Electric motor question....
Started by Dewey, August 28, 2015, 08:01:20 AM
Dewey
I have a Blower Motor that I use to help pull sawdust from my mill... For some reason out of the Blue it won't start on its own....  I have to hit the switch and give the blower a spin to get it to move... It takes a minute to get to speed but works fine once it gets going ??? Any Idea's ????
deepsouth.us
From what you've described it sounds like it could be the starting capacitor.
Timberking 2000
Den-Den
If this is a single phase motor, it is one of these:
* Starting capacitor
* Centrifugal starting switch (inside motor)
If this is a three phase motor, it is likely "single phasing" meaning that one of the connections is not getting power.
jcbrotz
Quote from: Den-Den on August 28, 2015, 01:40:32 PM
What he said^^^
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
Kbeitz
You probity got sawdust between the starting points...
Love machine shop work
and Wood work shop work
And now a saw mill work
Dewey
Hmmmm...  All good points....  It had been unused for quite awhile and had sawdust piled around.....  I finally rigged up the hose overhead turned it on for a second and it worked... finished up with hose hook up and it didn't work.... so I guess I will pull of any covers I can and give it a good blow out and see what happens....
It is a single phase... If it is a capacitor is that something that is easily fixed... and if so where would I get parts ???? Maybe Grizzly ??
sawmilllawyer
You could get the capacitor(s) from an electrical supply warehouse, as long as it is the same rating. Had to replace one on my 3hp Rockwell shaper. Works great now. Cost was around $20.00. Andy
Stihl MS-361, MS-460 mag, Poulan 2150, 2375 Wildthing.
deepsouth.us
If it is the capacitor, it's an inexpensive fix. Pull it off and carry it to a local electric supply, or motor shop.
Timberking 2000
Kbeitz
Quote from: deepsouth.us on August 29, 2015, 12:01:58 AM
Or E-bay.....
ladylake
Being unused for a while it's most likely the staring switch.  There are some points in it that you can sand with fine sandpaper to clean up any corrosion .   Steve
