husky 350, 346 or 353 P&C, best option?
Started by Native Cutter, August 19, 2015, 09:44:21 PM
Native Cutter
hey folks,
i got a question bout the above saws. i have a 350 that blew up, and had a rough life before i got it. was a crew saw. and this fall ima rebuild it. i want to know what you think is the best way for me to go based on my needs which is
a saw with the most low end for pulling a lil longer bar than a lot of folks run. this will see a 20" - 24" bar, likely .325, def chisel, full comp, for cuttin brush and also some firewood and clearing roads of blowdowns as a truck saw.
i used to run both a husky 42 and husky 51 cutting brush n slashing professionally with 24" bars, full comp 3/8ths chain.  they were both in this 3hp power range, albeit the 51 had wayy more torque in wood over 12" and the 42 had jackrabbit speed in brush and was dismally slow in wood over 12" lol.  they both put in a few seasons full time and were running great when a thrown chain cut a big hole in the 42, and the 51 broke a case half when a hunk of log rolled on it.
after some research i see the above oem p&c sets as my best options and know that i will hafta do some small changes to fit the 346, not sure on the 353. porting will be done at a later date.
what do ya think?
JohnG28
Try to clean up the cylinder and get a Meteor 353 piston for it. Base gasket delete, muffler mod. Retune and run it.  ;) A 346 cylinder will fit, just takes a little work around a few points I believe. 353 and 350 share same cylinder if the 52cc 350. If it's trashed maybe can find a used one decent priced, Chainsawr perhaps. If it's the older 49cc model then this won't work I don't believe though. IIRC 52cc has primer, 49cc doesn't.
Native Cutter
JohnG28, thanks for the info. And i forgot to mention that was one option i have in mind if it is possible. Ill know when I tear into it this weekend when he brings it over. Its been a while so i dont rightly know which one it is 49 or 52cc.
One thing im curious about, i hear lots of rave reviews on the 346 but much less about the 353. I just learned today on bailys site, the 353 is a closed port cylinder, yet it acres site say it spins the same as the 350 and not the much faster 346. does anyone have any comments on how the two stack up against each other?
weimedog
Quote from: Native Cutter on August 19, 2015, 09:44:21 PM
hey folks,
what do ya think?
A 353 is a bolt on. Not hard to "fit" a 346. If you aren't pinching pennies go 346.
A video...covers a LOT of ground about tips to build a 350
https://www.youtube.com/watch?v=7GR_lFjAgfU
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
Native Cutter
thanx Weimedog! I was hopin you'd  chime in, I been watchin thru your videos on the 350. They been very informative and helpful.  I'll watch this one.
And nope Im not pinchin pennies with this project, wanna get it done the best way. The cost of an oem 346xp p&c really isnt that bad when you think of what ur gettin.
SawTroll
Quote from: weimedog on August 20, 2015, 06:35:58 AM
Yes!
Information collector.
Native Cutter
ok, just got the saw back and tore it down. its the 45mm version which is cool I guess but it is definitely gonzo. good thing i already planned on the the 346 p&c. :)
got a question, how do i tell when it was made? I assume theres a code in the serial #  ?
JohnG28
Post your serial number and it can be decoded quickly down to week and unit.  ;) I don't know it off top of my head but ST or Walt or someone can help you fast. As I recall the first 2 numbers are year, i.e. 02xxxxx would be built in 2002 if a model from that series.
Native Cutter
oh ok , it looks like i got an 04 then? s/n 04 48012xx
JohnG28
Yes, as I know their s/n's that should be a 2004 unit. I don't recall how to decipher the rest though, sorry.
HolmenTree
Quote from: Native Cutter on August 22, 2015, 10:41:22 PM
Depending  what #'s are under the 2 x's if there are any. It would be a 1200 something unit built in the 48 week of 2004.
Native Cutter
Ok great, the year is all i was curious about. thanx gents
WV Mountaineer
FWIW, this may not apply to the saw you mentioned because he may not sell a AM kit for it but, I just bought and installed a kit on my 385 XP from Chainsawr that was awesome.   The jug had no casting imperfections, the ports were perfect and, the only thing I did was polish the exhaust port, widen the transfer ports and polish them, Moddied the muffler, and switched the rings out for Caber rings.  His would have worked fine.  I also put the gasket on it.  The saw runs very, very well.  Extremely quick with a lot of compression.  It yanks a full comp chain on a 24 inch bar through anything effortlessly.
I'm a huge Meteor and OEM guy when it applies but, the rebuild kit I received from Chainsawr was flawless and after 5 gallons of fuel, is just getting better.  God Bless
Trying to live for the Lord, spend all the time I got with family, friends, hunting, fishing, and just enjoying my blessings.
SawTroll
That would be  2004 week 48, and number 12xx that week.
SawTroll
Quote from: JohnG28 on August 21, 2015, 11:50:33 PM
Depends on how old the saw is, but correct for a 2002 saw... ;)
SawTroll
Quote from: SawTroll on August 27, 2015, 06:27:26 AM
Depends on how old the saw is, but about correct for a 2002 saw...(yy mmxxxxx) ;)
JohnG28
Did you mean yywwxxxx? I know the earlier year saws were different, but this holds true for the last 20+/- years, correct?
