'm very happy with it. Lined 1 side with metal shelving I've picked up along the way. Holds a lot of junk ;)
coxy
about the same price here to     our town law says we cant have them ;D
Ford_man
Look the roof over good if it has a dent in the roof it will rust through and leak. It is very hard to push the dent out ,I used 2 10 ton portapowers to straighten mine then used bondo to seal it up.
florida
Down here in rainy, wet, south Florida the roofs have rusted out on every one I've owned. The humidity inside is pretty terrible too.  I got an old reefer semi-trailer for $100.00 that was amazing. Stayed cool and comfortable all year.
General contractor and carpenter for 50 years.
Retired now!
rambrush
We just bought a 20 footer and had the option of a 1 tripper which means it makes the single trip across the pond, This results in very little rust great door seals and no odor. There were others to choose from but had severe rust and stunk inside. So there are options out there and not just a rust bucket.
You have been hiding rambrush.  Welcome to the Forestry Forum.    ;D
Adding your location and wood/sawing/lumber interest to your profile is appreciated and helpful.   :)
TimRB
Quote from: edkemper on October 11, 2015, 08:27:58 PM
Don't even think about burying one of those things.  I have seen one that has been simply covered with dirt and not fully buried--it is rusting into dust.  The wooden floor has been replaced several times, and the roof needed to be braced because the additional weight of about a foot-deep layer of dirt was causing it to cave in.  Conex containers are designed to take loads at the corners vertically--if you apply loads anyplace else you are asking for trouble.
Tim
edkemper
Interesting. Probably one of the most talked about uses for them is to bury them. Preppers are all over them for hidden bunkers.
I guess I'll have to rethink my plans.
Old Man
edkemper
Just did a bit of a search on the subject. WOW! Thank you.
Now the next discussion, how can I camouflage a shipping container above ground? There have got to be plants and such that would hide it and the plants could be useful and perhaps productive.
I'd still like to make it a root cellar type place if I can.
This went in a direction I never expected but am glad it came up.
Old Man
"C-Cans" are the only thing that we have found that are lockable enough that have not been broken into......yet.   :-\
Raider Bill
Quote from: edkemper on October 15, 2015, 03:31:07 PM
Post a pix of the area you are putting it in so we can give you some ideas. GPS cord's too :D
I camouflaged a house in the city isn't hard and I'm not a painter.
Started doing my shipping container on the Billarosa but only got the base color on so far. A guy gave me several "empty" 55 gallon drums that had 5 or so gallons of dark green paint each left in they use to paint transformers with. Nasty stuff. I'm waiting for them to start using either gray or brown for my next coat. ;)
Raider Bill
Check out my broken TV antenna. It still get's 32 stations   :)
rambrush
Guilty as charged! Been lurking for awhile now. Profile is being updated.
Quote from: Magicman on October 15, 2015, 12:33:43 PM
TimRB
I have two twenty-footers.  They are under trees, but get a bit of sun and they still get pretty toasty inside in the summer.  No doubt you could do better if you found a breezy spot in full shade or built a cover, but I would consider a purpose-built root cellar before trying to make a conex into one.
Tim
Now that you have been flushed out rambrush, you will be obliged to share some of your interests.   ;D
edkemper
Quote from: Magicman on October 15, 2015, 04:12:49 PM
I've been looking into security. This seems the most hopeful:
http://smile.amazon.com/dp/B00558MBHC/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1MNIPEBJTPFWL&coliid=I3SO8DXAUTYRRV
Old Man
That is a new one on me.  I use the round padlocks.
I have used a battery side grinder and cut many of the round padlocks off for "storage wars auctions".  They are bad but still can be cut off.  I just hope that our local crooks/burglars don't get side grinders.
21incher
I don't think that it would cost much more if you used blocks and a prestressed slab to build a root cellar. Then you wouldn't have to worry about the roof falling in.
