One day job
Started by Peter Drouin, September 25, 2015, 07:41:35 PM
Peter Drouin
Do you think one day will do it, to install all the parts?  :D :D :D :D
I do have help. :D
And more if I need it. ;D
A&P saw Mill LLC.
License NH softwood grader.
Quote from: Peter Drouin on September 25, 2015, 07:41:35 PM
Nope,  head gaskets on the deer will be easy, but new bushings on the cat's tail will be a nightmare.   :o
Banjo picker
I hope you post several pictures of the process.  Are you gona have to take the engine off the mill?  Banjo
Peter Drouin
Quote from: Banjo picker on September 25, 2015, 08:09:23 PM
No, I was going to hang it from some pipe stagging in place.
I'm not sure when I can do it with all the calls for lumber coming in.
A&P saw Mill LLC.
BCsaw
Not too bad a job as long as nothing else pops up.
Your lucky, my cat won't help with anything!! :D
Sheesh, I wonder about cats these days. ;D
Inspiration is the ability to "feel" what thousands of others can't!
Homebuilt Band Sawmill, Kioti 2510 Loader Backhoe
WV Sawmiller
   My vet has a placard up that says "Dogs come when called. Cats say 'Leave a message' ". So true.
   Good luck on your projects.
5quarter
My cat always comes when I call...but then I only call him for dinner.  ;)
Blue Harbor Refinishing
customsawyer
Quote from: Magicman on September 25, 2015, 07:55:58 PM
I thought the head gasket was going on the cat.
www.thecustomsawyer.com
terrifictimbersllc
and better order a couple more since it's Siamese, just saying.  ::)
petefrom bearswamp
Peter
Is that the crankshaft support kit?
I checked my engine and the head gasket is the old one.
Not sure if I want to tackle the installs myself.
My mill only has 875 hrs on it but I hate to take a chance on a fail of either the gasket or the crankshaft.
I may try to get my mill to Hannibal this December before i head to FL.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
arlostone
thats a perkins gasket i don't think it will work on a cat.
tk 1400
Peter Drouin
Quote from: arlostone on September 26, 2015, 08:17:29 PM
It's a Perkins with a Cat label.
Quote from: petefrom bearswamp on September 26, 2015, 07:50:15 AM
Peter
No this is.
This is a new motor mount. Next is the hydro brushes too. ::)
A&P saw Mill LLC.
Delawhere Jack
Met a few cats over the years that needed their "O-rings" reamed out, but I'd never do it myself unless they were de-clawed.
petefrom bearswamp
How difficult to install the crank kit?
Kubota 900 RTV
