Cable for log truck cargo control
Started by brendonv, July 25, 2015, 05:04:44 PM
brendonv
Where does a guy get cable with a hook end to tie down logs using a welded on cargo winch?
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
sawguy21
Is there a wire rope supplier in your area?
UN Hooker
http://www.cableworksusa.com/   Their in Putnam CT.  Their good - they can make most any cable combo. you need.      UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
brendonv
www.VorioTree.com
Gary_C
I believe those winches are only approved for straps and not cable. The log trucks that use cable tie downs generally have a short piece of chain on the end of the cable instead of a hook and a load binder for tie down.
I generally don't like the chains or cable for tie downs because they always are loose. The straps can be stretched a little to allow for settling and the chains and cables not.
Jamie_C
The company I work for has about 15 trucks hauling wood and I'm not aware of any of them still using straps, as long as the cables meet the strength requirements then everything is fine up here.
Jhenderson
Dot approved chains and straps have identifying marks or labels. How are cables identified as being Dot legal?
brendonv
Cables would have tags.
I might of figured out my issue tho, and may be able to still use straps.
www.VorioTree.com
cutter88
We go to a place called sling & Chocker but any cable place can make them up
Romans 10 vs 9
650G lgp Deere , 640D deere, 644B deere loader, 247B cat, 4290 spit fire , home made fire wood processor, 2008 dodge diesel  and a bunch of huskys and jonsereds (IN MEMORY OF BARRY ROGERSON)
luvmexfood
I got a piece of 3/8 cable around 65' with a hook the other day for around $35.00 at HF the other day. They sell it as a replacement winch cable.
Give me a new saw chain and I can find you a rock in a heartbeat.
