skidder shopping advice
Started by lynde37avery, August 02, 2015, 09:08:42 PM
David-L
I like the custom windshield, looks good. Last I remember, that one had a been gone through and did not have alot of time on it.
ga jones
Yes 16.9x30 and 18.4x26 chains are the same. That has Pr52 axles just like the c4 and the rims will fit also but the offset is a little different
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
lynde37avery
oh thats such good news about the chains being interchangeable. i have a pair of almost new looking single net ice picks that i would think are way better than the tractor chains that are on it now.
Detroit WHAT?
grassfed
I think that the chains that are on it in the picture would make good summer chains. I run without chains in the summer because the rear axle on my 440B does not have a diff. If the TJ has a locked rear running chains on solid ground will make it turn harder and put more stress and wear on the driveline. Chains that fit 18.4x26 should also fit 16.9 x30s and 18.4x30s
Mike
BargeMonkey
 That's a good looking skidder. How did your foot heal up ?
lynde37avery
Foot healed up great! It's a pretty gnarly scar. Doesn't bend much and it'd pretty sensitive. But its there.
Yes those will be my summer chains. I will be set for years.
Detroit WHAT?
Ohio_Bill
Congratulations, good looking Skidder
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
sandersen
Very smart purchase...it looks like a real nice TJ.  Can't beat em.  Congrats!
"Make every step count."
loggah
The 208's are nice machines,the first skidder my father bought new was a 208 after we stopped using a 310 case crawler for logging. he did have a bunch of planetary problems in one side and it was because the factory didn,t have the wheel bearings tight enough.If you take any planetarys out make sure the wheel bearings are "TIGHT" !!
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
lynde37avery
thanks guys, I'm very happy with my purchase. i been pulling firewood with it and im amazed at how much BETTER it operates and manuvers than the old Franklin.
Detroit WHAT?
chester_tree _farmah
Well sounds like u decided which u prefer :)
254xp
C4B Can-Car Tree Farmer
Ford 1720 4wd loader hoe
Farmin logger
Good luck with the new skidder.
Maine logger88
Congratulations! Looks like a nice machine! Looks like it has awesome rubber on it
lynde37avery
yea the tires are nearly new looking. about 95% if one was to calculate it.
i been running it a lot this week. pulling firewood for my cut/split orders and saw logs for local mill.
the 208 is incredibly stable and great on fuel. it seems so tight and responsive, all the levers are tight and work perfect.
8)
Detroit WHAT?
lopet
Good for you.  8)
I always wondered how people can get levers go sloppy. ;D
