How tough to load tractor tires?
Started by shinnlinger, August 30, 2015, 08:16:28 PM
shinnlinger
Hi,
Local place wants 100 bucks a tire, but I was able to recover most of the fluid and have to do two tires so any advice?   YouTube makes it look easy enough?
Dave
Shinnlinger
Banjo picker
I got a little do hickey from the dealer to put the antifreeze in the tire....takes quite a bit of antifreeze.  Banjo
jcbrotz
Its easy all you need is the filler I got mine from gemplers it hose to a regular garden hose, a pump and antifreeze or beet juice. OHHH and lots of muscle afterward to lift the tire. I did mine mounted in place with the valve stem up. I have been told of people breaking one bead down and just pouring the antifreeze in and re-seating the tire also but never tried it.
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
I myself would have a tube in it. I would not trust just the bead of the tire working it in the woods. Too many places in the woods,be it stumps or rocks,for the tire to flex. I did not have tubes in the front tires when I first bought my tractor. Soon as they went flat,I put the tubes to them.
I even had the tires loaded on the wife's tractor. And that really just gets used to mow the lawn and a snowblower on the back in the winter time.
When I have tire problems,I hire a place that comes right to the house. They keep the rim on the tractor. Some guy took his off and brought them to another place, Charged him $20 less per tire.  ::)  He thought that was a bargain. So much easier not to bother with a tire. Be it loaded or not.
Raider Bill
Tractor supply sells a dohicky that makes it easy.
tmarch
If what you have is salt water or calcium chloride I would not reuse it.  "Beet juice" is much better and won't rust your rims.
Retired to the ranch, saw, and sell solar pumps.
Chuck White
I don't know about other models, but Kubota has been using molasses for a few years now!
Seems to be working ok for them, and not corrosive!
Ox
After filling tires the old, hard way (gravity, tire on, valve core out, tire flat on ground, then jacking up to create suction, then doing it all over again) I would recommend the tire filling valve and all you need is gravity.  Sure, it's slower but gravity is free.  Keep the tire on, take weight off that tire and use tubes.  Change valve stems every few years because this is the leading cause of rim rot.  Any spilled fluid be sure to thoroughly wash off with water.  I used calcium chlorite in my tires last year.  Keep them from leaking and they'll last for decades.  Are there better, less corrosive fluids to use?  Sure!  But I figured the old ways are good enough for me.  Bottom line is no leaks, no corrosion.  Takes some time but loaded tires are like having a new machine to work with.  And in this world you either have time or money and if you don't have one you better have the other!  :)
Dixon700
Any of you guys think of getting them foam filled? No worry of air leaks then. I'm Thinking I'd  Like To Do THIS To ALL 4 Of My Backhoe Tires when I BUY NEW Front tires.
Ms 460 mag 25" b/c muffler modded 010av  14" b/c
94 case 580sk 04.5 ram 2500
Quote from: Chuck White on September 01, 2015, 10:21:35 AM
RimGuardR – a liquid ballast made from de-sugared molasses
I'd heard RimGuard was from sugar beet juice, so fits with the molasses. Not sure what kind of mess one ends up with when a tire needs repair. Might be a question to ask at a tire repair shop.  ;)
I load mine with windshield washer fluid. Often sells around a buck a gallon, but usually around $1.50 now.
Ox
Foam filled would be nice, for sure, but I wouldn't want it for road travel or high speed mowing because the flex in the tires would be gone.  Good for skidsteers and woods tractors but that's about it I reckon.
Not much worse than a big tire with no flex, like loading a tire too full and not having enough air pocket for the cushion.  It's like riding on a lumber wagon.
Banjo picker
Here is the device to load your own tires.  And as to Kubota filling them....they didn't load mine
I had to do it
       I would bet there would be a heafty add on charge for them to do it.   Banjo
Got the tires filed by the dealer when it's still at thier place. I had all my done at no additinal charge.
Raider Bill
Quote from: Banjo picker on September 01, 2015, 11:36:18 AM
I had to do it
That's the gizmo I have.
shinnlinger
Thanks for the input, I think I'm going to give it a shot.
As I said before, I was able to recover most of the fluid as the chart says I want 30 gallons (12.4-24) and I was able to save 24 gallons, so I don't really have to buy any fluid (and I probably won't, but if I own the dohicky, I can always top off later)
I will have to do the other tire soon so any investment in the dohicky and pump (If I don't just go with gravity) will pay for itself again in the near future.  I have a good relationship with a place nearby that can mount the tire but can't fill it and the other place nearby can fill it too but I just don't have a good feeling about them as they have always treated me as second class because I'm not in there to buy a new tractor every time I walk in the door.  In fact, it was a real chore for them to work up a quote for me and they act like I'm bothering them, so its more than just the money and convenience, but I am saving $200 over the two tires too so the money is indeed a factor.
Shinnlinger
Ox
I understand what you're saying here.  Some places are like walking into a yacht club with your bibs and work boots on.  That sort of thing chaps my seat meat. >:(
sawguy21
I hated that job. I pumped the fluid out into a drum so the tire could be repaired. The reversing switch didn't work so I unhooked the hoses and  reversed the pump to refill with the tire on the machine. That calcium chloride was murder on coveralls and any burns or open cuts immediately got my attention.
Ox
Heh.  That stuff will eat anything, including concrete.  Amazing stuff.  Good thing criminals don't know much about it or they could cause all sorts of trouble with it.
shinnlinger
If I could post a vid I would.   I picked up one of those $10 filler deals and hooked it up to a hose run to an old water tank elevated on the hood of my farm jeep.  I poured the fluid in the tank, sealed it up and pressurized it so the fluid filled the tire.   It went pretty fast and I am pleased.
Shinnlinger
Ox
