Bumps/rises in pine boards
Started by Solstice223, August 02, 2015, 12:16:06 AM
Solstice223
Hey guys I just bought a like new Norwood hd36. I'm getting rises/bumps when milling through knots on pine logs. Should I increase the band tension or maybe replace the ceramics?
Brucer
Usually this is caused by the blade slowing down as it bites into the knots. By the time the governor picks up the slack you're through the knot and the damage is done. Increasing the blade tension may compensate some, but it doesn't solve the basic problem. Some things that will reduce the problem:
  • Saw more slowly.
  • Diesel engines are better than gas at maintaining a constant speed.
  • Electric motors are better than diesel.
  • Smaller blade angle helps: 4° or 7° rather than the usual general purpose 10° blade.
  • Keep the blade sharp.
  • Be fanatical about blade and carriage alignment.
Bruce    LT40HDG28 bandsaw
Sometimes its hard to avoid but can be reduced as Brucer says less hook slow down going into knots and generally good band maintenance will help that being sharp and proper set. Take a scrap pine board and a hand chisel hold the chisel at 10 degrees and push it over the board, it wants to dig in. Try it now with a 4 degree that acts like a scraper with almost no tendency to dig in. Going from soft to hard is problematic for bands they tend to deviate. Frank C.
Welcome to the Forestry Forum, Solstice223.  Adding your location and sawmill to your profile helps with answering questions.
4° blades and entering the log from the top end rather than the butt end helps, but will not eliminate "knot wave".  All of the above suggestions are very vital to sawing.
Chuck White
Welcome to the Forestry Forum, Solstice223!
drobertson
If the blade tension is not enough then yes crank it up a bit,  pine knots show up at times, the faster speeds will produce more rise at times, it's kinda a touchy feely thing.
Solstice223
Hey guys thanks a bunch! Completely new to all of this so all the info is a great help!
Banjo picker
Quote from: Magicman on August 02, 2015, 08:42:46 AM
I nearly always load the log butt first, but I can see the wisdom in turning a knottly log the other way...thanks Lynn I will give that a try.  Banjo
deadfall
I generally prefer attacking the log from the upper end.  I will often turn them around to get it that way.  I just feel I can see what's in the log easier from that end.  I don't know why that is.  Never did any analysis of that idea.
The tree we get here in the PNW where the knots will have their way with you is Sitka spruce.  I love the wood (between the knots).  It is so light and so strong.  I wonder how many piano, violin, and guitar sound boards it took to make that Spruce Goose?
W-M LT40HD -- Siding Attachment -- Lathe-Mizer -- Ancient PTO Buzz Saw
Happy for no reason.
QuoteI wonder how many piano, violin, and guitar sound boards it took to make that Spruce Goose?
The wood most used in the "spruce goose" was birch.  ;)
The press called it the Spruce Goose and Howard Hughes didn't like the name, as he thought it was disrespectful of those who worked hard to build it.
customsawyer
You might also check your drive belt tension.
www.thecustomsawyer.com
Cutting Edge
Quote from: Solstice223 on August 02, 2015, 12:16:06 AM
....maybe replace the ceramics?
Yes,  that would be the best long term solution.  The ceramic guides actually compound the issue(s) of wavy cuts.  I've been down this road w/ a similar guide system.
Each time the blade deviates from it's straight-line path, it makes contact with the ceramic.  This generates heat which is transferred to the blade body.  Once this occurs, the blade looses tension.  Blade begins to make more contact w/ the guides, more heat generated, even further loss of tension.  As you can gather from the description, it is a downward spiral once it starts.
Does increasing the amount of lube help... kinda-sorta.  But then you have a soupy mess to deal with on everything/everywhere and you're only camouflaging the root cause of your problem.  Increasing the tension while the blade is hot/running only further damages the blade body.  Not to mention the additional stress placed on the carriage and components that it wasn't designed handle.
Upgrade to a roller guide system that applies down pressure and gives FULL adjustability... similar to what most consider as the industry standard.  Once you do, you won't look back.
http://store.cookssaw.com/sawmill-parts/roller-guides/standard-roller-guides/for-1-1-4-blades/1-1-4-complete-retrofit.html
Hope this helps
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
- Sharpening Services
- Portable/Custom Milling and Slabbing
- On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blades
Ph- (304) 878-3343
Jim_Rogers
Rise and bumps are a sign of dull blade.
Put on a sharp one.
Jim Rogers
Solstice223
Thanks guys, cutting edge, do you have a picture of that device installed on your mill?
ladylake
I agree with cutting edge, put on some roller guides with at least 1/4" down pressure . Then the sharp blades, less hook, enough set and a clean blade plus I'm really liking 3/4 pitch blades better than 7/8.  Steve
gmmills
   As Cutting Edge suggested, upgrade to actual roller guides.  He is also right on the money with the issues of heat induced loss of tension as the blade contacts the ceramic pads.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Cutting Edge
Quote from: Solstice223 on August 03, 2015, 12:14:09 AM
... cutting edge, do you have a picture of that device installed on your mill?
I'm sorry, I don't have any pics of the upgrade.
But, I can do you one better.  ;D  I did some digging and found the image below, from a LOGOSOL sawmill (re-badged Norwood sold overseas).
Direct swap/upgrade with no modifications ??  Might be worth investigating further.
Edit:  These roller guides don't have the adjustability as the ones from Cooks, but it would be a BIG step in the right direction.
Ph- (304) 878-3343
Solstice223
That's really slick. I'm going to have to buy that. Sure would near buying ceramics all the time. How long are you guys seeing the ceramics last before you need to change them out?
