Wavey cuts
Started by bandmiller2, August 04, 2015, 09:24:39 PM
Guys I would like your opinions. I suspect too much set leads to wavy cuts around knots. I think minimal set supports the rear of the band and limits the deviation when you hit a knot. I know the common advice is to use more set. Lately I've been using less set .015-.020 per side and  have no hint wave. Frank C.
drobertson
 I say if it works use it,  knots and logs come and go, and there is no way I would or could pick a band just for specific purposes.  I've heard less set works, and believe it, I've heard more set, and not to sure about this one.  for me it is the finish not necessarily the production rate.  Finish product always comes first.  Not much of a comment to your op, but just my way,  factory sets at around .025 give or take work for me,
kelLOGg
Very interesting, Frank. So the narrow kerf acts as a band stabilizer in your model. I'll be interested in comments in light of my recent thread on a related subject.
Bob
5quarter
Frank, you're talking about cutting pine, right? It's been my experience that the opposite is true. Although if it ain't broke, don't fix it.  ;)
Blue Harbor Refinishing
boscojmb
Here in southern New England, lots of knots usually means EWP and lots of pitch to go with it.
Excessive set does not directly help with knotty wood, but does help with pitch buildup on the blade.
My personal opinion is, use minimal set, skip the water based lube, and run diesel @ 1 drop per second.
You will use about 1 pint of diesel per MBF. This is a whole lot less than the amount of bar oil that you use in your chainsaw.
John B.
Log-Master LM4
Peter Drouin
I push my 55/7s out to 30 and cut dry. If I need lube to get the pitch off I use just water. One or two cuts will cleen the blade.
For me If I get a wave the blade is dull. For me If the blade gets hot it's dull. And I run the blade tight.
I push the feed to bring down my 51 horse Cat in a cut.
For me, I don't care If I'm going into the top or bottom of the tree / log. I cut them as they come. ;D
A&P saw Mill LLC.
License NH softwood grader.
Pete, how's you band life running so tight.?? When I ran the LT-70 would get two or three sharpenings then bam. Like you we never used any lube, never had any problems and some of the pine was just cut. Frank C.
terrifictimbersllc
I have dealt with wave issues sawing wider or dry spruce, by using 30-35 thousandths set bands rather than the more usual 26 thousandths set (my bands are 7 degree, .045, 1-1/4)  I have been thinking that more set is better for knotty softwoods.
Peter Drouin
Quote from: bandmiller2 on August 11, 2015, 08:05:30 AM
That's all I get, Maybe 4 sharpening. But by that time the hard part of the tooth is gone.
Like today I'm cutting Hemlock and the blades have been sharpened 3 or 4 times and they dull cutting 2 to 3 logs. I hate to toss them, but do I want to spend all my time changing out blades.
I may try the new by metal ones when they come out with the 55. All they have now is 45s.
A&P saw Mill LLC.
Peter Drouin
Is your wave this bad ? If not, no worries.  :D :D :D :D :D :D :D :D
;D ;D ;D ;D
A&P saw Mill LLC.
POSTON WIDEHEAD
You'll starve sawing lumber like that.  :D
Peter Drouin
Quote from: POSTONLT40HD on August 11, 2015, 05:33:30 PM
What makes you think the customer does not want it that way. :D :D :D :D
A&P saw Mill LLC.
Dave Shepard
Peter, do you find the Turbo 7 bands cut great, then when they are done, they fail fast? That's what I'm getting on the mill at work. You'd think you just ran into an insulator or something.
Peter Drouin
I have not tried the Turbos yet. Have too many reg7. And you have to get a turbo 7 CBN wheel too. Not just the blades.
Do you like my wave. It was made with a sharp blade. :D
A&P saw Mill LLC.
crowhill
Peter, it's just rough sawn lumber right?!!
TimberKing B-20, Kubota M-4900 w/FEL with tooth bar, hyd thumb and forks, Farmi winch, 4 chain saws.
Peter,
That cant is waving at me  :D.
Ox
Yikes.  I sometimes run into that as well.  Sometimes a different log from the same tree.  Nothing changed on mill or the blade but it just waves at me sometimes.  Then the third log is just fine.  Maddening.  Sometimes these trees just don't want to be boards.
Chuck White
Sometimes the waves will go away if you have the means, and turn the log around, end-for-end!
If you're sawing from the bottom (of the tree) to the top, switch and saw from the top to the bottom!
Peter Drouin
Just so you all know, The wave I made while going up and down with the head in the cut.  ;D
A&P saw Mill LLC.
deadfall
Quote from: Peter Drouin on August 12, 2015, 12:34:23 PM
You're lucky the cops weren't following you.  smiley_policeman
W-M LT40HD -- Siding Attachment -- Lathe-Mizer -- Ancient PTO Buzz Saw
Happy for no reason.
Chuck White
Looked a little obvious to me also, but....... things do happen!  ::)
Once in a while when I'm making and opening cut and it wouldn't be clean all the way to the end, I will lift the sawhead up through and out of the log, return to the front and start another cut, a little deeper.
Just don't want to lift out too fast, something bad could happen.   :-\
Hey, a wave is a wave, no matter how you do it  :D.
Peter Drouin
Quote from: Chuck White on August 12, 2015, 01:50:26 PM
I do the same thing.  smiley_thumbsup
A&P saw Mill LLC.
4x4American
I never thought to do that ^^ great idea!
Boy, back in my day..
POSTON WIDEHEAD
Quote from: WDH on August 12, 2015, 08:32:56 PM
smiley_wavy
