stress in southern cherry
Started by Joey Grimes, September 07, 2015, 04:10:44 PM
Joey Grimes
Cut some cherry that had stress and was going to cut up t4-5 long it got lot worse after drying. Is this more a problem with southern cherry?
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
POSTON WIDEHEAD
I have to put a lot of weight on my Cherry and will even stack, sticker and put bands around ir. A good straight Cherry tree in S.C. is rare. Most of our Cherry is from crooked logs..
Joey Grimes
That's what's odd the logs were cutting look like veneer quality logs. One log lays flat when cutting and the next one goes crazy
POSTON WIDEHEAD
Trees that grow on the edge of a forest will surely have stress in them. Most of mine are yard trees and they still like to bow up on me sometimes.  >:(
drobertson
I have found it very necessary to saw parallel to the sweep,!!! and stack very level with weight.
bkaimwood
I don't have southern cherry, but most of the cherry I've sawn is the same way...I have had stacks of 10/4 cherry, over 4 foot high, lined with 80lbs bags of sacrete on top...and one slab 6 down wants to twist...and it does, twisting the ones above it...I always center the pith on cherry, and isolate it to one board or slab...beyond that, not much u can do...
bk
Biocmp
Would QS'ing help reduce overall loss? I know you may initially get less BF but perhaps QS'ing would result in less movement and less total loss.
5quarter
probably would help to QS, but most qs cherry looks best flatsawn. I think I would grade saw it and take what I could get.
Blue Harbor Refinishing
