Oliver Manufacturing bandsaw
Started by ghitch75, August 04, 2015, 08:22:17 AM
ghitch75
i'm new to here as you can tell.........i'm not new to wood cutting as with chainsaws but not a mill.......i got the mill from estate sell and the mill came with no instructions.......Oliver is out of business as far as i can tell......can anyone give me the low down on how to set it up correctly.......
i get the jest of it and just want to make sure i'm doing it right....
Oliver Manufacturing 20ft 25HP Kohler
1954 AC WD45
1966 IH 500 10 Bullgrader
1979 Case 580C Extandahoe
1985 IH  S Series 1954
1993 K3500 Chevy dump
Chuck White
Welcome to the Forestry Forum, ghitch75.
Search through "Oliversawmill.com"!
There are several mills to check through!
No help, but Welcome to the Forestry Forum, ghitch75.
ghitch75
Quote from: Chuck White on August 04, 2015, 01:17:16 PM
thanks for the welcome!!!!
when you searched "Oliversawmill.com" was that search on the forums or a search engine?........i tried here and search engine and came up with nothing.....
thanks for your help....
1954 AC WD45
Chuck White
No, on Internet Explorer is where I saw the info!
www.oliversawmill.com
redbeard
ghitch75
Quote from: Chuck White on August 04, 2015, 05:58:24 PM
well Chuck i tried Chrome,Firefox and Internet Explorer and it say's "This webpage is not available"
i guess my search foo is not good today ???
1954 AC WD45
ghitch75
Quote from: redbeard on August 04, 2015, 06:00:22 PM
What model # is your Oliver?
i don't know i can't find the tag on it.......it just has 2 licences plates on both of the doors where the blade pullys are that say "Oliver Manufacturing" with there address and phone number....
i did cut up a 14" 12' long Hickory today......only got 7 good 4/4 boards and rest are going in the boiler >:(
oh well i'm learnin'... ;D
1954 AC WD45
21incher
Welcome to the forestry forum ghitch75. I can't help you, but some pictures of the mill may help identify it.
47sawdust
I know there was a post earlier in the year about an Oliver sawmill but I can't find a reference to it now.Thought they were made in Arkansas or Missouri,believe they are no longer in business.
Well....I did some pokin' round, a post was made by GareyD on June 22nd,2005 about Oliver sawmill.The title of the post was
'' a different brand of sawmill"....Yes I know that's not earlier THIS year.I don't know the quickest way to retrieve an old post,either look up the author or scroll back through the posts...there is a danger of getting sidetracked if you do that though and you forget what you first started looking for.Happy hunting
Mick
ghitch75
1954 AC WD45
Bruno of NH
Looks like a well built mill .
Jim/Bruno
samandothers
Can't help you but wanted to say welcome!
East ky logging
You might want to try something besides hickory to try on the first few tries.
They who can give up essential liberty to obtain a little temporary safety deserve neither liberty or safety- Benjamin Franklin
Kbeitz
Love machine shop work
and Wood work shop work
And now a saw mill work
ghitch75
Quote from: East ky logging on August 04, 2015, 07:52:40 PM
all i had on hand.......next try will be poplar ;D
1954 AC WD45
ghitch75,welcome to the forum. What's all the lumber going to be used for? You said boiler? Just a homeowner one or bigger?
ghitch75
Quote from: Kbeitz on August 04, 2015, 08:01:31 PM
Found it....
http://www.geocities.ws/oliverbandsawmills/
More....
https://forestryforum.com/board/index.php/topic,12833.0.html
thanks Kbeitz!!!!!.......the 20ft 25hp Kohler is the one i have.......i tried emailing them about a manual......when i called the number it just rang and rang....
1954 AC WD45
ghitch75
Quote from: thecfarm on August 04, 2015, 08:54:02 PM
my the lumber is going to be for a pole barn i'm going to build then i may hire it and me out if anyone needs anything cut.....
boiler heats my home,shed and to be pole barn....
1954 AC WD45
garyfg
look's just like mine. Mine has the cooks blade guides added on by the fellow I got it from. Haven't used it in a while because the engine was stolen. I never had a manual for it. The best I remember the guy I bought it from said it didn't come with one. He said Oliver just gave him the run down how to use it. It pretty much like any other bandmill. The most trouble I had with mine was short blade life. It didn't like big logs very much but I may not have ever got it adjusted right.
Gary
Chuck White
Might want to save out some of that Hickory for the smoker.
Just sayin'!
ghitch75
Quote from: Chuck White on August 04, 2015, 10:24:45 PM
Just sayin'!
i have plenty to smoke......47 acres worth :)
1954 AC WD45
Chuck White
Lucky You!!!
We don't have a lot, just "some"!
ghitch75
hey Chuck what brand of blades do you use?
1954 AC WD45
4x4American
I have had great luck with Wood-Mizer's blades.  They will sell you any amount cut to whatever length you need.
Boy, back in my day..
