One of my new blades Broke today!
Started by flatrock58, August 05, 2015, 11:19:31 AM
flatrock58
When I bought my mill last year it came with 20 old blades.  I bought 4 new blades to try and see if I could tell the difference in how they cut  and speed.  The old blades have been slowly breaking which it to be expected.  Yesterday One of the new blades that I have sharpened two or three times broke while cutting some pine.  After looking at the blade I notice another crack at the back of the blade.  What usually causes this kind of crack?  I have also noticed that most of the time I seem to break blades when the blade guide arm is closer to the closed position.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Cooks Dual Tooth Setter
Solar Kiln
xlogger
are they about 1/4" away from the back of the roller guides?
kelLOGg
All the cracks I have noticed start in the gullet.???
Bob
MartyParsons
Hello, "
Check the blade to roller flange adjustment. 1/16 on the drive side and 1/8" on the idle side. The first grove from the flange is about 1/8". A piece of wood or other stuff stuck in the saw head will also cause blade to over heat at the back.
Guide block plates can also rub the band and cause this.
Hope this helps.
Marty
drobertson
It almost looks like you hit something hard and ferrous,  but it happens, wish it did not, but it does,
hackberry jake
The choice of alloy used for the blade varies a lot depending on what is wanted out of the blade. If the blade is designed to be resharpened many times (long life) if will be a softer metal designed to flex more. If it is a one time use blade, like is used for high production pallet resaw systems, they will be much harder. Only designed to run for 4 or 5 hrs of hheavy sawing. The harder blades hold their cutting edges longer than the softer blades though. Maybe you have the harder type of blade and it just traveled around the wheels too many times.
Chuck White
I agree with Marty, the blade is likely too far forward of the flange on the blade guide rollers!
bkaimwood
I have had the exact opposite happen... The blade tracking rearward too far, and rubbing against the flange on the guide roller...this puts LOTS of heat in the back of the blade, as well as is the rollers..
bk
flatrock58
Thanks for the input.  I figured it could be a problem with the roller adjustment but wasn't sure.  They adjusted that a when I went to WM in Newnan about 100 hours ago, so I thought it would still be good.   I will check it and the other blades to see if they have any cracks.
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
drobertson
Quote from: drobertson on August 05, 2015, 02:30:06 PM
I will say again, there is metal on that second tooth, on the top tooth in the picture is rounded as well,  the plus side to it all is it looks like you found it before it wound up behind the wheels,
flatrock58
I think the damage to the tooth must have been after the blade broke and hit the guard.  I had just sharpened this one and been sawing clear SYP with no metal.  I was cutting the cant into three  section to make 2x4's.
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
boscojmb
It looks like Mr. Robertson hit the nail on the head. (pun intended)  :D :D :D
That sure looks like a minor metal strike that went unnoticed.
Cutting a small nail that is perpendicular to the blade, or soft metal like barbed wire, is sometimes hard to hear.
All blades that have a crack as substantial as the one in the picture make a TIC TIC TIC sound before they break.
It took me years to hear the TIC every time. I haven't had to fish a blade out from behind the band wheels (and everything else that a broken band can get tangled it) in some time.
John B.
Log-Master LM4
Bluejay27
Quote from: boscojmb on August 05, 2015, 09:04:50 PM
I've had minor metal strikes like that too. Either the blade breaks and has a minor strike with the blade guards (minor on all the teeth...) or I've screwed up and had the blade fall off (backing up in a cut with the blade still going) and it conveniently suddenly needs to be changed anyway.
'98 Wood-Mizer LT40HDD42 Super, '08 LT40HDG28, '15 LT70HDD55-RW, '93 Clark GPX25 Forklift, '99 Ford F550
customsawyer
Also check your b57 belts. Make sure they are not worn to the point of metal on metal.
www.thecustomsawyer.com
Kbeitz
Opps....
Some how my posting ended up in the wrong message...
Love machine shop work
and Wood work shop work
And now a saw mill work
flatrock58
Finally got a chance to look at the mill today.  The outside blade to roller flange adjustment was off.  The blade was actually against the flange.  not sure how that happened since it was just set a couple months ago at WM.  Got it all adjusted and will try it out tomorrow.  Thanks for all the input and advice.
