To beech or not to beech, that is my question
Started by square1, August 15, 2015, 07:08:03 AM
square1
I deal mostly with firewood. Beech & Firewood aren't words that generally go together.
I would not have taken this tree down, however a recent windstorm took it for me.  It's ~11" DBH and 26' (nice & straight) length.  It will be a pain to bring out whole, but if there's someone here with a mill that would like it, I'll do my best to get it out to the road  for you in one piece. It's located about mid-way between Flint, Saginaw, and Lansing Michigan.  Let me know, otherwise it will become kindling / shoulder wood I suppose.
petefrom bearswamp
Beech is excellent firewood.
That bark looks more like Aspen, not a good firewood
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
square1
Quote from: petefrom bearswamp on August 15, 2015, 07:14:41 AM
Okay then, Aspen or not to Aspen, that is my question.
Just doesn't sound right though ;)
Not worth milling either?  Even if free except the cost of fuel / time to pick up?
rooster 58
Ox
If it were me and it was close by, I'd snag it.  I'm from the mindset of waste not, want not.  If nothing more it could be used for furniture or paneling.  Heck, it could even be used for furring strips under metal roofing.
square1
QuoteI'm from the mindset of waste not, want not.
Being the child of depression era parents, I'm right there with you.  Hate to just drop it on the ground and let it rot.
But, yeah, NY is a bit of a trip even for a free log ;)
deadfall
So I guess Washington is out of the question.  Trees like that are what my handle here is all about.  More than anything, I like sawing up trees that volunteered for milling.  I prefer forests, in their natural state, to plantations.
Beech has been used for lots of tool and kitchen utensil handles, brooms and brushes.   It was used for a lot of things that are now made of plastic.
W-M LT40HD -- Siding Attachment -- Lathe-Mizer -- Ancient PTO Buzz Saw
Happy for no reason.
sprucebunny
Beech is excellent firewood and often not worth making lumber out of.
Aspen/poplar I rarely bother to drag out of the woods. The ones I find aren't big enough to saw and don't throw much heat.
rooster 58
Nearly 2 yrs ago, while working on a new house being built that was projected to cost 11 million, I saw hardwood flooring  waiting to be installed. Not sure what it was, I asked the superintendent  what it was. He told me they selected beech because the owners had large dogs
Seaman
I hope someone can use the beech, but I gotta ask....What is " shoulder wood"? Shoulder of the road?
Frank
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
Definitely looks like aspen, and not very good aspen. It also looks like it is growing on a slope, which means it is aspen with potentially a lot of stress.  I reckon I have sawn more aspen in my life perhaps than any other commercial sawyer in Michigan so have a pretty good idea what the tree will hold for lumber with those black conks started on it.
It's not worth messing with unless you need some fast burning firewood. If it were Beech, it would not be worth messing with unless you needed some good firewood.
petefrom bearswamp
Kubota 900 RTV
ahlkey
I saw a lot of Beech logs every season and while not great it does saw nice.  However, the majority of mature grade trees will often be hollow in the center.  It is great firewood though as the BTU's are high. From your picture of the tree it is pretty clear to be the common Quaking Aspen species.
I have burned a bunch of beech and and bunch of aspen too. Both in a boiler at my other house. Yes,the beech did much better. Those aspen would've made a great looking cabin. They was all just about 8 inches across.But at that time I did not have a tractor with a loader. Nor did I know anything about doing a cabin. I burn a lot of wood that others would not burn. As my Father use say,It's not the quality of the wood but the quantity of it.  :D
square1
Quote from: Seaman on August 16, 2015, 07:53:17 AM
Frank
Shoulder wood is lower btu wood that is burned in fall & spring to save the higher btu wood for winter when greater heat output is needed.
OneWithWood
Quote from: square1 on August 17, 2015, 08:06:55 PM
Frank
That big tooth aspen could be used as 'shoulder wood' but sassafrass or tulip poplar would be better.
Given the black conks I would leave it to rot in the woods and build the soil.
One With Wood
Weekend_Sawyer
I see the "black conks" but what do they mean to you Robert and Jeff?
Imagine, Me a Tree Farmer.
Most likely the "conks" are bark growths covering broken limbs that died and broke off. There will be some dark staining and possible decay extending away from the dead stub. The tree attempts to grow over these stubs and, in time, may be successful. Much depends on the growing conditions as to how fast the stubs heal over.
The conks shown are indicators of the dead stub and surrounding area below which leads to lower quality lumber and other products, as they limit the desired clear-wood volume often desired.
Engineer
That's not beech.  If it was, I would say it's worth dragging out for firewood, not for lumber.  I would definitely saw a larger beech log though - say, in the 14-18" range and up.  I have a pretty decent stash of beech lumber and I used a clear, 5/4 x 10 x 12' long piece in my kitchen as a shelf above my countertop.  It holds all kinds of canisters, mason jars and other 'country' stuff that makes the wife happy.  The stuff is hard, finishes beautifully, and unlike most other woods, imparts no taste or flavour to food.  It is ideal for cutting boards, bowls and kitchen utensils.  I'd rather have a beech butcher block than a maple one.  It also exhibits some really nice flecking & figure when quartersawn.
sawguy21
Other than tool handles I am not familiar with beech, we don't see it in the west. Aspen/poplar is a whole 'nuther story, it's just a giant weed. Unless that blow down is a hazard or in the way I would leave it to rot. I have some on a slope behind the house that really need to come down before they fall on the fence or the garage but all I can do is burn them in a pile once the bans are removed.
Ludo
THIS IS A BEECH!
My Daughter (chief sealer and money counter) is 55".  :-*
Going to slab it as soon as I can get it home!
That is a sunny beech.  Wow.
Your end-sealer is doing a fine job.
5quarter
Thanks for the info Engineer. I cut and split tons of Beech years ago, but have never sawn it for lumber. Wish it grew here in NE.
Blue Harbor Refinishing