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
Delawhere Jack
I agree with Marty and Dave's assessments, but beyond that, that blade is duller than dull. Those couple teeth in the photo are round. They should never get that dull. A band that needs to be sharpened should still be sharp enough to cut you if you handle it carelessly. Those teeth are WAY beyond time to be sharpened.
deadfall
I'm thinking those teeth bit some steel when the blade broke.  They look damaged, not dulled.
W-M LT40HD -- Siding Attachment -- Lathe-Mizer -- Ancient PTO Buzz Saw
Happy for no reason.
Cedarman
Looking closely, I think you can see a curled piece of metal on the tooth.  That is what we see when a blade hits the shield when it comes off or breaks.  Also see it when you hit a nail.
Let us know if alignment makes a difference.
flatrock58
Delawhere Jack I had only cut two logs since sharpening the blade on my CBN sharpener.  It was cutting smooth and fast when I had squared the cant.  The blade broke when I was cutting the cant in thirds.  The place it broke must have had a crack just like in the picture and it looked like it might have been cracked a little while.  Only the front half of the blade was a fresh clean break.  These logs were from the middle of the woods and I was cutting a log that was the third 12' log off the ground.  I guess I could have hit metal on an earlier log.  Anything is possible when cutting lumber!
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
Looking at the dull teeth and curled metal, you definitely hit metal.  Pushing a dull blade will always lead to breakage.
flatrock58
 Well after all the post about dull blades I had to go back and look at the blade to make sure I wasn't going crazy.  There were only a few teeth that were badly dulled and a couple that had metal strikes either from the hitting guard after it broke or hitting metal.  All the other teeth appeared to me to be in fair shape.
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
Quote from: flatrock58 on August 08, 2015, 10:31:23 AMI had to go back and look at the blade to make sure I wasn't going crazy.
I agree, you ain't crazy.
deadfall
Looking there, and especially at the tooth between your fingers, at this resolution, I see what looks like a darned good point.  I suspect you didn't break because of dull.  There are so many other factors, that I can't make any guess about why it broke.  But I don't think it was not being sharp.
drobertson
I need to clarify to flatrock,  I surely did not mean the break was caused by a hit, just noticed a hit,  I've had brand new straight from the box give way, so, it happens, change out, and move on,, on the crazy thing,, I think we all are just a bit on the crazy side ;D
flatrock58
drobertson you are probably right.  My wife does think I am crazy when I spend so much time talking about and reading about wood and sawmills.  But I have always liked trees and woodworking, so a sawmill fits in perfect.  It is nice to be able to get on the forestry forum and tap into years of experience from like minded people, who really care and want to help you find an answer to your question or problem.
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
flatrock58
Well after along break I finally made time to cut some SYP logs today.  With a sharp blade and the outside blade to roller flange adjusted everything worked great.
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
4x4American
Here's my $.02
I think that since you kept breaking blades, it was an alignment issue; the blade hitting the flange, getting it hot, making that crack in the back, and breaking.  I think that the blade has rounded teeth and that piece of steel sticking off from when the blade broke and hit the shield.  If it broke from being dull, the stress crack would be on the teeth side of the blade, and if you're grinding the gullet too hard the stress crack will be on the teeth side.  In this particular situation, the stress crack being on the back of the blade, it's from hitting that flange.  The blades can be brand new fresh from the factory, if you're pushing the blade against that flange it's gonna heat the blade up and break.
When you checked your alignment, did you check it with the movable guide roller at almost all the way in and almost all the way out?
Boy, back in my day..
flatrock58
4x4American, you are probably right about the way the blade broke and the damage.  I just had the mill aligned at WM  and have not cut that much.  I periodically check to see if things are aligned, so I don't know ho the outside wheel got out of alignment unless the jam nut was not tight.  I did check the movable guide roller all the way out and all the way in and it stayed aligned.
I have noticed that most of the old blades that have broken when the guide roller is almost all the way in.  That might just be coincidence but it makes me wonder.  I have not seen any other blades with cracks at the back of the blade, but I will go back and look at the collection of old broken blades.
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
fishfighter
First blade I broke last week, I took the time to look a it today real close. No other cracks anywhere. That was a new, but kind of dull blade. It was a Kasco blade that I am trying now. It was the first out the order. :-\
